Question about ASUS P5PE-VM Motherboard
I DISCONECTED ALL MY CABLE SO NOW I CAN'T ABLE TO CONNECT THE WIRE BECAUSE I LOT MY BOARD CHART
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 28 Answers
It is easy...
remember this your motherboard is like a children play house red for red, square for square.. if it is not compatible for the socket it will never be placed well..
you need to connect the following..
first your main power supply to your motherboard
it is very easy to see.. it is a group of maybe 16 wires in a plastic connector..you will connect it to your motherboard..
your processor power is a four wired in plastic connector but it is square in shape..
note: take a good look in each connector they have squares cirlce, etc shapes in each wires so don't force it to connect if it is hard to it means it is not for that socket..
this is the turning point..
your power button, reset button, pw LED, HDD LED,
maybe you know where it is placed,
but note the sequence.. pw button, reset, pw led,hdd led,
if not you can try to short the pins of *********** board so that you will know where the power button will be placed...
your usb and internal speaker has their own pins....
note: take a good look to your motherboard before you connect it, it may cause you some trouble..
take a look at the + ,- signs that is encrypted in the motherboard...
you have to the red wire is fore the posite and the black is negative..
i know it is compose of four wires but they are in one socket right...
your hdd connect it i know you know that how..
that's all..
Posted on Feb 07, 2010
I need a wire chart or a service guide for RCA antana ant 121r
there are 2 bolts up at the antenna and the converter plug fastened to them side makes no difference .
Jul 06, 2015 | RCA Televison & Video
CRT VGA cable pin color problem. I can not get which pin connect where
Refer its connection diagram. The user manual might help you. If not, contact any service technician.
Nov 25, 2014 | Philips Televison & Video
How to change a oxygen sensor
firstly take the old one out by cutting the wires aboput 2/3 inches above the sensor then unscre the old sensor with a 22mm spanner then buy a universal sensor from auto factors a three wire is twice the price of a 4 wire sensor and the box of the 4 wire one is a colout coded wiring chart as the colours do not always match up so use the chart to sort then out ,the heater wires can be connected either way around though ,then refit the new sensor and use a block connector to reconnect the cables following the cable chart ,easy shouldnt take more that 20 mins to do .
Feb 10, 2011 | 1996 Pontiac Sunfire
I want to connect My front USB to the Gigabyte MB ga-945p-s3 i dont know how to do it right if there is a video to show me how to do it, that would be great your help is needed thanks
There are two connectors on the motherboard marked F_USB1 and F_USB2 for the front panel USB ports. This is the page from the manual (you can download a copy here) for your board:
The pinout of each USB connector is the same, so it does not matter which one you use. Each connector supports two USB ports. The pin assignments are a standard, and the cable from the front panel USB connectors in your computer case may already have a plug on the end which will fit. Note the missing pin (pin 9); the plug is keyed so it will only fit one way so you can't put it on backwards.
If the front USB cable in your computer case doesn't have a 10-pin plug on the end, it will have a separate single-pin connector on each wire, and they will be marked with their function. Make sure you match each wire to the correct pin on the board, following the chart shown above.
You should have your front USB working very quickly. Thanks for using Fixya!
Dec 03, 2010 | Computers & Internet
Lcd does not power on
check outlet power, power cable and fuse inside. go step by step . be carefull some component hold power even if the tv is unplugged
Sep 11, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Radio display light
To get the back light on you need to hook up the illumination wire to the ignition acc wire
Jan 10, 2009 | Clarion DXZ375MP CD Player
Older whrilpool dryer
make sure the green wire is connected like in the picture. this connects directly to the neutral, if it is disconnected when you connect a 3 wire cord then this problem you are having will happen.
Aug 06, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
My clor looks to be
check the cables from your receiver or cable box. I am assuming you are using the Y, Pb,Pr component hook up. check the red wire, (Pr), as it may be disconected or bad.
Mar 30, 2008 | Televison & Video
ASUS P5PE-VM Motherboard Logo
104 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
