Hello I have a maytag washing machine and when I turned i on yesterday it filled with water and just ran and ran and didn't finish. It doesn't do anything else? It beeps and a message comes up "time to end 1H 58 washing 0:02" Can you help Thank you Lillian
    Brigadier General:
  • 3,917 Answers
It seems that the pressure switch may be faulty. Take the lid off and the pipe that goes into the pressure switch which should be located to the right hand side blow into the pipe which rises on re-pressure. Replace it. Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 07, 2010
Maytag Neptune TL washer overfilling
yes i would agree the water valve is defective as if unplugged it should close,but also sounds like a pressure sensor or pressure hose problem that is also defective too due to the fact that it should at least start the wash cycle even though the water doesn't stop filling,so also it could be the central control unit,pressure switch or pressure hose
May 07, 2012 | Maytag Neptune FAV6800AW Top Load Washer
When the full washing cycle has finished and all the lights are off, water starts running into the tub. Would keep filling forever if I didn't turn hot and cold off at the connection. I then push...
Water will not shut off
1. Defective timer ( timer fill the machine)---replace
2. Defective water level control---replace
3.foreign particles in mix & fill valve---clean out valve
4. Defective valve---replace
Sep 22, 2011 | Fisher and Paykel GWL11 Top Load Washer
Washing machine doesn't fill with hot or clod water.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jul 05, 2011 | Maytag Washing Machines
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Water fill, discharge and noise problems
to reset the water level you have to turn the knob all the way over as far as it will go and then come back to large load.
Feb 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machine will not fill with water
It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Dishwasher filled with water even though cycle was finished.
the same problem accures with some types of washing machines,when you turn on the machine the control switch sends a signal to a valve on the mains water supply inside the back of your machine telling it to open the problem accours if you live in an area that has hard water because lime scale builds up in this valve so when you switch it off the valve is in the open position because of a lime scale build up, i would say it needs an new valve.adrian
Dec 16, 2008 | Maytag MDB9600A Jetclean II Built-in...
Too wet after machine done
maytag wash machine MAH8700AWW
Feb 16, 2008 | Maytag Neptune Washer
Nf pops up on the screen & the washer stops
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
May 13, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
