My crosley heavy duty washer will not spin and when in spin mode it smokes, help?
  • tbabygirl323 Feb 08, 2010
    Very helpful, thank you my washer works great now, it was the belt!
  • 311 Answers
Usually when these units smoke it is the belt burning on the motor pulley. Depending on the model you will probably have 2 phillips screws towards the bottom of the panel on an upward angle. Remove the two screws and pull the panel towards you and there is two tabs at the top of the washer. Put it into a spin cycle and see if the transmission is spinning freely. If not unplug the unit and try to spin it by hand.
There are a couple issues that can cause the belt to burn up.
1) The tub bearing is tied up which would usually mean it sounded like a jet taking off for a while before the issue occured.
2) The idler pulley bearings are bad. You can remove the belt and spin the idler pulley. If its tied up then replace the pulley and the belt.
I hope this helps. In the future if you have problems the model number would really help me to give your more model specific information. I will be available for chat for a little while if you want additional help with the unit.
Good luck _MJ_
Posted on Feb 07, 2010
Crosley heavy duty dryer blows out heat but will not spin
Check the dryer drum drive belt it may be broken or the dryer drum drive motor may have failed
Oct 18, 2016 | Crosley Dryers
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series washing machine, heavy duty, super capascity plus,quiet pak2 3spd motor w/5spd combo, when in spin mode, it smells like melted crayons
If drain hose is connected to a standpipe check that it's inserted no more than 4". You may be getting a syphoning situation that is allowing gray water to contaminate clean clothes.
Jan 06, 2013 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Kenmore heavy duty washer runs does not spin
check out the security switch located at the lid , it could be defective , with a multi meter check for continuity, thanks AJ
Dec 12, 2009 | Computers & Internet
Washer did not spin
JERRY,
IT SOUNDS LIKE YOU GOT TAKEN ON THIS WASHER. A NEW WASHER NORMALY WORKS, BUT IN SOME INSTANCES, LIKE YOUR CASE, IT COULD BE THE BELT OR THE MOTOR COUPLING. WHAT I WOULD DO IS CALL THE PLACE WHERE YOU GOT YOUR WASHER FROM AND HAVE THEM TO BRING YOU A NEW REPLACEMENT. THERE HAVE BEEN COMPLAINTS ABOUT WASHING MACHINES NOT WORKING RIGHT WHEN THEY WERE NEW. I HOPE THIS HELPS YOU AND ANYBODY ELSE WHO READS THIS WEBSIT, BECAUSE THERE IS NO SENSE IN THE STORE SELLING A BRAND NEW WASHER WHEN IT ALREADY LEAKS.
RODNEY
May 14, 2009 | Crosley CAWS729MQ 3.2 cu. ft. Washer
Speed Control only works in Heavy Duty
sound like your motor is going out ,,,, the wiring at the motor may also be loose from out of balance loads
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
