Question about Ricoh Aficio AP3800C Laser Printer
Smearned Printing on Ricoh Aficio AP3800C Laser Printer
Hi, I work for a non-profit here in Tucson Arizona and we were recently donated a Ricoh ap3800c color laser printer. The printer worked fine for a while(1 month) but then it started giving a add black toner error even though the toner was full.
This was problem was resolved by cleaning the insides of the machine with compressed air. However after another week of use the machine suddenly started printing smeared pages and it no longer printed in black. The only colors that showed on a page were cyan, magenta and yellow.
After contacting ricoh tech support they said we needed to replace the black development unit, and so we did. Unfortunately this did not solve the problem.
Just to recap here are the main problems.
1. Pages print smeared
2. It doesn't print the color black.
Sidenote: The machine occasionally gives an SC error(261 or 380 I'm not sure ). This is resolved by restarting the printer.
P.S I attached a picture of the test page to show the smearing and the lack of black.
Any help would be greatly appreciated!
  • 417 Answers
Hi there the smudges are most likely down to the black PCU (Drum Unit) and following are the reasons for the two fault caode you have given me.
SC 261 LD HP sensor
not switched
off (for K only)
After the laser beam pitch was
changed, it takes more than
five seconds for the HP sensor
to switch off.
• Defective motor
• Defective sensor
• Mechanical problem
when switching the
actuator
• Brown fuse (FU81) on
the Power supply unit
1. Turn the main switch off and on.
2. Check the sensor actuator position of
the LD positioning motor.
3. Replace the LD positioning motor.
4. Replace the LD home position
sensor.
5. Check and/or replace the PSU.
SC 380 Black
development
motor error
SC 381 Color
development
motor error
When the motor speed is
within the target level, the
motor sends a lock signal
(High to Low at CN214-5) to
the BCU.
SC380 is detected under the
following conditions:
• The Lock signal stays High
2 seconds after the motor
turns on.
• The Lock signal stays Low 2
turns off.
for more than 2 seconds
while the motor is on.
• Defective motor
• Defective BCU
2. Replace the motor.
3. Replace the BCU.
Hope this is any help
Thanks J
Posted on Feb 21, 2008
Hi I Have a message saying colour pcu type A Flashing ? Ricoh Aficio AP3800c What do i need Thanks
This message indicates that the colour drum(s) (called pcus) have reached near the end of their counter life. If the output is still ok you can safely ignore the message for now. If the machine stops working, then you'll either have to replace them (expensive) or if the quality is still ok, then reset them. Take a look here.
Aug 04, 2011 | Ricoh Aficio AP3800C Laser Printer
What type or printer cable will i need to connect my RICOH Aficio AP3800C to my laptop USB port
usb cable.... u r trying to connect it to the usb port of ur computer... so obviously u need a usb cable
Mar 16, 2011 | Ricoh Aficio AP3800C DT1 Laser Printer
I am working with Leopard Mac OS X 10.5.8 and cannot find a printer driver for my RICOH Aficio 3800C. Please can you tell me where I can find it and how to install it.
You can get the AP3800C Mac driver directly from Ricoh here:
http://ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/p3800c/p3800cen.htm
If this link doesn't work, follow these steps:
- Go to Ricoh-USA.com
- Click Downloads on the blue bar along the top
- Click "Download Ricoh Drivers & Software"
- Select the AP3800C from the drop-down list under Printers, B&W/Color/Gel and then click Go
- Choose your operating system from the list
- Download the two files listed under Mac OS X 10.5
Once the files are downloaded, you should be able to install the print driver normally.
Hope that helps!
May 28, 2010 | Ricoh Aficio AP3800C Laser Printer
Printer does not load toner
the toner tube could be clogged -big and messy job
Jan 07, 2010 | Ricoh Aficio AP3800C Laser Printer
Ricoh 3800 printing dots on the page
sounds to me like there is damage to the charge roller in the black pcu. these can be dissasembled and the charge roller inspected/cleaned but the blk drum units are inexpensive enough its probally just better to replace it
Oct 31, 2009 | Ricoh Aficio AP3800C Laser Printer
Wont print 2 colors, only black and white
The print driver might be defaulted to black and white. Change it to color.
May 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio AP3800C Printing Problem
If the marks are along the same line and look like dots the black photoconductor needs to be repalced.
Jan 21, 2009 | Ricoh Aficio AP3800C Laser Printer
Nor printing magenta
If there is toner in the cart but not getting onto the page, the most likely cause is that the toner delivery tube is blocked. You can try removing the unit and vacuuming out the supply line to remove any lumps that may be lodged and then run the forced toner supply in the Service Mode.
Sep 14, 2008 | Ricoh Aficio AP3800C Laser Printer
Black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
Feb 26, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio AP3800C Laser Printer Logo
528 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
