Question about Arris SURFboard SB4200 Modem
What is the ip address for my sb 4200 - Arris SURFboard SB4200 Modem
  • 360 Answers
Http://192.168.100.1
Posted on Feb 07, 2010
Hi. I have a Motorola SB 6121 DOCSIS 3.0 cable modem. When I have a direct connectivity with this modem to the laptop with an ethernet, it works fine. But when I connect it to the Linksys wireless router,...
what is the ip address of the cable modem ?
when connected directly to the modem can you do ipconfig in dos command window and find out the gateway ip address listed.
This has to be the gateway ip address in the wi fi router.
turn of DCHP server in the WI FI router and make its ip address one more than the cable modem ip address.
make sure subnet mask is the same in both devices
Make sure DHCP server in Modem has leases above 20 to allow other devices to use 1 - 19 .
eg 10.0.0.1 or 192.168.0.1 for cable modem ip address internally.
make wi fi router 10.0.0.2 or 192.168.0.2 depends on the ip address of modem ?
Gateway address of 10.0.0.1 or 192.168.0.1 depends on the ip address of modem ?
dhcp server leases from 10.0.0.21 to 10.0.0.254 depends on ip address of modem ?
Feb 22, 2018 | Computers & Internet
I am trying to locate the ip address on an office hp 4200n
Usually you can print a configuration page and it will tell you the IP address that is assigned to the printer. You should be able to use the small menu screen on the printer to navigate to, and print a configuration page, or use it to navigate to the network settings to view and/or edit the current configuration. If all else fails, sometimes you can run Angry IP Scanner on a computer that is on the same network as the printer and see if any of the hosts come up with a name that matches the printer, then you will see the address of that host.
Jul 20, 2010 | HP LaserJet 4200 Printer
LaserJet 4200 Printer: HP LJ 4200 has Jetdirect card that worked fine unt...
Is the jetdirect card part number a 615n? If so, replace it with a 620N. The 615 cards were bad from the get go. Hp recalled them for about a year providing free upgrades to the 620.
May 16, 2010 | HP LaserJet 4200 Printer
Connect MSI RG54G2 to speadstream 4200
so that means if you connect the computer to the modem, it works but not with the router.
it seems that the router and the modem are not communicating with each other.
When you connect the computer to the modem , check the IP address through the modem. If ti is private IP address then you will need to change the settigns on the router.
Click Here for more info about networking
Oct 14, 2009 | MSI RG54G2 Router (MS-6848-002)
How do I get the ip address's that come into my 4200 speedstream
connect your router to computer with ethernet cable.
Then go to start menu then type in run 'ipconfig /all"
you find ip adreses sub net and GATEWAY.
GATEWAY ip is your router ip.
Let me know if you need more assistanse.
Thanks.
Aug 27, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Static Ip with Speedstream 4200 Modem
I am assuming here with the way you have it set up your getting an internet connection.
what you saying i understsand mostly so i'll see if i can help you
first of all you have speedstreem modem that connects to you isp, this is assign your internet address from the isp if you paid for a static IP it would be in here, if not it's assiged by a dhcp from your isp company so if you if turn it off or have a power loss for anymore than 5-15min your ip changes.
now your modem then connects into your belkin router this as well as your modem it's prob set up as dhcp so it wants to issue each computer with an internal address of 192.168.0.X the reason for this is so it knows where to send the incomming information to what computer.
no matter what computer your using the address that goes over the internet will be the one assigned to modem from internet provider so if this need to be static IP to run your game server you will have contact your internet provider for an address.
but you may be confussing the issue a little, my suggestion to you would be:
1. go to your connections on each computer
2. right click on the lan connection choose properties
3. go to internet protocol (TCP/IP) then click properties
4. then click on obtain ip automatically and obtain dns automatically
this will remove the static windows address you may have put in.
try this and see if you can get you game or game server will work.
btw you may have to reboot your computers after this to get be sure to get the new address.
Oct 09, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Hp laserjet 4200 printer- how to find the current ip address?
To have an IP address for the printer you must either have a HP4200n or install a Jetdirect card into the printer. The Jetdirect or "N" version of the printer with the built in Jetdirect holds the network IP address. Subnet Mask, Gateway Derfault and handles the networking functions. If you have a 4200n or Jetdirect installed it will print out on the configuration page.
The standard HP 4200 doesn't have the networking capability without adding the card. In the event that you have a card installed and its not recognizing the card on the configutation page it may be bad. The HP 615n cards are known to have burn out issues. If you have to install a card to upgrade your printer, I recommend a HP 620n or better to get around the known bad issues with the 615n cards.
Jul 07, 2008 | HP LaserJet 4200 Printer
Network connection
search for the network tab in the printer menu ( the setup isnt done from the computer)
and update the wanted IP address according to your network rules
Apr 06, 2008 | HP LaserJet 4200 Printer
Speedstream 4200 setup
I have just set up 4200 with dsl - you may find that you need to reset modem before you can configure. I was told that you need either a grey or yellow cable from your laptop to the modem. I use 10.0.0.138 to access modem. The 4200 I have was from a bigpond a/c - originally configured accordingly.
Regards,
Richard
Nov 12, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Static ip address
It is a ADSL Modem. It should have all ports open. In order to set a EXTERNAL static Ip address, you would have to call up your ISP and ask for a static IP address.
Aug 25, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Arris SURFboard SB4200 Modem Logo
356 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
