Question about Kenmore Elite HE4 Electric Dryer
Need to know were the fuses are located. the dryer runs but does not have heat.
  • John Tripp
    John Tripp May 11, 2010
    Will need the sears model number. For example 312.56489 That will allow me to give you or another technician away to see the diagrams. There are just too many variations of that model Elite is a GE Brand name. I am a Sears Parts Dealer and trust me they would not be able t tell you were or what without that number. I could also help you better by sending where that number is but they shut down their parts site. at 1: AM untill about 4 AM Thanks, Sea Breeze
  • Debra Galmish Apr 14, 2013
    How to test switches and where are they
  • Kenmore Master
  • 4,654 Answers
And Fixer1950 you are very correct. When a person has no model number you can not show location, diagrams, part numbers diasembly or assist in testing. Fuses most times burn out when air flows leaving the dryer and is restricted due to blocked air flow From the looks of what the customr said was were is the fuse. With part numbers you can lay out where the fuse is and the heating element some models have a trick to open where these are. And diagrams are availiable only with the correct model number. Just one hole in the lint screen sends loads of lint into the dryer eshaust and then moisture clngs to the lint to the point of no air flow. A few times like this will take out the fuse. When the heating element does it not continue too tumble? And even without a models number is to guess. Fixing the problem is first done with the model number. From there is easy, Sea Breeze
Posted on Feb 07, 2010
    President:
  • 2,976 Answers
Rathen than looking for fuses, it sounds more like your heating element is burned out.
Where is the fuse located ?
The fuse is located on the blower housing next to the thermister (heat control). You won't see it till you get filter housing off there:
The 3 vid down shows how to get into it HERE on my blog
Jul 07, 2012 | Kenmore Elite HE4 Electric Dryer
Dryer runs but won't heat. I need to check the
there is no fuse, you need to replace heating element
Oct 24, 2010 | Frigidaire GLEQ332A Electric Dryer
On the Kenmore series 90 electric dryer, where is the thermal fuse located.
The Thermal Fuse is located on the air blower housing. Its a small white plastic component with two wire leads.
The Thermal Cut-Out (TCO) is located on the outside of the heater box on the end opposite the heating element terminals.
The reason I mention both these components is because some people confuse the two and use the words interchangeably. There is a difference between the two components and what they do.
DOUBLE CHECK YOUR SYMPTOMS:
If your dryer does not run at all, check your Thermal Fuse.
If your dryer runs, but does not heat you need to check the Thermal Cut-Out.
If you have any questions, please post back and let me know what symptoms you are having. Please include your complete model number (located on a nameplate around the door opening) so that I can determine how your dryer is configured. I hope this is helpful to you.
Jan 06, 2010 | Kenmore 73952 Gas Dryer
Turns no heat continues to run? roper dryer model # red4340sq1
you need a Thermol fuse. This part is a non resetable fuse. you will need to replace it. it is located in the back of the dryer. you will need to take off the back panel. let me know if this helps
Oct 12, 2009 | Roper REX4634KQ Electric Dryer
How do I get to the thermal fuse on Whirlpool electric dryer LER4634EQ0
All the heating and temperature control components are located in the back of the dryer. To access, unplug the dryer and remove the exhaust vent hose. Turn the the dryer around so you can view the back and remove the back panel. With the panel removed, the component locations are as follows:
Right-Hand Side:
1. Heating element - located inside the heater box. If bad, the dryer will run, but will not heat. A good reading is about 9 to 13 ohms.
2. Thermal Cut-Out (TCO) - located on the outside of the heater box on the end opposite the heating element terminals. If bad, the dryer will run, but will not heat. A good reading is a short (0 ohms).
3. Hi-Limit Thermostat - located on the outside of the heater box adjacent to the heating element terminals. It works in conjunction with the TCO to help regulate the drum internal temperature. A good reading is a short (0 ohms).
NOTE: If either the TCO or Hi-Limit Thermostat are found to be defective, it is recommended that you replace BOTH components to prevent premature failure. These two components are commonly sold as a set.
Left-Hand Side:
1. Thermal Fuse - located on the blower fan housing. It is a small white plastic looking component with two wires attached. If defective, the dryer will not run at all. If the component is good it should read a short (0 ohms).
2. Internal Bias Thermostat - located on the blower fan housing adjacent to the Thermal Fuse. It has four wires attached to it.
NOTE: All resistance checks should be performed with the component terminal wires disconnected to prevent false readings.
If you have any questions, you can refer to searspartsdirect.com for some helpful exploded view diagrams to assist you. The components I mention are listed under the "Bulkhead" heading as follows:
Item 6 - TCO/Hi-Limit Thermostat replacement kit
Item 15 - Hi-Limit Thermostat sold separately
Item 17 - Heating Element
Item 23 - Thermal Fuse
Item 24 - Internal Bias Thermostat
If you need further assistance, please let me know. I hope this helps you.
Sep 23, 2009 | Dryers
GEW9200L runs but won't heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting
Jun 21, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer run won't heat up took off back panel don't know which tube contain element. if that not the problem don't know where to locate thermal fuse i need pictures diagram illustration
Hi, if this is an electric dryer and is a whirlpool model, the element is located in a housing on the right side (looking at the back)
You can run the dryer and check with voltage meter to see if it is getting 240V. If there is voltage, replace the element. If there is not voltage, check the thermostats and the fuse for continuity. If they do not have continuity, replace them.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 30, 2009 | Dryers
Dryer won't heat
whats going on w/ dryer,,slow heat? no heat at all cool running slow heat (exhaust problem)check exhaust hose,no heat thermal fuse depends were lint screen is located on top fuse on ,,lint screen inside dryer behind blower housing ,,,
Nov 29, 2008 | Dryers
FRIGIDAIRE DRYER
I don't know what you mean when you ask about fuses since a blown fuse would stop power to the dryer, but I do know a common reason for a dryer to run and not produce sufficient heat is that it may be cycling on the "safety" thermostat. One common reason for this is that the "cycling" thermostat (which is the thermostat which the dryer should cycle on), located in the exaust air stream, is insulated with collected lint, which also lowers the air flow through the ducts. You may just need to thoroughly clean the accumulated lint. I would suggest buying the service manual for your dryer, if available, and go to the manuals troubleshooting guide.
A test for cycling on the safety thermostat is to run the dryer with a damp load and watch the flame through the small service door at the bottom of the dryer; if the flame stars cycling on and off every, say 15 to 30 seconds, then the dryer is cycling on the saftey thermostat, if the flame repeatedly burns for close to a minute or longer, than that is not the problem.
Feb 02, 2008 | Dryers
Gas dryer lgr4634eqo GAS
check the thermal fuse located at the back of the dryer for continuity and let me know how you make out
Sep 13, 2007 | Whirlpool LGV4634JQ Gas Dryer
Kenmore Elite HE4 Electric Dryer Logo
187 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
