Question about Tascam 2488 Portastudio Multitrack Recorder System
I've been exporting master tracks and now I've reached a point where the tascam says, "master track too big". how do I free up space on the FAT partition?
    Problem Solver:
  • 15 Answers
If you NO LONGER NEED the songs/data in the FAT partition, you can delete the entire contents thereof in the manner detailed below. Note that these instructions were taken directly from the Neo manual.
1 With the transport stopped, from the DISK menu, highlight FAT REFORM, and press YES/ENTER.
2 A pop-up message appears.
3 Ask yourself once more if you want to erase all the data on the FAT partition. Press YES/ENTER to continue with the operation when a pop-up appears, or press NO/EXIT to halt the operation.
4 When you reformat the FAT partition, four directories (folders) named WAVE, SMF, BACKUP and UTILITY are automatically created. These folders are used for audio files, Standard MIDI Files (SMF) and backup data and system utilities, respectively.
...this will reformat and thereby EMPTY the contents of the FAT partition and create the 4 new, empty files as listed above.
THINK before you do this though, and I hope this helps.
Posted on Feb 28, 2010
Tascam DO-02 Master will not light and cannot export tunes to CD for burning. Is there a short cut.?
You might want to post this question in a different section. This is the computer section.
Jun 28, 2012 | Tascam DP-02 8-track Digital Portastudio...
On my tascam 2488 neo, ive recorded a song that is 2min16sec. i set my in at zero and out at 2min23. i hit mixdown and then try to hit play and record and the record button will not light up or actually...
I think if you had the manual you would know the answer to the last question.
Tracks must be a minimum of 4 seconds long (page 118)
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Jan 28, 2011 | Tascam 2488 Portastudio Multitrack...
Every time I try to Export a mastered track it says "Mastered Track Too Big" However I have deleted everything I possibly can.... Why is it all of a sudden saying I don't have enough disk space?
Several of my music programs seem to have a limit of around 2Gb for a track... this is inspite of having plenty of disk space... this seems to be a limit set by the program rather than the resources available.
Dec 02, 2010 | Tascam Music
TRANSFERING OLD TRACKS TO THE NEW TASCAM 2488-NEO
You'll need your PC as the intermediary. You'll have to do a USB export of the tracks you want from the DP01 to your PC and then connect the 2488's USB to the PC and do a USB import of those tracks into new tracks on the 2488.
Page 40 of the DP01FX manual will explain using the USB connection and page 43 details the steps for performing a USB export.
In the 2488 NEO manual refer to pages 80 and 81 for using the USB connection and importing the tracks.
Hope this helps. Best of luck.
bd.
Oct 14, 2009 | Tascam 2488 Portastudio Multitrack...
Master Track too big to export.??
Im having exactly the same problem as you have/had..I cant Export the Master Track..It says "Too Big", have you been able to solve it?
Best Wishes
Steve
Mar 30, 2009 | Tascam DP01 All-In-One Recording Package...
i'm having the same problem... did you ever get it fixed?
Mar 30, 2009 | Tascam DP01FX All-In-One Recording Package...
Tascam DP-01 master track too big to export
Here is what I did to solve this issue:
1. Open up the USB connection on your DP-01 so that you may plug into a computer:
MENU-
Mar 24, 2009 | Tascam DP01 All-In-One Recording Package...
Tascam DP-02CF: How to transfer files to my computer?
You can't see the fat partition from within the DP-02. It's there, but only your PC will be able to read the contents of the fat partition when you have the USB 'opened' on the DP-02. The manual states that if your CF card is less than 5 Gb in size than you will only see/be able to select one partition. The default CF card that comes with the DP-02CF is only 1 Gb.
If you've created a backup or exported your wav files properly and everything is working ok with the CF, then you should be able to see backup or wav files showing up in the fat partition while connected to the PC. Even if nothing is backed up or exported you should still see the directory structure from your PC with the three folders, BACKUP, WAVE and UTILITY. As you are not even seeing these directories, what may have happened is that the fat partition had become corrupted or these folders had gotten erased.
I would have thought that reformatting the FAT partition would have fixed this problem however and that the DP02-CF would automatically recreate the required directories on the CF media after a reformat. The manual is unclear on this however.
So a couple of things you could try:
1. You describe opening the USB connection as 'push the USB button and then hit enter'. I was assuming you meant that you were selecting 'usb' from the menu and then pressing the 'enter' button to open the usb connection. You may wish to verify that the usb connection is being opened properly first.
2. If the connection is opening ok, and after a reformat you still aren't seeing any folders in the fat partition while connected to your PC with the usb open, you might wish to try to recreating those directories in the FAT partition yourself. While accessing the FAT partition (DP-02CF's removable drive) from the PC create the three directories exactly as named in the manual (WAVE, BACKUP, UTILITY). If that works, disconnect from the PC, try exporting a track or backing up a song again, and reconnect to the PC to see if you can see/access those files now.
Best of luck.
bd.
Jan 02, 2009 | Tascam 2488 Portastudio Multitrack...
Usb file transfer
In reading and working with the unit, I have learned that the file transfer is for backup only. If you want to manipulate the file they have to be transferred individually via your sound card or an interface.
Jun 21, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
200 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
