Question about Toshiba Satellite A135-S2276 Notebook
Systems always getting struct ,and have to disconnect the power to restart
  • 374 Answers
First of all if you are working on the notebook with your AC adapter,remove that coz there might be a problem with the AC.
Secondly remove all the attached components like printer,pendrive etc. and then attach one by one to see where the problem is.
Third,there might a possible reason that some program is hindering your work and causing all the mischief,better to scan your notebook with an antivirus or Download this program smit fraud fix and run it.
Fourth,update all the drivers and Windows.
Fifth reinstall OS.
Last but not the least an internal hardware problem can be another reason,call the Toshiba Customer care.
Good Luck.
Posted on Feb 07, 2010
Stuck restart
Press F8 at start up and choose to start last known good configuration. Then try the windows update again.
Dec 09, 2013 | Sony VAIO Computers & Internet
What antivirus software is compatable for samsung laptops?
normally is Norton, However you can try with AVG, is GOOD for emails +unternet brower.Remember none antiviru is the best, but you must try it. Add too antimalware for web.God bless you
Mar 28, 2013 | Samsung Computers & Internet
My monitor will not stay on, it goes on sleep mode
Your problem may be due to the sleep button in your keyboard may got struct into when you cleaned your keyboard.
Try to resolve the struct in the keys, if any.
Restart your system and if still your problem persists, then remove your keyboard and restart your computer and try with some other keyboard if possible. Once if you find out that the problem is with your keyboard, then replace the keyboard / service the existing one.'
I hope this is helpful to you. Please provide your ratings.
Thanks
Apr 05, 2010 | E-Machines eMachines Monitor E15T4
Basically the same is the question here, only the
i would first disconnect the system and temporarily put ignition system back in to factory spec
then run the car as normal and see if problem disapers
if yes then replace the antitheft control box
if no then you have to dignose further check the cars ecu
Dec 31, 2009 | 1996 Ford Explorer
When i scan the image i get is black
  1. Shut the computer system off and then disconnect the scanner from the power source.
  2. Leave the scanner disconnected from the power source for at least one full minute.
  3. Reconnect the power and then restart the computer system.
  4. When the computer system has fully restarted, try scanning again.
Nov 03, 2009 | Mustek ScanExpress A3 USB 1200 Pro Scanner
Lens error, restart the camera. How to retart. The zoom lens projected is not getting back again When the camera was on, the zoom lens cameout and got struct and not going inside. we get a instruction as...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 01, 2009 | Cameras
Anti theft will engage
Try disconnecting the positive from the alarm. Sometimes its connected straight to the battery. If its not connected to the battery look underneath the dash drivers side. Find the alarm brain, the power cable (RED) should have a fuse on it. Take the fuse off, disconnect the negative from the battery wait five minutes. Then connect everything, if you took off the right fuse the alarm should restart. If its still doing it the alarm is not the problem. If you have a trunk switch to the alarm, you can simply disconnect it. These switches are optional and often get corroded or defective almost always causing the problem described. After disconnecting the negative from the battery you might notice your car's driveability different. This is because the car's computer also gets restarted. Don't mess with anything in the car the computer will set on its own. Let me know if you still have a problem after this.
May 24, 2009 | 1997 Acura CL
Inspiron 2650 does not boot up after turning power on
Not to worry.This is due to some device connected to the system.Disconnect all external device connected and then restart
Mar 17, 2009 | Dell Inspiron 2650 Notebook
System gets restarted while playing games
Hi there , not shore if this helps but , when your playing game the graphics uses more power to run the 3d display , if the system is completely restarting from bios the power supply may not be good enuff to support this , you could try disconnecting something your not using to test this like a cd or dvd rom .
Dec 20, 2008 | Intel D101GGC Motherboard
Donot startup
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 1 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing & start the system.
Restart the system.
Hope this helps.
Good Luck.
Live, Love, Laugh.
May 15, 2008 | Acer TravelMate 2300 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
509 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
