Question about Bosch & Tankless LP Hot Water Heater
Cannot get hot water
New home, just moved in today. Cannot get Bosch hot water system to produce hot water. Everything seems to be plugged in and switched on, gas tanks are full and on. Am I missing something?
  • chefgirl2002 Feb 07, 2010
    Thanks, I'll give this a try....model is 17E
  • 574 Answers
Make sure breaker is turned on. If that isn't it tell me model number and maybe I can help you more
Posted on Feb 07, 2010
How do i know if the control unit is bad on an aquastar 1600H
That voltage does not seem high enough. Supposed to be 1.6 VAC and I got 2.5 VAC. Do you have the water flow turned to the maximum? Is there something blocking water flow? The hydro voltage should be checked separetly from everything else, so if you can't get the VAC higher, my guess would be that's the problem.
Nov 19, 2014 | Bosch 1600H-NG Natural Gas AquaStar...
Worcester Boiler Greenstar 15Ri - The blue neon light is flashing - what does this mean?
http://www.worcester-bosch.co.uk/homeowner/literature/gas-boiler-literature/greenstar-15ri-literature. Hope this helps :)
Sep 19, 2014 | Water Heaters
The thermal cutout pops on tank two after it shuts off. It boils then shuts off. It also turns off when taking a shower, producing cold water. I checked the ohm readings on the thermal cutout and the...
Question posted under Bosch tankless.
Question says 'tank'
Brand, model, and type heater unknown.
Elements mean electric.
'Thermal cutout pops when taking shower produces cold water' indicates tankless, since tank-type would maintain some hot water.
No error code might indicate tank-type.
Add a comment with type, brand and model number of heater for possible assistance.
Sep 24, 2012 | Bosch PowerStar AE125 AE125 Whole House...
We have a Bosh GWH2400ENG Tankless Water Heater. I cannot seem to get the unit to produce any hot water at all or if I can get it to start to produce hot water it does for mabey a minute and then shuts...
Look for the error code on heater. Go to: http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ETechSupport/Troubleshooting/tabid/1131/Default.aspx
For technical support on your heater.
Apr 23, 2011 | Bosch AquaStar 2400ES-NG
Recently purchassed system from you plumber installed it and we asked specifically not to set it on child settings.....we have not had one HOT shower since. how do we go about resetting the hot water...
These Tankless water heaters attempt to heat water as it quickly travels through a short series of heated copper pipes. A high volume of water at an accelerated speed has little time to heat up as it passes through its heating source. You can turn up the temperature (which you undoubtably tried) and turn the water volume all the way down. These settings will produce the hottest temperature capable of the unit - given the entry temperature of your water source.
Most underground water enters at app 52 degrees - and becomes even colder due to ambient temperatures. Difficult to raise this temperature 60-70 degrees in a few seconds of heating.
I've routed a series of copper pipes adjesent to the home heating system in an attempt to pre-heat incomming water. It's only a few degrees warmer, but results a 20- 30 degree hotter delivery.
I have installed some top end units that simply delivers Hot water without compermise.
Mar 01, 2011 | Bosch & Tankless LP Hot Water Heater
I have model no. 45-550301 and it produces hot water for a moment or so then pops the reset off..............
Sounds like you may actually need to have the unit recalibrated by a Bosch Authorized Technician. Bosch Tankless units MUST be cinstalled and calibrated by a factory trained and certified technician as they are the only ones who have the proper tools for setting up the units.
If you did not have it installed by someone who is certified by Bosch, I would recommend that you call Bosch Service and get the name of someone who is.
I myself have a Bosch NG2700 unit and have never experienced any issues with it not working. Could be that the device is wired into a branch circuit of your home that is having problems or is underrated for the unit.
The heater should be plugged into an isolated 15amp minimum outlet.
Check the breaker/outlet, then call Bosch service next. The units have a 12 year warranty, so get it checked out. You may have to pay for the labor, but if they are certified and have the calibration unit, it should run you no more than a 1 hour call.
Keith
Feb 22, 2011 | Bosch & Tankless LP Hot Water Heater
Bosch aquastar Aq125-hx does not produce hot water. Pilot is ok. Gas and Flame heat is ok. water pressure is ok. Just no hot water getting to the faucets. Help.
That particular tankless water heater has hydro-generated ignition. In order for it to function, it requires a certain water pressure and velocity. You can try turning on the hot water in two location in your house to see if that gets it started. If it does, try getting a higher flow shower head, or removing the limiters in your faucets.
Jan 07, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch water heater
I'd initially check for a cross connection (cold water leaking into hot water system). This can be done by shutting off the cold water feed to the tankless unit, then opening up hot water fixtures around the home. You should see the water come to a complete stop; if you see a steady stream of water, then you have a cross connection. The most common place for a cross connection is at single handled showers. The valve cartridge starts to fail over time.
Jul 09, 2009 | Bosch & Tankless LP Hot Water Heater
Sings when producing hot water
it is a loose washer in a valve,,, when the water hits it just right it makes the sound,, either check the valve by turning it on and off while water is running that will let you know wich one it is
Apr 19, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch & Tankless LP Hot Water Heater  Logo
357 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
