Question about Cell Phones
Radio problem when i plug the headphones the radio is started but station cant find i was done autotunning but still cant work
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: TV does not autotune to all stations and does not store stations
The set has a EPROM somewhere that stores that info--either a stand alone one or one incorporated into the microprocessor the set uses.
The tuner if bad likely will not cause it to "forget" stored channels.
A possible way AROUND this would be the use of a cable/sat box connected to rear inputs on the set---you would sit on that input and change channels via the box which can usually be programmed to skip up/down channels you do not want---straight around the issue.
Posted on May 29, 2012
How do I un-freeze my Pure One mini radio?
Try removing the power sourse, wait a few seconds, then restoring it. Hopefully it will clear this problem.
May 29, 2016 | Pure Protein Pure One Mini Series Ii...
How do I manually tune an autotune Ford radio?
On my Ford radio, you press and hold one of the radio station buttons until it beeps, then it does a manual scroll through all the channels looking for a station. Once found, another press locks it in. Maybe your would work the same way.
May 26, 2015 | Ford F-150 F150 Extended Cab
Just bought used pair of wharfedale 28637WH headphones dont know how to connect them to av unit. i cant download manual as using ps3 to do this. can u help with this? thanks craig
The base station for these headphones will have to be plugged into your AV unit. This is done with either a 1/8" jack or a 1/4" jack. Once the base station is plugged in, you will be able to use your wireless headphones.
Mar 15, 2011 | Audio Players & Recorders
How to hookup kindle to car audio system
This could be either very easy or a huge headache.
Easy way - The newer cars have an audio input jack, basically a headphone jack (1/8"). There are cables that you can use with 2 male connectors; one on each end. Set your car radio on AUX/LINE IN/MP3 and turn it up.
Hard way - Go to Radioshack or Best Buy, even Target or Wallmart, and buy an FM Transmitter. They shouldn't run over $20. You plug it into you cigarette outlet for power and/or takes 2 AA batteries. Plug the headphone jack into your Kindle and set the radio station on the transmitter to either a very low or very high radio station; somewhere where there is no station close by. Turn the car FM radio to the station you set it on and turn it up.
Sep 18, 2009 | Amazon Kindle 2
Can not tune in Dab radio on AX-M131U
If it's anything lioke my DAB radio there is a Tune button that you hold down for more than 5secs and it goes into 'Autotune' mode - so that after some time ,say 1min, all the available stations are tuned1
Hope this works for you .
Nov 19, 2008 | Audio Players & Recorders
DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
Feb 22, 2008 | Audio Players & Recorders
Radio cannot do loadspeaker without headphones
i think its a factory setting you cant change. you cant listen to radio without headphones.
Nov 03, 2007 | Nokia 5300 Grey Cellular Phone
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
