Question about ASUS LCD Monitor
Speakers work but no microphone theres no place to plug in into the new monitor
  • judith_chapm Feb 07, 2010
    I have the cord, but there is no where to plug it into the monitor, there is only one green cord for audio, it is plugged in but still the microphone doesnt work
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 28 Answers
Try to find your mic input at the back or front of the CPU..it has also a output also...
the coor of mic input usually color pink and output sound is green...
Posted on Feb 07, 2010
After unplugging my computer for a week, the sound on my CLT 190 LX computer monitor didn't work, even though I tried several sound sources from online as well as MP3s on my computer. The headphone...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
May 10, 2011 | Computers & Internet
How to I get the speakers inside monitor to work?
I recently was given a MAG Model 780 too. I found the input for speakers just today. When looking at the monitor, on the left side behind the monitor you should be able to feel a flat horizontal surface. If you lay monitor down, you will see 2 mini-plug openings. These are your input spots for speakers/microphone. I believe pink is speakers & green is microphone.
Apr 13, 2011 | Mag Innovision InnoVision LT765 17" Flat...
Is this monitor compatible with a microphone?
Hey there,
This monitor has built in speakers, but does NOT have audio input for a microphone.
Mar 08, 2011 | Compaq FP 7317 17" LCD Monitor
No inlet on my computer for my X223W LCD Monitors audio cord.
Is the monitor supplied with inbuilt speakers..? Most monitors no longer have inbuilt speakers and this is why there is no place to connect the audio cable. You will have to purchase a set of external speakers and connect these to the audio output of your system.
Dec 27, 2009 | Acer 22" X223w LCD Monitor
Headphones
Welcome to the computer age. I looked up your HP W1907 monitor. It comes with a built in microphone and speakers but no audio jack for plugging in headphones. You will need to find an audio jack on your computer tower. Most new computers have audio and microphone jacks on their front face. In most cases there will be a picture of a microphone or headphones next to the jack to tell you what it is. If you can't find one on the front, look in the back. The audio jack is usually color coded green. I hope this helps you out.
May 20, 2009 | HP w1907 LCD Monitor
No place to plug in my speakers
Monitor plugs in 3 times?
1] power 2] video 3] sound???
use audio cable from desired speakers rather than for the monitor.
Mar 21, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Speakers - monitor E15T4
Every monitor doesn't have a place to plug speakers, does the monitor have speakers built in? You may have to plug your speakers up directly to the computer, imagine that!
Oct 25, 2008 | E-Machines eMachines Monitor E15T4
No sound on new LG Flatiron Monitor
You need to get a set of powered computer speakers!
I always found that stand alone speakers are much better than the ones in the monitor.
Jerry G.
Apr 30, 2008 | LG Flatron L1919S LCD Monitor
Compaq monitor speaker
If everything worked before you moved it, I would try checking the simple things 1st.
Make sure that the plug from the speakers is plugged into the correct hole in the back of your computer. Usually, the color of the plug for the speakers and the jack are GREEN.
If the power isn't coming on the speakers, then I would make sure that you have the correct power plug (If the speaker type that you have, has a removable power supply).
What you can to to test out the speakers, is plug the speakers into an IPOD or a MP3 player and test it out.
This will at least eliminate the possiblity that the speakers/wires/power supply are bad.
Hope this helps.
Good luck.
Feb 08, 2008 | Compaq PC Microphone (Black or Beige)...
ASUS LCD Monitor Logo
164 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
