Question about GE Advantium 120 Convection/Microwave Oven
My advantium 220 just stopped working. There is no power.No lights display is blank. It is about 9 years old
  • 572 Answers
Check power. if good then check for fuses inside unit
Posted on Feb 07, 2010
Our Advantium 120 oven (model # SCA1001KSS 02, Manufactured June 2008)is not working. Began w/ time not coming on when cooking and just a little green microwave light shows while cooking.
Typical of a control microchip failure caused by a power surge. With a microwave as old as yours, it is safest to simply replace the entire oven rather than attempt to fix it, as older magnetrons are likely to fail.
May 05, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
Display is blank
If the display is blank, and the oven works, 9 times out of 10 it is a problem with the circuit board that drives the display.
Apr 16, 2014 | GE Advantium 120 Convection/Microwave Oven
My GE Advantium SCA1000HSS LED display is blank. The display just went out one day when I opened the microwave door. I can microwave using the "add 30 second button". Also the timer works if you...
Sounds as though you'll have to replace it again. There isn't much else it can be. Is there a chance that the house is not well grounded? Lighting and the such can do this.
given the cost of parts....Look to price shop a new one before fixing this one.
Jan 31, 2011 | GE Advantium SCA1001HSS Convection...
My Advantium over is approximately 9 years old. I heated up broccoli last night for dinner and then it just went out. There is completely no light on showing the time and I checked the breaker switch. Do...
check the wall socket to make sure you have electricity to the plug. Secondly then check to see of the appliance "fuse" has blown, simple repair. If not, you have a costly serious issue.
Oct 07, 2010 | GE Advantium 120 Convection/Microwave Oven
I have a 220 Advantium. I love it and it is 8 years old. When I tried to cook in it today it made a louder vibrating noise, almost like a grinding sound. Not sure that it was cooking because I stopped it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 01, 2010 | Westpoint TV-201 Microwave Oven
Hi, my problem is with my GE advantium speedcook microwave oven. When using 'speedcook' feature, the oven starts, then there is sparking inside the circuit board area, followed by a loud POP, and this...
  • Select the "Options" menu and adjust the clock display settings if the display is blank. Set the clock if the oven won't start. The clock must be set for the oven to work properly, as oven programming is dependent on the clock.
  • Close the door tightly if the oven won't start. The oven won't start if the door isn't closed. You can identify from the lights whether the oven failing to start is related to the door or to the power supply. If the control panel is illuminated and interior lights are on when you open the oven door, you can be sure the oven is receiving power and any starting problems are due to the door not being closed tightly.
  • Press and hold the "Clear/Off" button if the oven performs strangely. Be sure to hold it for a few seconds. This will reset the GE Advantium.
    But as you mentioned that there is /was a loud noise this is a indication of the unit make any usual noise (groaning, gurgling, etc.?) or was / is it either louder or quieter than normal?It may be as simple as the top door switch or its mount or it may be a bad magnetron or shorted diode.
    For manual of the oven.please click the link below:--
  • http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40577-1.pdf
  • Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • Aug 12, 2010 | GE Advantium 120 Convection/Microwave Oven
    Advantium 120 (Display Pad is not Illuminated or Working)
    try removing the touch pad/switch membrane and cleaning connections on ribbon cables. if problem still exists replace switch membrane.
    Phil
    Jun 11, 2009 | GE Advantium 120 Convection/Microwave Oven
    Blinking display of advantium m/w oven
    by unplugging the m/w for a few minutes and then replugging the problem is gone.
    May 29, 2009 | GE Advantium SCA1001SS Convection /...
    GE Advantium 120 Convection/Microwave Oven Logo
    343 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Shekar Avadhani
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
