Question about Kitchen Appliances - Others
Le Creuset Non-Stick Surface trashed :-(
My Partner has trashed the non stick coating on my Cast Iron/enamel coated frypan. I brought this pan back from France while on my OE and adore it. They are terribly expensive in NZ and Id love to have it resurfaced if Possible.
1 - Can the non stick coating be redone?
2 - Who does this , anybody in Christchurch
3 - Approx Cost
4 - Will it be any good?? Will it still be the same Le Creuset pan I love???
It is not electric as stated below , I had to out something to have this processed!
  • 12,061 Answers
Posted on Feb 07, 2010
Testimonial: "Thank you! I'll give them a try."
Make a non-stick skillet non-stick again
David, If the skillet has a teflon coating and that coating is starting to break down just dump that skillet, you will never repair it and it is toxic to the kidneys. If it is cast iron then you will have to clean all the burnt food of dry the skillet, Dry it with heat and coat it with oil, flaxseed oil works well. slowly raise the temp of the skillet and hold it for about 30 mins then just let it cool.
Dry well and coat it with a little oil after each use,, same for carbon steel. The non-stick properties will improve with use.
Oct 24, 2017 | Kitchen Appliances - Others
My Scanpan wok has bubbled on the tatanium surface I now think it is not safe to use
not ideal
the flakes and scrapings of the pans coating
will end up in the cooked food
happenes with all non stick pan surfaces
using metal utensils , over heating . age of pan
Jan 13, 2017 | The Kitchen Appliances - Others
Breville toaster oven non stick pizza pan coating coming off
f you want to have a non stick coating you will have to order a new pan. There is no way to get a coating like that to stick again or even repair it. You might also want to scrape it off and go back to the old school method of greasing the pan.
Aug 10, 2012 | Breville Kitchen Appliances - Others
Is it possible to restore the teflon surface of teflon coated pans on which the surface has become scratched (in this case Jamie Oliver Tefal Frying pans)
No. There is no effective repair procedure for the pan once the teflon coating has become scratched down to the bare metal or begins peeling off.
You can continue to use the pan safely, but the non-stick surface will not be as effective as an undamaged coating would be.
Never use metal forks / spatulas / utensils on a teflon coated pan.
Instead try using thermal rated plastic, teflon, or wooden spatulas which will not scratch the pan coatings.
Good luck.
Jun 12, 2011 | Microwave Ovens
I have an old Le Creuset 16cm frypan an food especially eggs stick to the bottom .Is there any thing I can do to fix this?
It probably needs re enameling but the good news is that Le crueset guarantee for life. I can't point you at a link as i dont know where in the world you are but if in the UK see here
http://www.lecreuset.co.uk/Care--Use/Cast-Iron/
hope that helps
Jan 25, 2011 | Microwave Ovens
Gas oven lights pilot straight away but takes a long time for main burner to work has it got a thermocouple and cuold this be at fault
Sorry to read about your problem, I hope this helps you out.
I will assume you have the gas. there is no thermocouple, your oven use electronic ignition.
you may have a bad liter or you need to clean the grills
Hotplate Top Enamel or Stainless Steel
Hot soapy water, soft cloth. Any stubborn stains remove gently with a nylon scourer.
Pan Supports, Wok Cradle (some models only)
Enamel coated Cast Iron or Stainless Steel
Cif Cream Cleaner- Faberge Lever and a nylon scourer.
Dishwasher.
Burner Caps Enamel
Cream cleaner, nylon scourer. Dishwasher
Burner Trim Rings (some models only) and Burner Head
Aluminium
Cif or other cream cleaner with a soft cloth. Be careful not to be over vigorous.
Griddle Plate (some models only)
Non-Stick Surface
Allow to cool. Wash in hot soapy water. Do not use abrasive cleaners/scourers. Dishwasher.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Rangemaster Toledo 90 (Dual Fuel) Dual...
I have a black sticky residue on the non stick surface of my cooks essentials 12 inch frying pan. I can not clean it off and the non stick properties of the pan is gone, I think due to this surface...
Go to epinions.com, type your product and find you are not alone. Besides, as there is no cure to baldness there is no such thing as a perennial non stick pan. All coatings invented eventually succumbs to the wear and tear produced by temperature changes, contact with food and related chemistry, detergents, scrapping, etc. Consider the possibility that some of that non stick material may be ingested unconsciously.
Dec 18, 2010 | Microwave Ovens
Using a Farberware 12 pan coating comming off
non stick coating are volatile and have a short life span depending on the frequency of cooking and washing which wears it out if you are a keen amateur cook/chef my advice is go for HARD ANODISED which is russian space technology in your kitchen or classic copper pots/pans but they are costly,
to help preserve your non stick 1. do not wash straight after let it cool down, 2. always use plastic or wood utensils.3. be gentle,
hope it helps.
Jul 29, 2010 | Faberware Kitchen Appliances - Others
Non stick coating has been damaged
toss this pan out as that damaged coating is a cancer causer.
Feb 26, 2009 | Kitchen Appliances - Others
Enameled Cast Iron Pans In Sharp Convection Microwave 820
It should be fine, but to be sure I'd contact Sharp.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277).
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 10, 2007 | Sharp R-820B Convection/Microwave Oven
Kitchen Appliances - Others Logo
984 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
