Question about Canon PIXMA MP610 InkJet Printer
Canon MP610 error:''Paper output slot - paper jam..."
Canon MP610 error message: ''Paper output slot - The paper is jammed. Clear the paper and press OK.'' Opened and checked all slots and there is no paper. Cover is properly closed. Pressing ''OK'' just redisplays same message
  • 1 more comment
  • Yuri Feb 07, 2010
    This is an answer I have received from a website similar to yours - looks like copied from the same book:
    This problem can happen because of following reasons :
    1. There is some piece of paper / paper clip / sticker stuck inside printer and you are not able to access it. In this case you need to remove all ink cartridges, turn off printer, then turn it upside down and shake it few times. If still not working then you need to open it up as much you can to see if something is stuck
    2. The electric sensor which receives signal from the mechanical paper sensor to detect jam has issues. Either there is dust on it or its gone bad and needs replacement. You should first open up the printer and blow air in it (using compressed air can) to remove all dust.
    Now, if you have read the description of MY problem, you should know it's not that.
    What else can be there?
  • Yuri Feb 07, 2010
    Attention "Experts"!
    This is an answer I have received already and I've done all that:
    So, please, don't suggest this again
    I need a real expert assessment and recommendation, thank you!
  • Yuri Feb 07, 2010
    Where is this sensor located?
  • 11,896 Answers
Double-check that there is no paper in the rollers or gears as well. Then try unplugging the printer for a couple hours. In the meantime of it being unplugged, then press and hold power button for about 5 full long seconds. Wait half hour more and plug back in. The printer should now be reset. Try printing again. If same error message is received, there must be a hidden piece of paper that is stuck or the printer head needs to be cleaned with rubbing alcohol and a cotton swab.
Posted on Feb 07, 2010
  • 542 Answers
Check and remove any piece of paper is on the paper out sensor. Also check the any dust is accumulated on the paper out sensor. clean the same will resolve your problem.
Revert back for more assistance.
    Brigadier General:
  • 3,917 Answers
Sometimes the following reasons are responsible for the error. There might be some piece of paper / paper clip / sticker stuck inside printer and you are not able to access it. In this case you need to remove all ink cartridges, turn off printer, then turn it upside down and shake it few times. If still not working then you need to open it up as much you can to see if something is stuck. The electric sensor which receives signal from the mechanical paper sensor to detect jam has issues. Either there is dust on it or its gone bad and needs replacement. You should first open up the printer and blow air in it (using compressed air can) to remove all dust. Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Paper won't feed into printer & output slot jam error message
reboot your pc.unplug cables make sure you remove papers jams located at the back of your printer
Jun 24, 2010 | Canon PIXMA MP610 InkJet Printer
I have the following error message:
SOMETHING MOST LIKELY FELL DOWN IN BACK PAPER PATH OR TORN PAPER THAT HAS PAPER SENSOR STUCK. HARD TO SEE SOMETIMES. MIGHT WHAT TO TURN MACH UPSIDE DOWN AND SHAKE BE VERY CAREFULL
Apr 14, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error paper output slot. the paper is jammed clear
Try this...With te printer off line, press the paper feed button making sure thre is paper in both feed trays. Once it print, a blank page go in and change back t your desired papper source. Hope that helps, please let me know.
Ash
Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Problem with Canon MP600
I had the same problem with my Canon Pixma MP610.
After stripping the printer down I found there is a lever in the path of the paper that operates a photo electric sensor. This can get stuck in the wrong position. To reset it get a sheet of A4 paper or (better) card fold back a 1 cm strip on the top edge of the paper and press it down flat. Open the rear cover and insert the sheet folded edge first and folded flap upper most over the top of the upper set of rubber rollers. Push it into the machine as far as it will go and then withdraw it. You should feel a little resistance or here a click as the lever is reset. You printer should now work.
Several hours of frustartion and foul language have brought you this fix. I hope it works for you.
Regards
Jon
Jan 03, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper Output Slot Error Message
When the print head temperature falls, the error is
automatically cleared.
Note:
If the print head temperature exceeds the specified limit
when the scanning unit (printer cover) is opened, the
carriage does not move to the ink tank replacement
position.
Oct 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error, paper output slot
That means the sensor flag under the platen roller is broken, bent, or jammed in the up position. Hard to see and must be taken apart to repair.
Aug 07, 2009 | Canon PIXMA MP610 InkJet Printer
Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Jan 04, 2009 | Canon MP610 Photo All-In-One Printer
Mp830 shows paper output slot jam
I cannot receive faxes or print anything.
The message says that "there is no paper in the machine". There us plenty of paper in the machine and I push "OK" and get the same message
Jun 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP610 InkJet Printer Logo
353 people viewed this question
old marine
old marine
