Question about EnGenius EOC-3220 (EOC3220)
Resetting the senao eoc-3220 long range wireless access point/bridge
Pls kindly tell me how to reset the eoc-3220 to default setting
  • eoc3220_user Mar 03, 2008
    when i telnet into my eoc3220+ unit(via hyperterminal), it drops me into a linux shell prompt. using 'help' command shows list of shell built-in commands. i have a little bit of knowledge of linux and was able to use 'ifconfig' to obtain ip information. but i don't know how to reset the username and password. there is no built-in 'ls' command so i can't list commands in any of the bin and sbin directories. what happened to the user interface that was available in the 2611cb5 model?
    any help would be greatly appreciated.
    Problem Solver:
  • 6 Answers
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Posted on Feb 22, 2008
Serial Port not work, plz help me what i do. any reset option on Main Borad.
Posted on Sep 06, 2010
You should use the superuser account via SMTP, that is all I am saying, as it is a weakness as well as a strength.
Good luck!!
Posted on Feb 18, 2009
  • MikeTson Feb 18, 2009
    Erhh... fast fingers... SNMP I meant - of course :)
On linux prompt > type flash reset then press enter
>flash reset
>reboot
that's it... your senao should be resetting back to factory default
Posted on Jun 04, 2008
My Seneo 3220 has changed its mac and gone to Realtek,can not log on to it any more,think its lost Engenius software. nigel 2205
I have no idea what it means for a Senao to "go to Realtek."
Here is the factory reset procedure for the Senao EOC-3220:
An RS-232 null modem serial cable is required for this procedure.
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Oct 25, 2010 | EnGenius EOC-3220 (EOC3220)
Problem using 2nd hand AP senao EOC3220 EXT
You can use this unit either as an access point, to provide wireless access to a network you already have, or as a bridge, to access a remote wireless network someone else has.
Note that you own the EXT model, meaning that you have to attach your own antenna to the connector before it will function. There is no internal antenna on this model.
Configuration instructions are available at
EOC-3220 Series User Manual
Factory reset instructions are available at:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
May 14, 2009 | EnGenius EOC-3220 (EOC3220)
Username password
Apr 18, 2009 | EnGenius EOC-3220 (EOC3220)
Trying to get into my engenius 3220.using 192.168.1.254
If you have lost track of what IP address you have assigned your 3220, you can use the serial reset procedure documented here to return it to factory defaults:
http://www.engeniustech.com/datacom/support/general-details.aspx?id=65
Apr 16, 2009 | EnGenius EOC-3220 (EOC3220)
How do i reset my engenius senao eoc 3220 outdoor radio
back side one reset button is there pull out the power cable then pull in that same time you have to press the reset button for three to five sec then all lied's blink all to gather then your default ip address is came then you again configure at default ip
Apr 15, 2009 | EnGenius EOC-3220 (EOC3220)
My senao eoc-3220 is showing SSID as 802.11g-SSID. But it does not acquire an IP automatically. I tried using defaults but that does not work either. Trying factory reset does not work because the "#"...
Hi
I had the same problem. This may be as simple as pressing the enter button on your computer keyboard after all the activity stops. This brought up the number sign for me after which everything else in the reset procedure worked fine.
Dec 22, 2008 | EnGenius EOC-3220 (EOC3220)
Eoc3220+ ip finder
hi
reset your eoc 3220 and put the default ip address is 192.168.1.254 bridge mode and ad mode ip is 192.168.1.253 and put your pc ip 192.168.1.10,12,14,16 and open the web page and browse the 192.168.1.254 or 192.168.1.253 put user name and password ok!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Oct 07, 2008 | EnGenius EOC-3220 (EOC3220)
After a windy day lost wireless connection
For a new unit disconnect the eoc from the network and connect directly (through POE injector of course) to your laptop/pc.  then in network connections setup your lan port TCP/IP settings as follows.  ip 192.168.1.10 subnet mask 255.255.255.0 then gateway 192.168.1.1
point your browser to 192.168.1.1 or 192.168.1.2 (one if it is in AP mode and the other address works if it is in bridge mode).
When configuring, I assign it an new static IP outside of the DHCP assignment range.
To see how it is setup afterwords you can use hyperterminal with a null modem cable to view the current config.  instructions on the engeniustech.com support page.
May 28, 2008 | EnGenius EOC-3220 (EOC3220)
SENAO EOC 3220 CONNECTIVITY PROBLEM
hello!
-- try to change wireless channel on your access point
-- try to enable wireless security on your wireless network
-- try to assign static ip address on your wireless computer
Apr 26, 2008 | EnGenius EOC-3220 (EOC3220)
AP Mode Problems
Probably you have to learn that there are various people looking for an access of the internet through your facilities. Anyway, inorder to solve your problem these are the following recommendation I made just for you. Hope this will be helpful.
PHASE I
1.) How do I reset the EOC-3220 / EOC-3220 EXT / EOC-3220+ back to factory default settings? An RS-232 null modem serial cable is required for this procedure.
(where to buy it : http://www.keenansystems.com/store/catalog/product_info.php?cPath=3&products_id=221)
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press “OK” to bring up the HyperTerminal window.
Phase II
1.) Since that you already reseted the AP you need to use the default IP which is 192.168.1.1 user: admin password: admin
2.) Make it sure you need to use different IP such as 72.10.251.xxx and the subnet: 255.255.255.xxx
3.) The idea of configuration in come from your own desire which was no body can no longer try to match your network IP so that there will be no body access your AP anymore without your knowledge.
4.) You need to make you SSID invisible to everyone inorder no body no longer able to reach your SSID by setting up basic setting which is transparent to everyone.
5) And lastly change the default user and password of your AP.
Good Luck
Nov 24, 2007 | EnGenius EOC-3220 (EOC3220)
EnGenius EOC-3220 (EOC3220) Logo
3,701 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
