Question about Dell Inspiron 1000 Notebook
Broken Ethernet Adapter
Hi, I recently had an accident, in which the ethernet cable was torn from the adapter. After everything was plugged back in, the network would not connect. I thought the cable had snapped, but upon closer inspection, I noticed that the laptop's ethernet port only had 7 of the eight pins raised. So, my question is, is there a way to replace the ethernet adapter, or should I try wiring or something. I'm eager to fix this problem ASAP, any suggestions would be helpful.
  • TastyPaper Feb 21, 2008
    That's a great idea, I suspected there might be a USB-to-Ethernet sort of thing. I also got a suggestion refering to an ethernet PCI card, which I didn't know about. Thanks a lot, iZen!
    I must be using the wrong name then (wouldn't be the fist time.) I meant the interchangeable card slot on a laptop.
  • 28 Answers
They sell USB to Ethernet adapters that you can use. If you want to replace the adapter yourself you will have to strip the laptop down to the mother board, then proceed to de-solder then solder the new one back onto the board. You can but the replacement piece from either http://sparepartswarehouse.com if they have your make and model, or you can get it from your laptop's distributer.
Posted on Feb 21, 2008
  • Tim Kelso
    Tim Kelso Feb 21, 2008
    Ethernet PCI cards are for Desktops ONLY.
Sony bravia lcd tv 40 inch
I have a Sony Bravia 46'' TV. I bought a Universal WiFi Adapter from Walmart a few years ago for about $50. You have to plug it into the Ethernet port on the Bravia using an Ethernet cable (the other end of the Ethernet cable goes into the Ethernet port on the adapter). The adapter needs also a power outlet. I do not remember if the adapter came with the Ethernet cable (likely) or I had to buy it separately.
Before buying the adapter make sure that:
1. Your Bravia has an Ethernet port (on my Bravia it is in the back of the TV), and
2. You have/use a wireless router for your home network.
Hope this helps.
Jun 22, 2014 | Sony BRAVIA Televison & Video
Need to connect to internet through comcast cable where is the ethernet connection on the machine
hi
yes there is ethernet connection bilten in mother board just chack back site of your CPU
May 16, 2010 | E-Machines T1100 PC Desktop
Can you explain to an idiot, which exactly what is the correct way to connect Powerline Adapters to orange livebox, I have connected Powerline Adapter to yellow ethernet socket is this correct with the...
Plug the PowerLine adapter into the wall
Plug one end of the ethernet cable into PowerLine wall adapter
Plug the other end of the ethernet cable into the Orange LiveBox
Plug the Orange LiveBox power adapter into the wall
Mar 09, 2010 | Powerline Ethernet Network Adapter
I have the ethernet cable plugged into a netgear wireless n router but when I run setup it says I don't have an ethernet adapter
ethernet cable and adapter are different!
1st see if you have internet access with the cable- if you have access then the cable is working
Aug 10, 2009 | Gateway Computers & Internet
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
Router to desktop plug
what o.s windows..98.me.2000..or...xp
1. purchase a network adapter at your local electronics store wireless or ethernet adapter
2...install to desktop report back if Ethernet adapter is chosen i will help you install it in your desk top. ( Install time 30min.)
either is an easy fix you can do it you should not spend more than $60.
please reply if this helps
and don't forget the power of your vote
p.s GOOD LUCK
Jun 09, 2008 | Computers & Internet
Ethernet adapter jack is broken
There are Ethernet to USB adapter such the products shown here. Alternately, you can use a PCMCIA card with Ethernet such as shown here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 13, 2008 | Computers & Internet
Adapter issue
Pls reconnect the Ethernet cable back to the other PC and check how is its getting IP address, automatic (Obtain an IP...) or fix (Use the following...). To do this go to your Control Panel, click on Network Connections, right click on Local Area Connection, click on Properties, highlight Internet Protocol (TCP/IP), click on Properties button. If it is the latter, note down the numbers.
Plug the Ethernet back to your laptop and do the same. Set your laptop's Internet Protocol Properties to mimic the other computer settings. The only possible difference would be is if the other computer is ticked on "Use the....", the IP address of the laptop should be different from the other PC. Example if the other PC is 192.168.1.5, make the laptop 192.168.1.6. All others stay the same.
Hope this ne of help/idea. Pls post back how things turned up or should you need additional information.
Jan 24, 2008 | Broadcom BCM5704 10/100/1000BASE-T...
Dell Inspiron 1000 Notebook Logo
105 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
