Question about Kenmore 42822 Front Load Washer
Drum does not agitate water goes in and it just humms, no agitation or spin
    President:
  • 1,554 Answers
The drive belt is broken or the motor's rotor is stuck. Open the door and rotate the drum manually. The drive belt is worn or broken if you can freely rotate the drum. The rotor is most probably stuck if you cannot turn the drum.
Visual check can be done by removing the back panel. Remove the screws holding it to the cabinet and pull it off. Replace the belt if it is worn or broken. Simply wrap it around the drive motor pulley and on one side of the drum pulley. Rotate the drum pulley in such a way that the belt completely wraps around it.
Try to free the rotor if it's stuck by lubricating it and forcibly turning it back and forth until it turns freely. To remove the motor, disconnect the motor wiring harness and ground wire from the terminals and remove the mounting bolt. Pull the motor out of the mounting slots. To reinstall or replace, simply slide it back into the mounting slots and secure it with the mounting bolt.
In some cases, the drum will not spin due to a broken drum pulley. Post it back if that is the case.
Posted on Feb 07, 2010
2 Suggested Answers
  • 219 Answers
SOURCE: LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
Posted on May 21, 2009
This is for an LW7503W2B washer. We have water on the floor during agitate with large loads. The water is comming over the edge of the tub. I have noticed the tub rotates in what I would call a slow...
I had the same problem. You need a brake kit. it holds the drum still while in the agitate mode. the centrifical force of the water during that slow spin is causing the water to spill over the top of your drum. easy and cheap fix.
Oct 18, 2010 | Amana ALW780QA
Agitator humms and won't move
It hums since the motor is still working. However the mechanism for the agitation is not working due to the helix part worn out. Need to replace it. If the service man is coming, have him to check the spinning mechanism also, since the same labor for the 2 mechanism. if the agitation mechanism worn out then the spinning mechanism is going to wear out soon. Now keep in mind that the clutch and the brake for the spinning mechanism are hardly worn out, only the part pushing up to release the brake is worn out. Keep this in mind to prevent overcharged.
Jan 09, 2010 | Dryers
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine will not fill with water. only agitates. will drain and will not spin only humms
unit should not agitate with no water. pressure switch has to be satisfied to begin wash cycle. what kind of washer?
Jun 21, 2009 | Washing Machines
GE Profile Washing Machine
There is a clutch which is mechanically engaged to stop the drum during agitation.
If the location pin is worn or bent it fails to engage and the machine tries to wash and spin at the same time.
Only solution is to call for a man who can fit a new clutch assy
May 25, 2009 | Washing Machines
May 20, 2009 | Maytag PAV2300 Top Load Washer
I have a lg wm2277hw agitator problem
I had this happen on mine, and it was the valve that dispenses the water into the drum. I wasn't getting any water into the drum because the dispensing valve/solenoid was not working. I've had to replace it 3 times in the past 5 years though.
Dec 02, 2008 | LG WM-2277HW Front Load Washer
Washer fills wont agitate or spin
supposed to be a problem only with water level switch.
hhhmmmnnn...
try checking the hose that goes from the bottom end to the pressure switch. if there is a hole or a crack or anything loose on the connection. if the pressure won't build up on the water level switch, it wont transfer the contacts to start agitating.
test the water level switch by pulling the hose from the drum end and blow unto it until you hear a click on the water level switch. this should turn your agitator so please be careful and watch out for parts moving rapidly.
tnx 4 using fixya,
drcool
Oct 28, 2008 | Maytag Washing Machines
Will agitate, but will not spin
hover gemini. mod.A6516-010 will agitate but will not spin.thanks .henry
Jan 01, 2008 | GE WDSR2080D Top Load Washer
Kenmore 42822 Front Load Washer Logo
173 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
