Question about Alpine CDA-9887 CD Player
I have a 04 jeep grand cherokee. Wiring harness and adapter have two yellow power wires. Alpine only has one. Do I hook them both up?
    Sergeant:
  • 306 Answers
Yes thats fine. they should be right next to each other in the harness.
Posted on Feb 07, 2010
Alpine wiring diagram
If you contact Alpine they will be able to tell you if there is an adapter that will plug right into your existing OEM harness. If not then, you'll have to figure out Which wires are which on your OEM harness, here is the Alpine wire code:
Alpine wiring help
HU harness color code pretty much universal.
red=ignition
yellow=battery +
black=ground
blue/white=remote turn on
blue=power antenna
pink/black=audio interupt in (not sure if you have one)
speaker wires
gray=right front
violet=right rear
green=left rear
white=right rear
speaker wire with black stripes is negative.
Sep 29, 2016 | 2011 Dodge Ram Pickup 1500
I have a 1998 Toyota Camry...Trying to hook up an Alpine...Need to know what wires to connect to the alpine.Car Wires are same with grey spots.....
From what I can tell you cut the wires to your factory wiring harness and that is what you want to hook up to. My advice is to reconnect the factory harness and buy the adapter harness for your car and use that to hook up to the alpine it will save you hours and possibly your sanity. If you want to hook up directly to your car without the adapter you will need to figure out what wires are the power ignition and ground with a multimeter or power light. Easiest way to find ground is to just put in a ground wire with in a foot or so from the deck. Then it's just a guess and check for the correct placement of power. I suggest turning the power placement on the deck to what speaker you want and repeat for all speakers until your finished. Or you can buy a Chiltons or Haynes manual the should have a wiring diagram
Sep 03, 2014 | Car Audio & Video
Rear light wiring schematic for 1994 jeep grand Cherokee
They make an adapter that plugs inline of the tailight harness so you dont have to cut into harness
Aug 26, 2012 | 1994 Jeep Grand Cherokee
I am looking for the diagram for the ignition wiring on a 1996 Jeep Grand Cherokee Laredo
Here's what I found;
Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness
Sep 15, 2011 | 1996 Jeep Grand Cherokee
Power windows and door locks not working on my 2004 jeep grand cherokee
Check the wiring harness from the door jam to the door pull back the rubber boot and check wiring harness for broken wires and splice as necessary. Had the same problem.
Mar 14, 2011 | 2004 Jeep Grand Cherokee
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
Windows do not work, locks do but not drivers side/ please advise grand Cherokee 04.
1. Check the fuse that supplies the power windows.
2. If the fuse is good, then check the wiring harness that passes to the drivers door. If there's a broken wire, power will not be supplied to the windows and they won't work.
Let me know what you find.
Nov 08, 2010 | 2004 Jeep Grand Cherokee
Where is the wiring harness located on a 1997 Jeep Grand cherokee
On factory installed trailer package. The harness is located on right rear quarter panel back (inside) The trailer connection is just below the bumper. This harness can be purchased at your jeep dealer
May 14, 2009 | 1997 Jeep Grand Cherokee
Alpine CDA-9887 CD Player Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
