Question about Eforcity Apple iPhone 3GS 16GB / 32GB Screnn Protector W/ Micro Fiber Cleaning Cloth
My iphone 3gs battery life spam very short even just finished charge..
My iPhone 3GS will not stay charged even though I had a new battery installed.
Have you tried removing things such as Push email and turn on fetch email this really helps with the battery life also the Brightness setting have them set half way
Nov 28, 2012 | Cell Phones
Tip
Tips and Hints on How to Maximise You iPhone 3GS Battery Life
1. Turn Screen Brightness down to less than a half and turn on Auto Brightness. (Settings - Brightness).
2. Turn off Location Services when you are not using a GPS dependant App. If on a long journey using the iPhone's GPS, only turn the App and the service on every so often. GPS based Apps really eat battery life up!
(Settings - General - Location Services - Off).
3. Turn off Fetch Data. With this feature enabled the iPhone will interrogate the internet or your mail account every so often to fetch data, for example, an e-mail. This drains battery life. (Settings - Mail Contacts - Calendars - Fetch New Data - Push Off).
Or if you really want to keep this feature, just follow the same protocol as above , but instead of switching "Push" off, below that, adjust Fetch Data settings, to fetch on a less regular basis ie Hourly as opposed to every 15 mins.
4. On long journeys when all you need is the iPod functionality, turn Flight Mode on.
(Settings - Airplane Mode Off).
5. Remember to run the battery completely flat every so often. I do it around once a month and then fully charge it again.
6. Turn Bluetooth off.
(Settings - General - Bluetooth Off).
7. For those of us who have an iPhone 3GS or updated software on iPhone, switch on the Battery Percentage for better battery monitoring. (Settings - General - Usage - Battery Percentage On).
8. If you are fairly desperate for battery you can turn off the 3G feature of the iPhone. 3G enables higher browsing speed and better call quality. (Settings - General - Network - Enable 3G Off).
9. Turn Wi-Fi off if not in use. The iPhone will use battery searching constantly for Wi-Fi networks. (Settings - Wi-Fi - Wi-Fi Off).
10. Remember, if you really can't manage with the battery life, you can buy iPhone cases which provide extra battery power.
Good Luck
on Feb 08, 2010 | Apple iPhone Smartphone
My iphone 3gs those not charge what could be the problem
go to the iphone shop buy a new charge.maybe the charge don't match the battery.
Sep 12, 2012 | Apple iPhone 3GS Black (16 GB)
Why does iPhone 3GS shut off unexpectedly?
dear,
It can be the problem of charging circuitry in your cell phone. Please get it repaired by a mobile repair tech from a repairing shop.
best of luck!
Feb 16, 2012 | Apple iPhone 3GS Black (16 GB)
What is the differeance between iphone g3 to phone gs3?
the main difference between the iphone 3g and iphone 3gs is the speed. but here are the specifications for both phones
weight: the 3gs is slightly heavier at 135g memory: iphone 3g only has two options an 8gb or a 16gb whereas for the iphone 3gs it has 8gb/16gb/32gb camera: the iphone 3g has 2mp camera that can only take pictures while the ihpne 3gs has a 3.15mp camera that can also capture videos cpu/processor: iphone 3g has ARM 11 412 MHz, PowerVR MBX-Lite graphics while the iphone 3gs has 600 MHz ARM Cortex A8 processor, PowerVR SGX535 GPU. So the 3gs is faster and it means less or no lag on apps
the 3gs has a digital compass
and the 3gs has a longer battery time than the 3g.
to summaarize, the iphone 3gs is faster, has longer battery life, and has a bigger memory (as it comes with a 32gb version).
Apr 24, 2011 | Samsung Omnia Pro B7320 Smartphone
My iPhone 2g is heating up and losing battery even though i am not using it its hotter when i am charging it but if not is not that hot but it lose battery so pass if i fully charger it it will last for...
It's possible that there is a short in the battery cell and/or that you got water in the divice. My experience with Apple is that their customers are #1. Give them a call and they should at least get you to a point of if they will fix it for free or how much it will cost you.
Mar 24, 2011 | Apple Iphone 2g 3g 3gs 8gb 16gb S
Quick discharging of the Iphone 3gs battery
Yes its normal. To maintain the most power adjust your brightness bar down to 1/4 or 1/2. Keep the push mail function off when you don't need it. Don't recharge the battery until the unit shuts itself off. Then recharge the battery to max before using. This is called conditioning the battery, even though many say you don't need to on lithum ion batteries because there is no memory effect. But their full of sh.t, cause you do the first time you get the battery and should do it once a month to extend the life of the battery.
Feb 04, 2010 | Apple iPhone Smartphone
Poor cell reception and short battery life
UNLOCK YOUR IPHONE FOR ONLY $19 WE CAN UNLOCK IPHONE 3G 3GS 2G, EASY STEP BY STEP TUTORIAL VISIT US AT WWW.UNLOCK-IPHONE.ORG
Sep 29, 2009 | Pantech Matrix Cell Phone
Open Questions:
Eforcity Apple iPhone 3GS 16GB / 32GB Screnn Protector W/ Micro Fiber Cleaning Cloth Logo
74 people viewed this question
Top Eforcity Cell Phones Experts
Computer Repairing
Computer Repairing
Are you an Eforcity Cell Phone Expert? Answer questions, earn points and help others
