Question about Canon SmartBase MP360 All-In-One InkJet Printer
PRINTING PROBLEM WHEN I PRINT SOMETHING IT ONLY PRINTS THE TOP & BOTTOM LINE, IE PAGE 1 OF 1 ON THE TOP & FILE://C:\USERS\JULIE\APPDATA\LOCAL\TEMP\LOW\3C39RJ0E.HTM ON THE BOTTOM. HOPE YOU CAN HELP
    Problem Solver:
  • 13 Answers
Most probably the setting in your document. try to see header and footer settings
Posted on Feb 07, 2010
My printer is not printing all the horizontal lines
First try to copy and if copy works fine, means the hardware is fine and issue with the driver.
Do right-click on printer icon and select delete.
Once deleted, run the installation disc and click on add a device, follow onscreen instructions to complete the installation. Open printers and faxes window and then do right click on printer icon and select properties, click on print test page.
Check if it prints fine, if yes try to print from other application. I hope it will work.
May 26, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Brother MFC 7220 prints vertical line from top to
The photosensitive drum needs to be cleaned or replaced. If after cleaning it the vertical line continues, the printer may need maintenance.
Sep 17, 2009 | Brother MFC-7220 All-In-One Laser Printer
My computer was printing fine, but now it prints blank pages on every website I try to print from. All I get is "Page 1 of 1" on the top and the website address on the bottom. Same with the print preview....
You must try to print a test page. If it still prints black pages. Maybe it has changed its configuration. You must configure it first to your desired output.
May 18, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Layout/Printing issues
FileMaker 5.5 is a long time ago for me, but I think I will try to answer your question (although it is likely you have a solution or no longer need one.) While in layout mode, while working on the layout, go to printer setup and choose the printer and page size you will be printing to. This will cause FileMaker to have a dashed line where the printer pages are on the layout. Anything that extends over these lines will require additional pages to print. Simply bring everything back in before these lines to limit to 1 page (including the blank space at the bottom of the page. There is a tab you will need to drag above the page break line to prevent a second page from printing. Additionally, if you cannot work it out, while printing from FileMaker if you choose the page range of 1 to 1, only 1 page will print, however, doing this prevents you from printing additional records without writing a script to do it. However, if you are able to redesign the layout to only print 1 page then you will notice there is an option on the print dialog box that indicates something to the effect of "Print current record" and "Print records currently being browsed" (Don't remember the exact wording in FileMaker 5.5); Choosing the records currently being browsed option will print all records in your current found set.
I hope I've done a good job answering your question. I am a FileMaker expert for version after 7 and have used Filemaker since version 4; if you have any additional questions I will do my best to answer them. If my answer was helpful for you I'd appreciate a 5 thumbs up rating, or a click on the yes this was helpful button. Thank you!
Apr 06, 2009 | FileMaker Server 5.5 (540100U) for Mac, PC
Counter info print out
Hi Beadworker,
This information can be found by printing a configuration page from your printer. Follow these steps to print out a configuration page.
Printing a Configuration Page
You can print a configuration page from the printer’s control
panel. Use the configuration page to view the current settings,
to help troubleshoot problems, or to verify the installation of
optional accessories, such as memory or an optional tray.
To print a configuration page:
1 In ready mode, press the Menu button on the control
panel until you see “Information” on the bottom line of the
display.
2 Press the Enter button to access the menu.
3 Press the Enter button when “Configuration” displays
on the bottom line.
A configuration page prints out.
Oct 11, 2008 | Samsung CLP-510 Laser Printer
Print out counter info
Hi Beadworker,
display.
on the bottom line.
Doesn't print correctly
Current printers do not have a 'built-in' font or character set. The printers only print what they are told to print by the application from which they are printing. What program are you printing from? Does it do this with all programs? Check printing from very basic programs like Notepad or Wordpad (print documents that are at least a couple of pages long). If the printer prints correctly from there, you may need to contact the publisher of the program that is giving you the weird printing.
Apr 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
No print of the Internet Address Bar
In Internet Explorer 7 do the following to remove the internet addresses from the top and bottom of each printed page.
Start IE&
Click "File"
Click "Page Setup..."
Look for the "Headers and Footers" section of the Page Setup control panel.
Remove everything in the "Header" and "Footer" fields.
Click "OK"
Let me know how it goes.
Jan 08, 2008 | Computers & Internet
Top print margin shrinks.
It's a software problem, you have to uninstall the printer and reinstall it then it will be ok.
Oct 10, 2007 | OKI MICROLINE 390 Turbo Matrix Printer
Open Questions:
See all Canon SmartBase MP360 All-In-One InkJet Printer Questions
Canon SmartBase MP360 All-In-One InkJet Printer Logo
124 people viewed this question
old marine
old marine
