Ip90 Printer all installed and apear to be working fine. i send documents to print. Sends everything and appears to print fine. but when paper comes out nothing has printed. Followed all instructions and taken casing off. Any suggestions? Thanks Crispian
  • Peterson8 Feb 22, 2008
    After installing new ink cartridge I send documents to print. When paper comes out nothing has printed.
    Any suggestions?
    Scholar:
  • 121 Answers
Just to be sure i'm going to ask this ??.. have you removed the little sticky clear film located on the new cartridge? not sure what kind it is but double check that.. if that's not the case, i would go into your printer properties and check thru your options and be sure you do not have some setting set to off that would affect your color.. if there is a default option, set it back to default settings, then reboot.. hope this helps.. d
Posted on Feb 22, 2008
Pages come out of printer blank
It’s making te noise of printing or just get the paper and got it out fast ? If goes straight out is the driver if goes line by line and is blank the cartridges are dryed or the injector are clogged with old ink. Time to buy a new one or send it to maintenance
Nov 10, 2017 | Kodak EASYSHARE 5100 All-In-One Printer
The printer will print a document but does not put it all on one page. Sometimes it prints part of the document, then sends out a blank page, then prints the remainder of the document on a third page. We...
1. check paper length..... Select proper lengths
2. check printing leading edge, weather its matching to the selected scale?...Clean paper sensor & disc encoder
3. check printed caractors, is there any abnormal caractors?....clean Disc encoder & sensor
3. remove back door clean the paper sensor and check sensor flag
4, clean disc encoder & sensor...
goodluck..
Sep 05, 2011 | HP Deskjet Printer
'check paper size' error has come up and nothing can now be printed. If turned off and on the last print which had caused the error prints out then the error message appears again. How can i clear this
This is usually caused by data within the print job. Microsoft Office sends paper size and job data with each job. Clear all print jobs in the computer sending the job.(Start/Printers/double click the canon printer and delete all jobs in the print que. Clear the Canon by off/on. Open a program and print a standard letter size document to test. This can be corrected by going to the page/document setup choices under "File" or the Ball in MS Office. Usually this is set to A4 or Bypass by mistake within the application.
Thanks
Jan 06, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
The printer sends the my computer successfully sends the document to the printer but it does not print. the paper goes through and comes out blank.
Try unplugging the Printer for 30 seconds, Plug it back in and try it out. if problem persists next step.
Are there any error specific codes? If not re install drivers here link to your driver.
Please provide feedback to help get to the source of your problem, thank you.
Nov 10, 2010 | HP DeskJet F380 All-In-One Printer
Ip90 printer does not print blac on a test after
Sounds like the printhead is plugged on the black side. A new printhead is #qy6-0052-000 around $40.00. That model also needs a firmware update to help it clean the printhead better.
Jun 23, 2009 | Canon PIXMA iP90 Mobile Printer
Printer sends out extra page everytime I print
either your paper size settings need to be adjusted in the software, or your setup has included a seperator page.
Jan 27, 2009 | Office Equipment & Supplies
Lexmark C1150 printer doesn't print
First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
Reconnected the cables again, install the printer - it works well!
Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
3055 sends to manual feed
Hi there
I've had a similar problem in windows instead of the mac, but it sounds like it's a
similar problem where the computer's telling the printer to use a
different sized paper to what the printer's been told is in the trays. For example, if, say, your document is set up for A4 sized paper, but the printer is set up to think it has Letter sized paper in the trays, it'll ask to have A4 sized paper installed in the tray instead.
Go into the system setup on the printer and select the paper setup menu.
Select Tray 1 and choose the right paper type and size from the settings (After you choose the paper type you have to go all the way back through the menus on the printer and choose the paper size as well)
Hope this helps!
Nov 22, 2007 | HP LaserJet 3055 All-In-One Printer
56 people viewed this question
k24674
jasbo
jasbo
