Question about Whirlpool RBS305PDS Electric Single Oven
Need to know if the temperature probe needs to be removed from my WHIRLPOOL WALL OVEN RBS305 for the self cleaning option. The instruction manual only says needs be removed from some models but does not say which models.If I do need to remove it how do I remove it/
  • 572 Answers
No u dont how is it going to read the temp for self clean. never heard of removing the temp probe. the things u remove are the oven racks
Posted on Feb 07, 2010
I have a whirlpool accubake self cleaning oven.. when trying to use the self clean option it now states e1 f5 in the digital screen what do i do know?
Most commonly that is a runaway temperature error which usually means the temperature probe is bad and needs to be replaced. If you need more detailed instruction or help making this repair visit the link below:
Appliance Repair Help With Live Chat
Mar 26, 2017 | Whirlpool Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
I have a Kenmore smooth cooktop electric range. It is about 3 years old. Recently i used the self clean function, and since then I can't get the oven door to unlock and I'm getting a F5 code on the read...
Press the "Off/Clear' button to cancel anything on the display, and reset the oven. This is a soft reset and will simply get you out of any program you have started. If the problem still persist,
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the oven back into the wall power supply to reset any anomalies with the oven memory.
Mar 02, 2011 | Kenmore Ovens
I have lost my manual and need instructions on how to start the self cleaning for the oven
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 18, 2011 | Whirlpool GBS307PR Electric Single Oven
I have a Whirlpool Super Capacity 465 SF357PEKQ Serial#RM5114836 oven. The oven heats up, but then after it heats up it shuts off unless I stand there and open the door for it to come back on. Otherwise...
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor .If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Oct 29, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Stove shuts off and posts F10 on readout
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 30, 2009 | Whirlpool RBS245PDS Electric Single Oven
I cannot get the oven to come on after I used the self cleaning.
Things to check- The screw in fuses, they are usually the 30 amp fuses for the oven. Next is the clock assembly, often these clocks will have the words "push for manual" or "turn for manual", this will put the clock back into the normal operating mode rather than the automatic mode. Next, you may have to remove the power and check for any burnt wires. If all checks ok, you will have to test the selector switch and oven control.
 Oven temp problems: Temperature is too low possible trouble makers, blown oven fuse, bake element is out, burnt wire, oven probe clips, oven temp control, oven temp sensor.
Temperature is too high in the oven possible trouble makers, oven temp control, oven relay ( if used ), oven probe clips, oven temp sensor, shorted wire.
These oven probe clips often rust off and the oven temp probe hangs down, or touches the oven wall giving false temperature readings to the oven control.
Apr 01, 2009 | Whirlpool RBS275PD Electric Single Oven
Oven will not heat after self cleaning
We used the self cleaning feature on our RBS305 Built In Electric oven and afterwards it would not heat. replaced the Fuse-Thermal part Nr 9759243 (which is the new part number. (Shown as Nr 37 on the Parts list for the oven parts). Cut all Power to the oven off and it was very easy to pull oven out with help of my wife. Removed back, bought a new part for 49.55 plus tax. Put in new part, replaced back and oven works like new. I am a 73 year old senior so when I say it is fairly easy to replace you know it is. Hope this helps someone
Dec 11, 2008 | Whirlpool RBS305PD Electric Single Oven
Whirlpool RBS305PDS Electric Single Oven Logo
211 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
