Question about Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA)
Connection refused after configuring IP address?
I'm having headaches with a Linksys SPA-2102 I'm dinking around with. I got it configured with a static IP address, a gateway address, and a subnet mask, and I get a reply when I ping it, but every time I try to access the configuration page on the web to give it the display name, user name, etc I keep getting the "Connection refused when attempting to contact 10.10.*.*" - what might be causing this? I'm following the exact same procedure I used for setting up some older PAP2T adaptors, which work fine. I've tried rebooting and unplugging the adaptor, but that doesn't work either. Any suggestions?
I dont hear a dial tone?
Posted on May 02, 2008
How to configure it
You need to connect it with your router using ethernet cable then check which IP is assigned with router and then type that IP in your browser address bar to enter into your device setup. Once entered into setup then follow the on screen instructions.
Mar 05, 2012 | Linksys SPA-2102 NA Analog VoIP Adapter...
I could not configure Linksys PAP2T. I am getting IP address 0.0.0.0 so plz advice me
To be honest, your best option is to call their toll free support. Its free, and 24/7!
They will walk you right through everything step by step!
heres the number 1-800-326-7114
Feb 23, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
My linksys spa2101 is locked, i dont have the password, what can i do
If you forgot your user and password of router then press RESET button of router for 10 seconds it is in back side of router. Then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . If you forgott WEP password in wireless security note down the WEP code it is your password to connect wifi.Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Sep 06, 2010 | Linksys SPA-2102 NA Analog VoIP Adapter...
Linksys SPA 2102
To reset your SPA device to the factory default values, follow the steps below:
1. Disconnect the Ethernet cable
2. Access the voice menu (****) and press 73738#.
3. Login with the username "user" when accessing to http://spa-ip-address OR
login with "admin" when accessing http://spa-ip-address/admin/.
NOTE: Resetting your unit will erase all the configuration settings. If your SPA device was provisioned by a service provider, the reset function might be password protected. Contact your service provider.
Apr 21, 2010 | Linksys SPA2102 Router
LINKSYS SPA-2102 CAN NOT FACTORY RESET, PASSWORD REQUIRED!!
You need to:
1) figure out where it's going for config file updates (e.g. http://ip address/path/filename (wireshark highly recommended for this)
2) once you have the filename, you need to find a "broken" copy of that CFG file. You may be able to use the broken sunrocket one (google linksys2102-sunrocket.cfg)
3) setup a webserver to it appears to be at the ip address above (there are a number of ways to do this - google sunrocket 2102 for some step-by-step instructions.
4) reboot the SAP with the DTMF codes
That all seem like too much? Then go to broadband reports.com and PM DogFace05 - he can remotely unlock your 2102, but there's a fee.
Jun 09, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
We have Linksys G wireless router for our 2 home pc's and would like to get our laptop also connected - please help..
- Let me know what is the configuration of your wireless?
- If your configuration have no IP address included to access your Wireless connection?
- You need to obtain the Network IP configuration for automatically connection the Wireless Point.
- Let me know The Operating System of your Laptop?
- The same Procedure if your Settings Wireless Connection or IP Address needed.
- If you are using Windows XP Please Follow the Instruction.
1. Select [START] =>
2. SETTINGS=>
3. NETWORK CONNECTION=>
4. Select your Wireless Connection if you have or your local Area Network then PROPERTIES.
5. On GENERAL = Use Scroll down Under: This connection use the following items Select Internet Protocol {TCP/IP) then Click Properties.
6. Select Obtain for automatically connection or add IP address if needed then apply.
Sep 23, 2008 | Linksys Wireless-G WRT54G Router
LinkSys SPA 2102
try this out
power on your linksys
then pick up the phone connected to that linksys
no dile tone required
dial ****
when it says configuration menu
type 73738#
if ask for password then nothing can help you buddy
and if it says press 1 to save then press 1 and your device is reset with factory default
Feb 05, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
Password of linksys spa 2102
The Linksys comes with web admin access disabled.
To enable it, pick up phone, dial **** then 723646# , when asked for password, dial 78778839# , when asked for value dial 1# then dial 1 to save.
Then, go to »192.168.0.1/admin/voice/advanced , enter user and password.
If you did a factory reset, you will need to call Linksys technical support.
Nov 09, 2007 | Linksys SPA-2102 NA Analog VoIP Adapter...
Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA) Logo
432 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
