Question about Lexmark X3350 All-In-One InkJet Printer
3350 stoped printing - Lexmark X3350 All-In-One InkJet Printer
  • naushasame May 11, 2010
    was it working few minutes ago? how old is it
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
  • 1 more comment
  • JM Alvis Feb 07, 2010
    Supplies needed:
    paper towels
    latex gloves
    warm water
    PROCEDURE:
    Hope this helps. .
  • JM Alvis Feb 08, 2010
    Supplies needed:
    paper towels
    latex gloves
    warm water
    PROCEDURE:
    Hope this helps. .
    Supplies needed:
    paper towels
    latex gloves
    warm water
    PROCEDURE:
    Hope this helps. .
Where is the scroll lock button on my dell vostro 3350?
You can Click Start
Type in OSK
then activate your scroll lock on or off.
Feb 06, 2013 | Dell VOSTRO 3350
Smiley nokia 3350
if you want some reference you can go to YMand look for the symbol combination ofthe emoticons there. that is also the symbols for smileys. like :) ;) T_T ^_^ etc
Jul 24, 2012 | Nokia 3350 Cellular Phone
Need a needle for a TECHNIC SL-3350
It's 'TechnicS' and 'stylus'. Wouldn't a web search have been faster?
"TECHNIC SL-3350 stylus"
But even 'technic" and 'needle' would have worked.
http://www.lptunes.com/Technics-SL-3350-turntable-stylus-replacement-p/tstsl3350.htm
Sep 01, 2011 | Technics Audio Players & Recorders
LexMark 3350 Printer often stops printing in mid multi-page
If printing is stopping in the middle its not the Problem with the driver
Check the Spooling Properties
Checked Printing Test Page
Jan 06, 2010 | Lexmark X3350 All-In-One InkJet Printer
Using the PCL drivers for our Ricoh Aficio MP 3350
Try using the RPCS (Ricoh's proprietary print driver) for printing from Word, and see if that works any better. You could also try another version of PCL -- if you're using PCL6, try PCL5, for example.
All of the 3350 drivers can be downloaded here (just choose the correct operating system):
http://ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/mp33/mp33en.htm
Dec 02, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Manual
hope this link helps
http://cameras-and-mp3-player.free-driver-download.com/Vivitar/35279/Vivitar-Vivicam-3350-Twain-Driver-Windows-98-Me-2000-XP.html
I believe the cord looks like this
http://ecx.images-amazon.com/images/I/41WYbuAGTML._SL500_AA280_.jpg
Mar 25, 2009 | Vivitar ViviCam 3350 Digital Camera
Lexmark 3350-Vista-Prints but Won't Scan
Is this the driver you downloaded. If so , sounds like a Lexmark software or driver problem. I am a little confused as the heading on you question says x1270 but the bold type says 3350?
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Dec 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X3350 All-In-One InkJet Printer Logo
91 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
