I have a pioneer vsa 9500 amp, usually when i turned it on, it has two clicking sounds, now it has only one, and it doesnt have any output sound at all but it has power''
  • rlblancas Feb 09, 2010
    thank you for taking time ctaylor, i just want to clarify on what do you mean by d.c.?
  • 88 Answers
Suggest one channel has gone d.c. and the speaker protection relay is not operating because of this. or maybe power on delay cct is not working correctly
Posted on Feb 08, 2010
Pioneer VSX - 26 TX single-processor receiver elite no sound work fine one day turn on have no sound checked all the connections everything's good here clicking in the receiver can you help me
You may have overloaded your amp. If you have a separate amp in line then this would not be the case but if you are using your receive as the amp then it could be. Look for a fuse on the unit. Usually a small black square marked with 15a.
Dec 03, 2015 | Pioneer Audio Players & Recorders
Pioneer DEH-P5200HD after I replaced a fuse the subwoofer stoped working. I checked the speaker and the amp. Its the radio that doesnt give signal to the amp. Also I tried turning on and off the sub in the...
It sounds like the remote turn on wire from the radio no longer outputs power. You can try connecting the the remote turn on wire from the amp to the accessory power of the radio. Place a 10 amp fuse in line just in case the issue is the amp.
Sep 07, 2012 | Pioneer DEH-5200HD
Hello, I have an old Pioneer VSA-1000 home theatre
I have a Pioneer VSA-1000 with what sounds like the exact same problem. It is the world wide model with multi-voltage selectors.
I bought a schematic a couple years ago that I found at www.servicemanuals.net. Cost USD $21 at the time.
Mar 01, 2010 | Pioneer Audio Players & Recorders
I have a pioneer receiver..vs 812....and sound has ceased to come out of it. It comes on....and switches between sources...but there is no signal coming from ANY source
First make sure the speaker A/B switch is on.
If still no sound, dissconect ALL speakers from the rear of amp.
Now turn on amp and listen for the relays to click in.
One relay will click when you press power. A couple of seconds later, the speaker relay will click in.
If it does, you could have blown outputs, bad speaker wiring, faulty speakers.
If it does not, the speaker relay may be faulty.
Hope this helps.
Sep 12, 2009 | Pioneer VSX-D812 Receiver
My marantz DV 9500 doesnt output digital signal for audio cd anymore but outputs audio for dvd,sacd,dvd audio. Does it need servicing
Make sure your playing componet like CD player have a digital output socket. Connect this to a digital port on the amp witk a single RCA or Optical cable if output available on CD. Make sure the digital assingment in amp is set for cd function and corresponding input(example cd plyer connected on dig 4 input on amp, press menu, setup, assignment, go to cd player, make sure setting on dig 4 or change input to dig 4, go to next component to memorise setting.and exit, see manual to assist you) if still no sound take dvd cable for instance that is working and put that in dig 4 port. if that works check in cd player that settings spdif/raw/pcm is correct one for yor digital output if still no sound soun pc board faulty.
Aug 11, 2009 | Marantz DV-9500 DVD Player
Wiring the scosche fai-3a to a pioneer two channel amp
the 2 left and right dont matter, it only matters when ur hooking up a 4 channel amp.
all u do is connect one of the channels to it but it would be best o buy a stereo ull have alot of engine nose and vibration on ur speakers and a thump every time u turn on ur car but itll sound ok for now ti
Jul 07, 2009 | Scosche Industries Scosche Slc4 Speaker...
JL Audio 500/1 Amp, The green power light is on but no sound!
Check to be sure you are on the correct outputs on the head unit, and be sure the outputs do not have a separate volume control.
Mar 06, 2009 | Jl Audio 500/1 Car Audio Amplifier
Pioneer amph sa 9500 II
Hi yalazogeday
Your amp is fitted with two 2SD588A (NPN) and two 2SB618A (PNP) power transistors in the output stages. Click on the part for a place to get them from. These parts are no longer available from Pioneer, nor are the prescribed replacements. (the amp was built in 1978) Because of the unusual transistor package used, you may have to upgrade to a more modern transistor, and modify the mounting also.
robotek
May 24, 2008 | Audio Players & Recorders
Pioneer vsa 730
try pushing your speaker button untill it says speaker A on or try pressing the button that says signal select.... push it untill auto appears on the screen (You have to do this to every Input eg DVD CD etc Not the radio ) other than that not sure
Mar 10, 2008 | Pioneer VSX-D411 Receiver
Pioneer vsa e06
depends what audio outputs you have on the sky box,analogue (two phono usually red for right channel and white left channel)in which case just use phono leads to the phono inputs,Optical(toslink),connect an optical cable from the output to the optical input on the dvd channel of the pioneer,coaxial (spdif)connect to spdif input on the laser disk input of the pioneer,dont connect to the attenuated spdif.In the unlikeley event of the sky box not having any audio outputs,just use the outputs from the tv to the pioneer.The optical digital input gives the best quality on the vsa eo6
Jan 24, 2008 | Pioneer VSX-1015 Receiver
1,116 people viewed this question
 Grubhead
Grubhead
