Question about Stoves 720EF Electric Double Oven
How do i replace the bulbs inside the ovens - Stoves 720EF Electric Double Oven
  • 250 Answers
The lenses have to be removed to gain access to the bulbs. If you look carefully at the lense, the edge immediately in front of you will have a small lip that you can get a screwdriver blade under. do so and twist the blade carefully and the lense should just spring clear. Note that the lenses have cut outs on them to ensure clearance on the bulb, so replace them round the right way.
Oven bulbs are all the same quality, so as long as you buy an oven bulb and it is the same physical size and fitting (BC or SES), you should be ok.
Posted on Mar 02, 2010
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
Both oven lights out
Are you buying hi quality oven grade lamps for this purpose that'll take the intense heat inside an oven? I wonder if they're halogen or tungsten filament lamps. Defective solder, frosty joints and/or ring fractures on lamp driving areas of a circuit board ARE indeed capable of causing problems with lamps.
Mar 16, 2014 | Dacor MCS130 Millennia Electric Single...
Have a bulb broken off inside socket in gas oven..cannot remove..need help
power down at the breaker or unplug the oven,then if possible you can remove the lamp cover and shell from the rear oven wall,then most lamp bases have spade terminal connections unplug these remove the whole lamp base with the broken lamp,remove the broken bulb base,then check the center power tab inside the lamp base to make sure it isn't flattened out too much,otherwise carefully bend it upwards to make sure it makes contact with the bulbs base then re-insert the terminal connections and new bulb into the opening at the rear of oven,then replace the bulb,but,do not over tighten new bulb as this leads to non operation due to heating
Jan 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Replacing oven bulb
what type of oven isthis and model , can you get to the bulb, is it broken inside the socket ?
Dec 06, 2011 | Ovens
How do i change the light bulb in a Zanussi oven ?
Turn off at the wall and remove the light cover inside the oven by turning anticlockwise, this may be stiff, I use a well wrung out dishcloth.
You can see the bulb, which should be screwed out of its holder with care, also care when replacing. a I screwed mine in too hard and snapped the holder, but my oven is 5 years old.
Hope that helps
Jan 01, 2011 | Zanussi ZBF360 Electric Single Oven
My oven light does not work at all, how to replace
reach inside and unscrew the old bulb and screw in a new 1
Nov 09, 2009 | Ovens
Replace oven light
If the metal sleeve that the bulb screws into is damaged, you can go to a local appliance repair shop for a replacement. Be sure to unplug the stove before doing any work on it. you will need the make and model of your oven to make sure you get the right part.
In the future, if the bulb detachs from the base on any light you have, 1) disconnect the power, 2) using a small wooden dowel or the plastic handle of a screwdriver that will fit inside the base, apply enough pressure while turning to remove the base. Good Luck.
Aug 06, 2009 | Ovens
Burned out bulb
you may have to rmove it from the back part of the oven. there should be access screws to allow you to change the bulb from the back
Dec 07, 2008 | Kenmore 47783 Electric Single Oven
Change oven thermostat
Not familiar with the brand - but there are two types of temperature sensors - i am assuming here that the person meant temperature sensor rather that a thermostat.
1 bulb type sensor
2 rtd type sensor (metal looking tube usually installed at back)
If its the bulb sensor - then there is a long tube from the bulb to the main dial on the front panel. All of this must be removed to change it. (power turned off) The knob on the dial removed and the front panel removed and the screws removed and the bulb threaded through - reverse to installed.
If its the rtd - then they are usually secured with two screws inside the oven (look inside to see) loosen those then pull the unit towards you the connecting wires should come through there should be a quick connector - (if under counter type) remove the old sensor and connect new one. Thread the wires back through the hole and secure the new sensor with screws - if the screws were damaged replace with only stainless screws
Aug 22, 2008 | Zanussi ZDQ895 Electric Double Oven
Oven light bulb
Check your email
Jun 15, 2008 | Ovens
Stoves 720EF Electric Double Oven Logo
101 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
