Question about Mitsubishi WS-65413 65" Rear Projection Television
Hello my tv won't work
  • Dan Feb 22, 2008
    no... the green power LED stay lit whenever the tv is plugged it... the TV itself does not power on. Pressing the power button on the TV or the remote does not do anything, the power LED stays lit. Unplugging the TV and plugging it back it at a later time does not work. Changing outlets does nothing.
  • chev71 Apr 27, 2008
    green light stays on when plugged in. will not turn on
No.
Posted on May 03, 2008
  • Mitsubishi Master
  • 8,617 Answers
Does the power light flash a certain number of blinks before pausing?
Posted on Feb 22, 2008
My TV won't come on
Hello Linda,
The set will need to be diagnosed to find the problem. There could be an issue with the power supply or main board but get it checked out.
Sep 23, 2012 | Vizio L32 32 in. LCD HDTV
I bought a Radio Shack universal remote. It does not list Element codes. I've done the suggestions but it doesn't work. What are Element's codes??
hello!
"Element" codes could be: Polaroid, MAG, LG, Vizio.
Have you tried "code search" mode on universal remote? If you won't find the luck of those "brands" I suggested, do "code search". Refer to remote's owners manual. I did the same for myself: obtained RCA convertor box, without remote, RCA codes won't work, RCA is out of TV business. By using "code search" I made it work. Then, you may want to do "code retrieval" option, to know the correct code.
good luck,
Alex.
Feb 16, 2012 | Televison & Video
I am trying to add my lg tv device to my Panasonic DVD player remote, but I can not find the code for the lg tv. The model of the tv is 32LC2D.
Hello...Here are some remote codes to try...0004, 0005, 0050, 0009, 0227, 0338, 0012, 0057, 0080, 0156...Hopefully..you won't have to go thru them all before you find one that works....I hope that this was helpful....PEACE...
Jan 25, 2012 | LG Televison & Video
My remote won't work and I used to be able to change the channel on the TV but even that dosn't work. I checked the cords. Changed the batteries;
Hello
First check its battery contacts for any rust or dirt accumulated on it. If so, contacts of battery will not touch properly, and the unit will fail to work. The second reason for malfunction is due to the infrared sensor inside your tV. If it is faulty, the set won't respond to infrared signal generated by the remote control. If so, eventhough remote control works properly, the set won't work with it.
Remote sensor comes just behind the infrared window at the bottom front panel of your TV. It is a replacable part and not so costly too. It is a three terninal component will look brownish black in colour. It will looke like this.
gopakumarg43_77.jpgThe procedure to check the remote control for its perfect working is described at a tip I've given and published by Fixya on Google. Type "gopakumarg43" on google search box, and get into my profiles. There you can see 'Tips and How To's" line, click on it. You can read it there. OK.
Sep 23, 2011 | Philips Magnavox 20MT133S 20" TV
Philips 50PFP5332D 50 in. Plasma Television won't load software upgrade. Was doing the upgrade to try ans resolve a picture issue of black and white double image picture with vertical lines
I had the same problem with the same tv, replaced the main logic board for $30 used on ebay and it works perfect now. Make sure all part numbers match on the replacement part otherwise it will not work, some tv parts work in combination with other parts.
Sep 05, 2011 | Televison & Video
We have a 46 inch sharp tv model number 46SB54U won't turn on. The green timer light is flashing. We just replaced the power supply board thinking that was the problem. TV still won't turn on...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will helpout ......
Jun 25, 2011 | Sharp LC46SB54U 46 in. LCD TV
The red light keeps blinking and tv won't turn the fan won't come on either
I hope this will help out in solving the problem....
Jun 19, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
My Kenmark 19" tv won't
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem, do take in handling the fault, because it contains high voltage..
Good luck
Jun 07, 2011 | Televison & Video
I am able to get in with the 5898 code to unlock the tv, it won't let me put in a new code and I still can't watch r rated movies? and when I get in to the dvd side of things it only want's 3...
Hello
Just unlock it following any one of the methods described below. Then reset it as your desire. One amoung the following methods will surely unlock your RCA and give you option to do others.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won
May 17, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Deva
Apr 21, 2011 | RCA 20F420T 20" TV
Mitsubishi WS-65413 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
