The stereo i put in my car is getting no power, there is no sound going to the speakers, and wierd things happen to my car when i try to hook the stereo up. Whats wrong?
IF you could try to explain how you wired your system,than i will have better understanding of the problem.IF you could try to explain how you wired your system,than i will have better understanding of the problem.
You can't post conmments that contain an email address.
OLDSMOBILE ALERO 2000 speakers - find speakers that fit your ... sound. This size is capable of delivering exceptional mid-bass that can't be found in smaller ...
Easy Plug and Play Wiring Adapter. ... 2001 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram ... If you can't find your car audio wire diagram, car stereo wire diagram or car radio ... Right Rear Speaker Positive Wire (+): Dark Blue ... olds alero and I have replace the stock stereo and have found that the sound out put ...
If you had a "Bose" sound system - Factory installed - it should have and Amplified System - which means the original stereo will supply power to the Speaker Amps - that is the circuit that didn't get connected and why there is no sound.
I hope that resolves your issue
Thanks
Sounds like a wire is shorting out, probably in behind the stereo, but more likely in the back where the speakers connect. Check for something shorting out or a wire grounding out near the speaker.
You can trace back from there.
Other than that probably is the stereo.
If bumps affect the noise then you should be looking at loose wires and connections for the speakers and at the back of the system. Look for a bad earth or the earth wire connected up to something that is not really a good earth
I had the same problem when I changed out the factory cd player. I finally found the problem was that grand am gt cars have a couple of amplifiers with crossovers in them for the speakers and the after market stereos put out sound that has been slightly amplified already and when you hook up your new stereo to the wiring harness your sending amplified sound from your stereo the the factory amp then to the speakers this sometimes messes with he sound and clarity of the sound. My car is 2002 and the factory amps are located 1 under the glove box and 2 in the trunk behind the carpet on the drivers side. The amp and crossover in the front is to split the signal for the door speaker and the tweeter by the mirror and the amp in the trunk is to split the signal for the two way speaker in the back by the back window witch if they are like my factory speakers have 2 wiring harnesses connected to each speaker. the only way I could get mine to sound good was to run new wires from your stereo directly to the speakers and bypass the factory amps. This may not be the only way to fix this issue but it was the only way I could figure it out. I hope this helps
It sounds like the amp built in the car stereo has gone bad. It's common on the GM product factory radio that the amp in the radio go bad due to the heat and it may need to be replaced. The best thing to to is go to the salvage yard for a factory replacement, since your truck is 17 years old and the salvage yard will cost you around $35,00. That may vary depends on where you live, so call around. Good luck friend, the other thing to is to have the stereo repaired and hope it's not going to cost too much.
make sure the speaker wires in the car do not have one side grounded.the output on the clarion is a floating output and cannot be grounded.the best solution is to look at the wiring on each of the speakers,and match them out to the ones on the clarion.the most common colr code is white front left,gray front right green rear left and purple rear right.each speaker has a plus and minus.mixing them up will result in the speakers being out of phase and result in poor bass performance.i would wire the wires directly to the clarion using crimp connectors.the first thing i would do is power up the stereo out of the car to 12 volts,and using a speaker make sure you have sound coming out.the yellow wire which is the clock/memory is a must to be connected to constant 12 volts or no sound can result
Try leaving your cell phone at home and driving around. Cell phones and other devices many times will try using speaker wires as an extension of their antennae which is RF interference and therefore the sound of this crackling can go through your speaker system. This can happen at home or in a car.
