Question about Krups XP4030 Espresso Machine
Krups XP4000 starts in 0 position too
Krups XP4000 turned on with power switch: not only the heating starts, but immediately the pump too, even with the turn switch in 0 position.
Normally only the heating should start, and I should be able to start the pump by turning the switch arm to the right after the heating LED goes off. So now I can make cold coffee with it.
Do you have a wiring diagram for that? Can it be the switch or is there a relais on the power module for the pump?
  • 4 Answers
SOURCE: krups 453 coffee maker - won't to brew/heat
I just had the same failure, but fortunately, had already bought a used 10-cup unit a few months back as a spare.
The component in question is a thermal circuit breaker, of the sort which does not reset. Once activated, it is destroyed,
I have been unsuccessful locating the same component on the internet, but it seems to be a very high temperature unit, with the nomenclature "Tf 318 C" which because of the lower case "f", leads me to conclude that it's designed to trip at 318 degrees, C, or a very healthy 604 degrees, F.
Similar fuses in other appliances range around 230 degrees C (446 degrees F),  which is in the ballpark.
The failure is easy to verify.  If blown, there will be powdery white residue on the inside of the bottom plastic cover near the part.  Also, an ohmeter will show an open circuit across the contacts.  (Unplug the unit before measuring!)
Screws to remove the bottom cover are three tamper resistant torx screws.
If I am unable to find an exact replacement, I will use a thermal fuse in the same power and temperature range (10 Amps, 300 degrees C trip).
Because my unit unequivocably did not experience over temperature conditions, I suspect this is a component aging issue and that there is no other problem with the coffee maker.
Supporting this is the fact that the unit works fine after I moved the good part from my spare coffeemaker to the dead one.
Posted on Apr 13, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: hi, I need a 'joint
The part for your XP4000 is the brew head seal. A Google search turned them up here:
http://www.smallappliance.com/product.asp?cur=USD&cam=krups_parts&sid=18954&gid=18960&mid=15&pid=2870&prdCls=P&shopBy=Brand
This page is their Krups model list:
http://www.smallappliance.com/department.asp?cur=USD&cam=krups_parts&sid=18954&gid=18960&mid=15&shopBy=Brand
It doesn't show the XP962 but it gives their phone number and says to call if you don't see what you need. So maybe they can help.
In general, when you want to search for something on the Internet, start with a good search engine (I use Google but there are others of course) and give a search string like "krupps kp40000 parts". Then you can check out the links it gives you until you find what you need.
Posted on Nov 22, 2008
SOURCE: red blinking light on krups coffee maker
It means your water filter needs to be replaced. I wouldn't know this either as I found my coffee maker in a thrift shop, but I read it on Epinions a few minutes ago in a review.
Have you had any problems with splashing when brewing - some of the water missing the spout? I lose up to a cup of water and I'm stumped. The goldtone filter has to be pushed to go down into the unit, does this mean I'm putting it too far in and screwing up the stop n pour or something?
Posted on Jan 15, 2009
SOURCE: Krups Coffee pot stopped brewing after programming
OH Yeah!
That is the number one failure in these machines. (owned four of them)
The problem is one or both of the "twin" thermal fuses or the thermostat for water
heating and hotplate,( one in the same) has gone open. I have tried for a long time to locate correct replacement parts to no avail. I would STRONGLY not recommend trying to bypass as these are not only controls but a safety feature as well. I was lucky a wile back and found one without a carafe at a garage sale. used it for parts, now those have failed also. Really miss them. If I ever find a source for parts I will post it here with replacement procedure.
EfACTOR
Posted on Jun 13, 2009
  • 4090 Answers
SOURCE: my Krups coffee maker is leaking some coffee onto the counter
no normal fix it requires worshop inetervention to replace the seal
Posted on Jul 31, 2009
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
Fisher and Paykel Washer GW 609 when switched on at wall keeps pumping
The best bet is to have an authorized serviceman test the control board for continuity. It is out of phase and cannot reset to the normal start position.
Feb 27, 2014 | Fisher and Paykel Washing Machines
Need directions on how to use Krups XP4000
You may download a copy of the manual from Krups here.
Jun 14, 2012 | Krups XP 4000 Espresso Machine
Krups Novo 2000 ~ water isn't flowing. I bought this used at a yard sale, and I must say it looks as tho it was hardly used at all. Today I plugged it in, turned the power switch to on until the temp...
If the pump is bone dry sometimes they refuse to pump. In the past I have found some soft tubing that will fit over the water inlet where the tank plugs in. I then fill the tube with water and pressurise it with my mouth while operating the pump. Often this is enough to prime the pump and start it pumping. The downside with a machine that old will probably be lack of new group head seals, you will probably find they are obsolete.
Apr 27, 2017 | Krups Espresso Novo 2000
Krups nespresso not heating water
That is a faulty thermostat or a defective control board.
Contact Krups and have the machine replaced.
Contact - Krups International
Feb 17, 2009 | Coffee Makers & Espresso Machines
Hi, I need a 'joint seal' for my Krups XP4000 expresso maker, and ideally also one for my old Krups XP 962 expresso maker. I got them in France where they are called 'joint porte filtres' ref cde MS 620342...
Nov 22, 2008 | Krups Small Appliances Espresso Machine
Krups XP4000 Pump Espresso Machine. It comes on and gets incredibly hot but no water ever comes through. It shakes a lot, makes a really loud noise when turned on. The tank is full and pushed in as far as...
If it is brand new you should not be expected to figure it out, take it back to the shop. Any messing about with a brand new appliance can only harm your guarantee, let them figure it out. It sounds like the pump valves are dry or stuck.
Feb 28, 2017 | Krups XP4030 Espresso Machine
Krups XP4030 Espresso Machine Logo
119 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
