Question about Canon PIXMA MP210 Photo All-In-One Printer
Cannot use my scanner. the photocopier works perfectly, but the scanner, no way. can you help pls?
  • Valerie Ferrari
    Valerie Ferrari Feb 07, 2010
    Thanks. I will definitely try doing what you suggest and then let you know. Wish you a happy sunday. Once again, thanks.
  • 4,889 Answers
There are a few things you can try here
1)Un-install the printer from device manager and then remove any associated software from the control panel. Download the driver from the link below and re-install it
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=15402#DownloadDetailAct
and see if it resolves the issue.
2) When you press the scan button on the printer do you see the scanning LED move down the surface of the glass. If yes then is it lighting up?
Please answer this question so that we can decide what to do next.
Sai.
Posted on Feb 07, 2010
  • eagle338
    eagle338 Feb 07, 2010
    Sure. Also since you have accepted the thread you may not be able to post further replies on it. Please send your further responses to vls_powerful2002@yahoo.co.in.
    Happy sunday to you too.
    Sai.
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
Hello, The scanner & photocopier were not working and the screen was just stuck on the "scanner bulb warming up". Then, after days of trouble shooting, it finally began making a noise,...
From what you described it sounds like you need to get the "scanner assembly" replaced.
The bulb is probably bad and won't come on to full power.
Not knowing what kind of printer you have, probably won't change the fix. If you can look at the event log you may be able to see an error code which could make it a definite scanner assembly replacement.
If you want to throw money at this unknown printer, get a tech to look at it and give you an estimate.
Jan 17, 2011 | Office Equipment & Supplies
Scanner function does not appear to work. All
i would say possibly you are missing out on something..because if the other functions particularly photocopying are working then this should work..as in if the photocopying function works then the scanner is ok cause basically in photocopying the machine scans then prints... perhaps check whether you are correctly following procedure to scan..most hp all in ones have a button on them that you press and it automatically initiates scanning and simultaneously the software on the pc is initiated..try this,if not then try reinstalling the hp software..hope this helps..regards
Jun 04, 2010 | HP Photosmart 2575 All-In-One Printer,...
Scanner ink failure pop up appeares when i try to photocopy
pls try to rifilled your catridge or change your printer catridge
Oct 08, 2009 | Umax Astra 3400 Flatbed Scanner
Printer/scanner/photocopier. scanner not working. Any ideas?
Are you scanning to your computer? If you are getting an error during the transfer to your computer, check your firewall. I had a scanner (mine is a Panasonic) problem with the transfer to my computer. I corrected it by printing the properties of the scanner and found out the port number that the scanner used and opened the port in the firewall. Hope it helps.
May 04, 2009 | Office Equipment & Supplies
All in one printer, scanner and photocopier wont work?
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 08, 2009 | Epson Stylus RX425 Multifunction...
Hp psc 1210 all-in-one the scanner is not working
These "Experts" are ****! Thanks to Yahoo Answers I found a VERY simple solution which I had totally overlooked!! Don't uninstall / reinstall printer drivers before checking in your control panel under "Scanners and Cameras"! Make sure that your device is listed and the "Scanner and Camera Wizard" will take it from there. Next time I will go straight to Yahoo instead of this lame excuse for a "tech" site!
Feb 10, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp 1317 psc
you didn't describe your problem briefly. 1. Check if you photocopy anything, it is coming out correctly you are doing. it means your scanner is perfectly allright. 2. if you are not able to photocopy with this printer, it means your scanner is not working properly. But if it photocopying properly and in windows it is not scanning it means software is not working properly, try to arrange new software from anywhere and try.
Sep 24, 2007 | HP PSC 1315 All-In-One InkJet Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
18 people viewed this question
old marine
old marine
