Question about Microsoft Xbox 360 Console
My xbox 360 colors are all messed up for example the color red looks brown and the color pink looks white PLEASE HELP ME!
  • 767 Answers
This sound like intermittent connections form the G.P.U.
color feed data lines to the ANA/HANA (video chip driver)
This is normally accompanied by poor resolution ,dots , lines,
and finely 3 red lights
You have 2 viable options
1 Have a shop re-flow the G.P.U. and then properly clamp
it to the P.C. board .Cost will very 60.00-80.00.
and ask for their track record and if they replace with
the x clamp with screws and washers take your console
else where . The xclamp must be replaced with supporting
hardware. screws alone will flex and damage the P.C. board
2 do a conservative x clamp mod this will get your console
working but this type of repair normally last 2-5 months
3 And there always Microsoft but there repair service is sub-par for the price
if you have any questions feel free to ask
Rob
Posted on Feb 07, 2010
Wire color abbreviations Isuzu Rodeo
P - Pink
LB - Light Blue
V - Violet
GR - Grey
LG - Light Green
BR - Brown
L - Blue
Y - Yellow
O - Orange
G - Green
R - Red
W - White
B - Black
Some wires will be allocated 2 colors ie B/W. This is a color with a different color line running along its length.
The first denotes the main color (Black in our example) and the second denotes the tracer line (White in our example)
Sep 09, 2010 | 1992 Isuzu Rodeo
CONNECTING XBOX 360 TO A LCD PANASONIC VIERA TV
You need to Connect via, the Component Video, the xables are Blue, Red, Green, ALL Video, and go color to color, from, Xbox to TV, and you Select EXTERNAL INPUT, on TV. OR You must use the Composite, Video, which is Yellow, for Video, again, cables go color to color. The Audio, as you have discovered, is Red & White. Now, if using HDMI, you do not usually need the Red 7 White audio, as it's all in the one signal, though the HDMI. Again, you select the relevant, INPUT On the TV, And also select the output on the Xbox, and you should be all OK.
Apr 30, 2010 | Microsoft Xbox 360 Console
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
THE WIRING ON THE FAN CLUTCH GOT CUT AND THE WIRES FROM THE TRUCK ARE YL/RD,BLK/RD,GREEN/GRAY,RD/GREY,GREEN THE WIRES FROM THE CLUTCH ARE RD,GREEN,WHITE,ORANGE,BLACK. TRYING TO BE SURE BEFORE I CONNECT...
1) ECM Fan Clutch 1) K160 18BR/OR Park Lockout Solenoid Control Green
1) BR / OR = Brown/Orange unit with Green
2) K900 18DB/DG Sensor Ground 2) Black
2) DB / DG = Dark Blue/Grak Green unit with Black
3) K161 18BR/LB Fan Speed Sensor White
3) BR / LB = Brown/Light Blue unit with White
4) Not Used
4) Not Used
5) F856 18YL/PK 5 Volt Supply Orange
5) YL/PK = Yellow/Pink unit with Orange
6) F504 20GY/PK Fused Ig. Sw. Output Red
6) GY/PK = Gray/Pink unit with Red
With this, you have 5 due color cables unit to the 5 full color cables. Run.
Good luck, and rated this help (and us chat).
Aug 27, 2009 | 2004 Dodge Ram 3500 Truck
Need color code diagram for sterio
I'm not sure what year you have but this color code works for 87-93 mustangs.
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Hope this helps.
Jun 19, 2009 | Ford Escort Cars & Trucks
Trying to wire in a new stereo into nissan largo, found power but cant find speakers. is there an in line amp that i need to power up to make speakers work?
This might help.
Wire colors in your car might be different than colors described here. Use the given colors for reference purposes only. Always test wires to make sure they are correct.
NISSAN P o w e r Memory (+12v Constant) Red Ignition (+12v Switched) (varies) Brown or Green Ground (-) Black (varies - most don't have one) Illumination Red/White Dimmer Red/Black Power Antenna Green S p e a k e r s Right Front (+) Brown Right Front (-) Brown/White Left Front (+) Black Left Front (-) Black/White Right Rear (+) Blue Right Rear (-) Pink Left Rear (+) Red Left Rear (-) Green
Mar 28, 2009 | Car Audio & Video
Best setup for Xbox 360 for Sony 32" Tube WEGA tv
Hi, Not sure whether you are kidding or not. You don't mention the tv model so I will try to help using a KV-32FS100 as an example. You really only have 2 choices assuming you have a current model xbox 360. The component cable that comes with the xbox has 6 connectors, a green, blue, red, yellow on one part and a white and red on the other part. On the back of the tv below and to the right of the s video connector are inputs labeled Y, Pb and Pr and are colored Y is green Pb is Blue and Pr is red if they aren't colored that is the correct order. Don't connect the yellow to anything. The red and white on the other part of the cable go directly to the right of these connections. It will say audio and L and R they should also be colored but if not white is L and red is R. There is also a small switch at the xbox end of the cablewhich you need to slide to HDTV. Once you are powered up don't forget to enter the setup menu on the xbox and select the settings for your tv. Again without knowing the model most wega tvs limit the component input to 480p which was the limit of a dvd. I hope this is helps.
Jan 28, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
Serious Color Printer Issues
This is to do with the way in which the cyan, magenta, yellow and black ink is mixed to produce all the colours e.g. to print "red" requires both magenta and yellow ink. Thus, if the magenta ink is not flowing for some reason, for example, the "red" will print out as yellow. So, make sure all your cartridges and nozzles are working properly.
If you need further help with this, please post a new comment to this effect.
Oct 18, 2008 | Epson Stylus C62 InkJet Printer
Problem With Xbox 360 Color Depth
Wow i have no idea what to do with my Xbox #360 Elite. I was playing halo3 and my screen started acting up, and the colors on the tv were flashing.. red pink green and blue.. but i could still play.. so i shut it down then turned it on and had no picture
Jun 09, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
780 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
