How to connect surround sound to my samsung 42 inch plasma screen?
SOURCE: 42 inch LG Plasma TV - Lost picture
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync
Posted on Mar 09, 2008
SOURCE: samsung 42' plasma tv,screen keep flashing, blurry,no pics
I'm not really sure what causes this but I might be able to help.
I have an LG 42 plasma which had the same problem. In my case I removed the video and the tuner board (they both were mounted on the same frame which was screwed on the tv chassis) and installed them in a "wooden box" so that there would be no electrical contact with the rest of the chassis except from the cables connected to them. It now works fine.
Posted on Feb 23, 2009
  • 304 Answers
SOURCE: pink vertical line down my 42 inch digital plasma
I do believe the Panel is bad and needs to be replaced. Check with the manfacture to confirm this.
Posted on Jul 16, 2009
roety
  • 585 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Posted on Aug 19, 2009
SOURCE: I have a 42 inch plasma and teletext wont work any
A factory reset made teletext available again on digital channels.
When on standby, push on remote in quick succession <info><menu><mute><power> buttons. Follow onscreen menu to option 12 (reset) and select. Be aware that you will have to tune in all analogue and digital channels again.
Posted on Oct 29, 2009
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs · 22 Inch to 29 Inch Class TVs · 32 Inch to 39 Inch Class TVs · 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
Jan 11, 2016 | LG 42LS5700 42 Inch 1080p 120Hz Smart TV...
I have a HP notebook laptop that I am trying to connect to a Sanyo 42 inch Plasma HDTV model DP42740 . I have VGA , S-video ,and an Expansion port 3 jacks coming out of my laptop. What way would you...
That television doesn't have a VGA input, but it does have an S-video in. So this is the cable that you would need to connect to get the video image on the screen. However, s-video does not carry sound. So you either run the sound from the laptop still, or use the earphone jack to bring the sound out to your surround amp, or tv.
May 02, 2011 | Sanyo DP42746 42 in. Plasma Television
I have samsung plasma tv 42" ps42c7s,have sound but dark ,no picture
Hi friend,,,
welcome to fixya
Commonly for Plasma tv's if the screen went out,,the problem will be the CATHODE RAY TUBE,it is costly to buy.if you want you can buy it,,or it may be the D-board problem will be also,,,
but it is unusual,so check the tube.
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Intermittent audio loss with 42 inch 2007 Sharp HD( not plasma) TV. Happens 2-4 times/hour for a second or two during most HD programs. It has gotten more frequent over the past month. We have...
Are you running the sound directly from the DirecTV box to the Onkyo reciever? or is it routed through the TV first? Personally if you have it routed through the TV you are losing out on true 5.1 surround. To ge that you need to have the DirecTV box connected via optical or digital output (orange connector) to your Onkyo amplifier. If you need further assistance please email me at tvtek(at)msn.com
Nov 17, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Samsung plasma 42 inchs with sound no picture
Most likely your Y Sustain panel has gone bad. I would have a qualified service center evaluate it to be sure.
Nov 07, 2009 | Samsung PS42P2S 42 in. Plasma Television
I have a 42 inch Insignia plasma tv. I only hook
If you have the audio cables hook up correctly to where the video cable from DVD is connected to, it should be RED and WHITE wires for audio. Then go to on screen audio setup menu to see if the speakers is turn off in the menu. Also try hooking up the powered PC speakers to the AUDIO LINE out RCA jacks to see if you get the sound OK there.
Nov 03, 2009 | Insignia 15 in. Flat Panel LCD HDTV
42 inches samsung plasma screen with sound and without image
Check this link to find the LJ41-02759A board for your TV. These boards fails quite often and the TV will power ON but with the same symptoms as yours.
Jul 15, 2009 | Philips 42PF7220A 42 in. Plasma Television
42 inch samsung plasma screen is half blacked out
the problem lies in the y or x board just replace the on thats acting up and you should be ok
Dec 31, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Samsung surround sound wont connect up properly to samasung plasma tv
i have a plasma samsung 42 inch and i dont know how to connect my jacks red,white, yellow from the dvd to the plasma and what channel should the plasma be on to see the dvd ???? thanks anthony
Mar 28, 2008 | Samsung HT-Q100 System
Sound Issue
hi.On my surround system i can play dvd's and only get sound.The tv says not receiving signal.Any help appreciated.
Mar 16, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
