Question about Garden
Hello the last info. was very helpful however I'm still having a problem starting my snow thrower. I'm getting good spark, in fact it will turn over and run for a second after I give it a shot of starting fluid. I changed the old fuel and check to see if the line was clear. It's 5 hp Tecumseh Snow King engine. It's starving for fuel...do you have any suggestions. We just got 26" of snow last night and I'm desperate to get out there and start clearing it away. Thanks for your help. Paul Maugeri
2 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: Hello the last info. was
You need carburetor Kit and this will fix your problem.Anytime motor runs fuel out it will be carburetor
Posted on Feb 13, 2010
Electric start on craftsman 9 hp snow thrower won't start engine it sound like it's turning but engine won't start. I can start engine with the pull rope. Started last week with the electric start.
Sounds like you need to replace the gear drive on the starter. If the starter turns but the engine is not turning you have starter problems.
Jan 22, 2015 | Garden
Carberater for my snow thrower isn't getting gas
The carburetor could be clogged. Try spraying some carb cleaner into the engine to see if it starts. If it does, then some part of the carb may have varnish clogging some of the ports.
Jan 30, 2014 | Craftsman 24" 208cc Dual-Stage Snow...
Carb adjustment and what is the correct spark plug
If the snow thrower worked last year I would suspect old fuel in the tank. Dump out the old fuel in the tank and put in fresh. Put a squirt of starting fluid in the carb and try to start it. If it fires the ignition is good. Do this a few times to pull the old fuel through the carb and fuel line. When the new fuel gets through the fuel system to the engine it will stay running. The spark plug in the engine will have number on it. Get one with the same number if you want to replace it.
Dec 10, 2013 | Craftsman Sears Snow Thrower Manual Model...
Toro snowthrower 38180 won't start
You have probably fouled the spark plug (got a heap of black carbon on it) remove the spark plug wash in some petrol then use a wire brush vigorously brush between the contact points on the plug then reinstall. & lastly don't forget to push in the choke when you get it fired up next time.??
Mar 14, 2017 | Garden
My MTD 10hp auger will not turn. I adjusted the auger cable by tightening the bolt on the handle. I disconnected the spark plug and checked the shear pins on both sides of the auger. They are both still...
Yes there are 2 belts one for the drive and one for the auger. If you remove the cover on top that is located between the engine and the auger housing you can check the belts. The auger belt has come off the pulley or is broken. Hope this helps you out. Best regards and good luck.
Jan 08, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
I have a craftman snow thrower, model#536.886122, serial#632722946 and I'm in need of a manuel.
Manuals of Sears products are available through their 'Parts Direct' system and have been resonable in price. The last one for a riding mower cost ~$7.00
Sep 21, 2009 | Tools & Hardware - Others
My snow thrower wont start
Change the spark plug being sure to set the spark plug gap as recommended in the owner's manual. Then clean or change the air filter. Finally use new high test gasoline. good luck.
Jan 12, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
Jan 11, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
