Question about Acer Aspire RC900 (91.PJB6P.UE7) PC Desktop
How to Open a case - Acer Aspire RC900 (91.PJB6P.UE7) PC Desktop
  • Acer Master
  • 5,660 Answers
Acer Aspire RC900?
1) Computer off, unplug the power cable from the surge protector. Now unplug it from the computer (Power Supply)
(Unplugging the power cord from the back of the computer, while still plugged into the surge protector, may cause a voltage spike.
This could result in frying out the Power Supply, and may also fry out the Motherboard, Processor, Ram Memory, and Graphics)
2) Viewing the Acer Aspire RC900 from the Front, the Left side panel, is the panel that removes.
3) Viewing the Acer Aspire RC900 from the rear, look at the right side. (Left side actually, but now the computer is turned around)
There is a Cover Release Latch that is close to the outside edge, and towards the top.
It is whitish in color, and approximately 1-1/2 finger digits long, and half a finger digit wide.
(Universal measurement I figure. Using the Inch system it is approximately 1-1/2 inches long, and 1/2 inch wide)
Pull this Cover Release Latch to the right. (Towards the bottom of the computer if it were standing up)
You will see that this side cover, has a formed shape that you can put your fingers in, to pull the side cover towards the rear of the computer.
Pull the side cover back towards the rear of the computer to remove it.
Advise:
Your body carries Static electricity,
Static can fry out (Short Circuit) the hardware components inside a computer.
Touch the metal frame of the open computer case BEFORE you reach inside, to relieve your body of Static.
(Not shouting)
If you get up, walk away, then return, Touch the metal frame again.
Computer unplugged from power, you are safe.
Touch the metal frame of the open computer case, your computer is safe.
Have any more questions concerning this, I'm right here. Please post in a Comment.
Regards, joecoolvette.
Posted on Feb 07, 2010
  • joecoolvette
    joecoolvette Feb 13, 2010
    This is the Acer FTP server website, and the User Manual download page for the Acer Aspire RC500 and RC900 series Desktop PC's,
    http://support.acer-euro.com/drivers/ftp...
    On this page left-click on - desktop (Fifth one down in the list)
    Now scroll the page down, and left-click on - aspire_rc500
    On the next page left-click on - manual
    Lastly left-click on - aspire_rc500.pdf at the bottom of the list.
    After you click, a split second later another file name shows up. DO NOT click on it. The PDF file you clicked on, is downloading in the background. This file will show up in a few seconds.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 28 Answers
What type of case???
common cases are needed to open in the back of the cpu...
you need screw driver or philips to unscrew it...
then you only need to pull up the sides covers of your cpu.. and it is open already..
How to open the case of a dell optiplex 760
Retail computer manufacturer cases can be troublesome to figure out how to open. Generally, there are two screws on the rear of the left side (facing the computer) that you remove, and then the case side slides off. There may be snaps that you must press open in addition to this (or not!). Some old cases have hinges that open the case like a door, newer cases usually do not have this. For more free in-depth help go to www.suggest-a-fix.com
which is a free computer help forum that I belong to. Post in the Hardware section and I (or someone else) will be along. This forum is not set up for complicated problems that require detailed, in-depth communications.
Jul 29, 2014 | Dell OptiPlex 760 PC Desktop
How to open case?
under the decals on ether side are four screws remove these and
separate the sides under these you will find white wedges that hold the case halfs together pull out these wedges and open the case. repair unit and Reverse the prosess to reassemble the unit. If you know how to work on electronics you may need to replace the electrolitic capacitors while the case is open. Kill 2 birds with one stone.
Oct 27, 2012 | Namco Arcade Classics Plug and Play TV...
I cannot open the case
You open the case by laying it on its side, pressing two buttons, and folding it open like a book.We found it awkward to simultaneously press two large release buttons and lift the case open, and we encountered some uncomfortable resistance in swinging it all the way open.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jun 11, 2010 | Dell Dimension 8200 PC Desktop
Need to open the case of a Mactor OneTouch III to
well i dont think we will be able to open the case of the hard drive commonly because a hard drive is the safe casing of the very expensive metal disc which is used to store the data on to it and it is done by using magnetic energy so normaly a hard drive cannot be dismantled by the user but may be the drive manufacturer can do this only in the extreme needs.
Good Luck.
Jan 07, 2010 | Computers & Internet
Can not open case to install 2.5
The wheel probably is an OFF/ON switch.
Take a closer look for small screws. If you see none, then what you probably have is a "press-fit" case -- like the lid on a bottle of ketchup -- that takes some pressure to force the case to open.
If you just recently bought the case, take it back to the store that sold it to you, and get them to demonstrate how to open the case.
Dec 29, 2009 | Computers & Internet
Open case
Here is the Gateway download site to obtain your manual which should show you how to open the case.
http://support.gateway.com/support/drivers/search.asp?param=gateway+500+SE+&x=12&y=10&st=kw
Dec 19, 2008 | Computers & Internet
Acer Aspire RC900 (91.PJB6P.UE7) PC Desktop Logo
492 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
