Question about Ovens
How to operate a franke electric oven
Hi i just need to know how to operate the oven for general purposes such as baking. I need to know which symbol stands for what. thanks
Posted on Feb 14, 2010
  • levisi2
    levisi2 Apr 03, 2012
    so wheres the answer???
    Problem Solver:
I too have a franke oven. Maybe I can help you. Obviously have to see if the type is the same. What is your problem? P.S. I am very happy with mine
Posted on Feb 07, 2010
  • william mateer
    william mateer Jan 27, 2014
    problem is i do not know how to turn it on, ,i just bought this house and the stove was already in. its the same as ours
Can't unlock oven door elelctrolux model130EW35
Hi Frank Tahmoush - Press the CLEAR/OFF key for approximately 15 seconds to see if it overrides the controls. If that does not work, disconnect power to the range for approximately 30 seconds and then restart unit. Reset time of day and press the CLEAR/OFF key again. If these solutions do not work, the range could possibly be experiencing a communication issue with the EOC, faulty door lock assembly or wiring failure. At this point I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit.
Mar 16, 2013 | Electrolux 30" Built-In Single Electric...
Oven light does not light
Have you tried replacing the bulb, have you check to see if you have power at the light socket , do you know how to read a meter , and do you have one ? ge back to me and we will go from there , after you do some testing thanks Frank
Dec 14, 2011 | Maytag 30" Built-In Single Electric Wall...
Error codeE6 F2
Remove the power from the oven. Open the control panel and unplug the key pad ribbon from the control board. Assemble the control panel back and turn the power on. Wait a few hours.
If the error code came back on, replace the control board.
If the error code did not show up, replace the control panel (the key pad comes as a control panel assembly).
- The part number for the new control board AP3595759
- The part number for the black/stainless control panel AP3131755
Good luck.
Gene. __________________Hi I did some research for your oven and this is what i found , someone with the same problem , control board needs to be replaced , if you click on the web page below it will explain it to you , good luck Frank
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1094-whirlpool-fault-code-e6-f2.html#ixzz1gYuqvZnV
Dec 14, 2011 | Whirlpool RBD275PR Electric Double Oven
How to fit the splashback
Hi Do you mean the screws don't match up with the holes ? I find this all the time I drill new holes to make it fit correctly. One thing you should know is stainless is very hard to drill so go to the hardware store and get a bit for stainless and also get it just a little smaller then the screws, if you bring the screws with you they will help you get the correct bit , rate this call thanks Frank
Dec 13, 2011 | Baumatic B187 Stainless Steel Electric...
My zanussi electric cooker has heated up, gone bang and there is black ash all over inside
Sharon First turn off power on this oven or unplug it if you where useing the oven then that element went bad if it was the broiler then it is that one , very easy to fix and it is cheep also, with a flash light look at the elment for damage don't touch it unless the power is off , get back to me with the information like make model serial number and i will locate the element for you and you can buy it at the place if find it for you . good luck Frank
Dec 07, 2011 | AEG B2100-4 Electric Single Oven
I have an AME10001 Built in Electric Oven and need a new door. Can you please help?
Hi always tell everyone brfore buying new check area appliance repair fo used parts , cause a door will cost more then a used unit is worth , if you still need help locating please email all info to me and the area you live in and i will help search for youthanks Frank
Dec 05, 2011 | Ovens
Moved to a new place... I don't know how to work the Franke oven.
There are some links to pdf's at the lower portion of this page.
If they aren't helpful, try the "dealer locator" on the left upper side of the page for some help.
http://www.franke.com/kitchensystems/uk/en/home/support/view_brochures.html
Feb 11, 2011 | Ovens
Oven-part of Franke Stove not working.
I have a Franke gas stove top and under one burner knob the spring is broken. Model #AD 72 M WQ
Jul 10, 2009 | Ovens
Kenmore MODEL #790.95302104 electric range
suspect you have oven on automatic by mistake. get your book out and reset the clock
Sep 14, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
672 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
