Question about Maytag Neptune Washer
Maytg neptune "FL" fault code
  • 96 Answers
FL fault code means door failed to lock. Could be misalignment between the lid and the locking mechanism. Try the service mode and see if you can get the door to lock. Otherwise you may need to replace the lock itself.
Posted on Feb 22, 2008
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune front loading washing machine door locked, is flashing a FL and will not unlock.
I suspect 'FL' stands for 'Fault Lock'. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 31, 2011 | Maytag Neptune MAH5500B Front Load Washer
My neptune washer stop working. has power but doesnt cycle. shows a FL code. cycle i mean as spin to start washing
FL means that the door isn't locked properly. Make sure that its locked tightly and restart the cycle
Feb 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune frontload washer codes FL when we try to run it, it will also not release door, i had to release door manually with release handle in soap area. this happens on any configuration of cycles
It would most likely be the door latch/although the wiring between ccu and door latch/ ccu and touch pad or user interface should be checked with meter as that can also give the FL code ...Good luck
Jan 31, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load washer with FL code
The "FL" is indicating that the door has failed to lock or it locked but the control does not sense the door has locked.
It could be caused by:
faulty door lock solenoid
loose wire connection
faulty door lock switch
faulty door lock sense switch
bad control board
I recommend calling a service technician to diagnose and repair your washer.
but try this first just in case....unplug it for 1 minute plug back in and see if the fault code clears.
good luck.
Jan 03, 2018 | Maytag Neptune MAH5500B Front Load Washer
Error code FL
FL means the door Locking Mechanism has failed. It will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2008 | Washing Machines
Error Code FL
it is saying failed to lock the door need door latch switch part # 22003269
Apr 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
"FL" light
The "FL" error code indicates that the door is not locking. The buzzing sound you hear is most likely the door lock trying to lock the door. It may only be a matter of aligning the door so that it locks properly. Otherwise, you may have a faulty door lock that needs to be replaced.
Feb 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
231 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
