Question about Dishwashers
I just installed a new Frigidaire dishwasher. Took it through 1 cycle as the directions indicate looking for leaks. I now have it full of dishes for its maiden voyage, and I get an Er uo code. Cannot find this error code anywhere. Can someone help me. M# FGHD2433KW Jamie
  • 1,531 Answers
This is a vent problem you need to check the vent motor and make sure tha the wire have not been pinched by the door spring and make sure it is connected properly.the vent should be located on the top or possibly the right side of the cabinet.
Posted on Feb 07, 2010
Dishes not cleaning after full cycle running
Your screens are plugged with food residue in the bottom of the unit. clean it out. You can use 1 gallon of white vinegar for your wash after you clean the screens. Start your washer to fill with water but after the water starts, open your door and pore all of the gallon in the unit. Let it now run for 4 minutes and stop it by opening the door. Leave the door slightly open for 1 hour. close the door and let the cycle continue for 4 more minutes. open the door and repeat it a couple of more times. Let it sit all night with the vinegar in it and in the morning - close the door and let the cycle continue to the end. This should help soften and clean out the food particles in the unit. You can repeat the process and get a better cleaning then too. All the scale should be off your dishes now.
Jan 08, 2014 | Frigidaire Professional Series 24 in....
My new Frigidaire Profesional Series dishwasher is not cleaning my dishes and the rinse aid leaks. I am finding residue still on my dishes at the end of the cycle.
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if the heating element goesbad then that also can mess things up bad... So I would buy new spray arms, and also check out theheating element to make sure it is working... Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 20, 2010 | Frigidaire Professional Series 24 in....
No water going into dishwasher checked supply line its good Frigidaire model fdb635rfr6
Just had a similar problem with my Frigidaire FDB834RFS0 model. Dishes were not getting clean. Noticed some detergent still remaining in the dispenser after completing a wash cycle. Checked the water level during several cycles and noticed it was barely visible in the bottom of the tub. Decided to remove the water supply valve and solenoid to check it, thinking I would probably have to buy another one. Took it apart and found there is a mesh water strainer on the inlet side that was full of bits of junk. Cleaned it out and decided to reinstall to see if it made a difference. Noticed immediately when starting the next cycle that I could hear the water gushing into the tub. The water level rose significantly and the result was clean dishes and no left over detergent in the dispenser.
Jul 31, 2010 | Frigidaire Dishwashers
Dishes are not getting dry with my new dishwaser
sounds as though the element is bad, verify this with a Volt/ohm meter
Jun 29, 2010 | Frigidaire 24 in. FDB635RF Built-in...
My diswasher is leaving a grimy film on all the dishes after they are run through the cycle, I'm wondering if it is because the dishwasher itself needs a cleaning and if so how do I clean it its a...
Go to you local Supermarket and purcase a bottle of disjwasher cleaner is about 8 bucks a bottle in some cases you may need to use two bottles I would buy 2 but use just one if it works save the other one for a future occasion.Follow all directions on bottle..Make sure you use it in an empty dishwasher and turn hot water tap on closest to dishawsher to make sure it is filling with hot water...You will be quite surprised at how clean your first load of dishes will look after the cleaning
Jan 23, 2010 | Frigidaire Precision Select 24" Tall Tub...
Hi, my Frigidaire dishwasher doesn't seem to clean
Factory Defect, where I was given full refund plus re-installation costs from Lowes...
Oct 04, 2009 | Frigidaire Dishwashers
Water flow
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
chkq356
Nov 01, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Kenmore dishwasher has never cleaned dishes
make sure you are getting plenty of water. Start the D/W without putting soap in disp. run for about 1 minute, Make sure there are no suds inside. If there is, run full cycle to get excessive amount of soap out. If no suds check in pump resevoir to make sure its not clogged.
Jan 05, 2008 | Dishwashers
Dishwasher will fill and drain, but will not cycle!
Bobalou If you just bought and installed, I'm assuming you dish washer is brand new. It means it has full warranty with Maytag. Do not do anything. It will void your warranty. Call Maytag authorized service. Gendos...post back
Jan 23, 2007 | Maytag 24 in. MDBH750AWS Stainless Steel...
Dishwashers Logo
228 people viewed this question
Top Dishwashers Experts
