Question about Whirlpool LER4634J Electric Dryer
I have a model LER4634PQO electric dryer--it runs but will not heat. Mike
  • 5,911 Answers
If your dryer runs, but does NOT heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare.
NOTE: In many cases the problem is NOT the heating element. The heating element has protection devices that are designed to regulate the heat temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem. Read through the information I provided and take resistance checks to be sure.
If you have any questions, please post back and let me know. I hope you find this information is helpful.
Posted on Feb 07, 2010
    Problem Solver:
  • 16 Answers
I think you may find that the heating element which consists of a long "spring", has broken it's connection somewheres. If you look close at the spring you may find it, you can just take one end and twist it to the other to make a connection and should work. If it does you may want to consider replacing the element as it'll probably happen again someday due to age and weakness (rust, etc...) Very common and has worked for me often (on Kenmores mostly)...
Posted on Feb 27, 2010
Whirlpool dryer - ler4634pqo Runs fine but won't heat or shut off. Happened at same time.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 06, 2011 | Whirlpool Dryers
I have a Commercial Quality Whirlpool model LER4634PQo 4 cycle/ 3 temp electric dryer. The drum turns but it's not producing any heat. it's hooked up to a double breaker. It worked...
The most prominent things to go out causing the dryer to not heat are, thermal cutoff,high limit thermostat,heat element & cycling thermostat. All of those in the rear of the dryer and be checked with a meter set a low ohms setting and check all listed parts for continuty. THe picture shows locations of all those parts. The only one in the picture that has nothing to do with it not heating is the THERMAL FUSE,the thermal cutoff is different from the thermal fuse. If all those check good i would suspect the TIMER as being the problem but most likely it will be one of those on the back as pictured.
Good luck,i hope i have been able to help you determine why your dryer won't heat...GENE
Aug 15, 2011 | Dryers
My ler4634pqo dryer has no heat. I have taken the back panel off but do not know how to locate the fuse.
heatman101
Jun 26, 2011 | Whirlpool Dryers
I HAVE A WHIRLPOOL DRYER MODEL LER4634PQO...IT WON'T STOP RUNNING WHEN IT GETS TO END OF CYCLE AND IT DOES NOT HEAT UP
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 10, 2011 | Whirlpool Dryers
ITS MODEL number ler4634pqo
take a clothes hanger and try and remove it
Apr 21, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Whirlpool model LER4634PQO dryer. Will not heat. Dryer also will not shut off. Timer is running but will not shut off at the end of cycle. Can manually shut off and opening the door also shuts dryer off.
96f3244.jpgEither the top limit or the element is open, that is why the timer motor is not advancing. The small wire on the bottom limit powers the timer motor. The fuse is not blown because the dryer runs. The fuse has smaller wires and is tied into the door switch wiring and when it blows it is as if you opened the door. If the top limit is dead it is because of a vent blockage. I have repair photos HERE
Feb 28, 2010 | Washing Machines
Whirlpool dryer LER4634PQo won't heat up
if it spins
its more than likely just your heat package
ive included the national part number
you can order it through sears
4391960 42.00
Oct 06, 2009 | Whirlpool LER5636P Electric Dryer
LOUD NOISE WHILE DRYING
remove the back cover that covers the lint trap. there is a fan blade back there and some foreign object is probably hitting the fan blade
Jan 01, 2009 | Whirlpool LER4634J Electric Dryer
My roper dryer is not heating
YOUR HEATING ELEMENT IS BAD OR YOUR HEATER BOX FUSE IS BAD,IF YOU HAVE A METER YOU CAN CHECK THEM BOTH-LET ME KNOW-MIKE
Dec 06, 2008 | Roper REX4634KQ Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
582 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
