Question about Brother HL 2140 Laser Printer
My printer is not letting me print, it doesn't print at all
    President:
  • 1,561 Answers
First thing to do is to test print to see if it will print, if it does, check if your system sees the printer, if no, install the printer driver or software on your laptop or system but if your system sees the printer, i suggest you uninstall the driver and reinstall it back.
Make sure you select the printer and is set to print online.
Another area you can look at is the cartridge, check if the tonal is till filled up to allow you print, if it is not refill the cartridge or replace the cartridge.
Best regards.
Posted on Feb 07, 2010
Wont let me print
Sounds like your puter has lost contact with the printer. Unplug the USB or Parallel cable and reconnect. If that doesn't work, you may need to reinstall the printer driver.
Jan 22, 2012 | Ricoh Office Equipment & Supplies
Tip
How to clean the printer heads
When it comes to printer issues, there are few things as frustrating as expecting a clearly-printed document and ending up with something that looks like a cross between a Picasso and a Rorschadt blot. If you notice that the print quality of your documents has decreased considerably or if you are bringing an old inkjet out of retirement, you need to clean the print head to ensure you?re getting the best from your printer. A dirty or clogged print head will hinder a regular flow of ink from the ink cartridge to paper. The first step is actually knowing where the print head is and what it does. As you print a document, ink droplets leave the ink cartridge through the cartridge?s nozzle and go to the print head. The print head then lays the ink on a precise point on the paper. As you print, tiny droplets of ink can get stuck around the print head opening. If these drops get time to dry, they can form a crust around the print head opening and cause it to print poorly. Clean It With Software There are a few ways to go about cleaning the print head. Potentially, the easiest way is to let your printer clean itself. Many inkjet printers will have maintenance options in the printer?s software that will actually clean your printer for you. We used a streaky Canon BJC-80 for our testing, and the driver we installed on our system for this inkjet had quite a few maintenance options. (Keep in mind that the process for cleaning your specific printer?s print head may be slightly different than what we?re describing here.) To check these out in Windows XP, click Start and then Printers And Faxes. Right-click your printer and then Printing Preferences. This displays the Canon Bubble-Jet BJC-80 Printing Preferences dialog box, which houses various layout and print-quality preferences, as well as the printer?s maintenance options. Click the Maintenance tab to view what your printer can do from a software perspective. Our printer has two cleaning modes?Cleaning and Deep Cleaning. Cleaning isn?t quite as time-consuming as the Deep Cleaning mode, but Deep Cleaning mode does a more thorough job and can resolve some issues that the normal Cleaning mode can?t. Just click the proper cleaning mode to start it and let the cleaning process run its course. You may have to do this a number of times to get the print head clean. If you don?t see a maintenance tab, it doesn?t necessarily mean your printer doesn?t have a self-cleaning function; it just means that it doesn?t use commands from your computer to do it. For instance, on the BJC-80 you can also start the cleaning process by holding down the Resume button until you hear two beeps. Check your printer?s manual for ways to clean your print head. Clean It Yourself Some software bundles that come with printers have cleaning functions that you can use to clean your print head. If the built-in cleaning functions don?t seem to do the job, there are a few ways to clean your print head manually. Some swear by isopropyl alcohol, while others believe in just plain ol? water. When used correctly, either can help your printer perform better. First, remove your ink cartridges from your printer and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink. Some printers, such as many Canon models, feature removable print heads that give you easy access to the print head and its nozzle(s). Many other inkjet printers don?t have this feature, so you?ll have to do your best to work around parts in your printer. Be careful, especially if you use isopropyl alcohol to clean your print heads: Some printers use rubber gaskets; if you get isopropyl alcohol on the gaskets, it could dry them out. If you have a removable print head, remove the ink cartridge from the print head and take the print head out of your printer. Put some isopropyl alcohol or hot water into a saucer and set the printer head in the saucer. Let it soak for at least an hour. If it?s really dirty, it might be a good idea to let it soak overnight. Let it air dry, reinstall it in your computer, and run a cleaning cycle. This should get rid of any dried ink that was loosened during the soaking.
on Apr 21, 2010 | Office Equipment & Supplies
My finished print is nearly to small to read. need to increase size of print
Go to File > Print Preview and at the top of the screen that pops up there is a place where you can bring up a drop down list which lets you choose shrink to fit as well as a wide variety of percentage increases or decreases. If this doesn't help go to File>Print> and then click on Preferences on the screen that comes up check your printers settings. Don't forget to look at what size paper the printer thinks you are using and see if your printer has settings for how many pages to fit onto the document. Let me know if this was helpful.
Sep 30, 2011 | HP Deskjet F335 All-In-One InkJet Printer
Yellow is completely missing from the nozzle check. However, I was able to print a sqaure of solid yellow ??
More than likely, your print heads need cleaned. Remove any dried up ink from the inside of your printer with a Q-Tip and some denatured alcohol. Let everything dry and put it back together. If that doesn't do the trick, you either need a new ink cartridge, or a new printer.
Jul 27, 2011 | Epson Stylus 1400 InkJet Photo Printer
My printer won't print. my computer is hooked up to it, and it doesn't give any error messages. it just doesn't do anything.
Go to Control Panel/Printers. Right click on your printer's name, and hit Print Test Page. If printer prints a page out, then the problem is likely with the software you're using to print - make sure you have selected the right printer in the dropdown. If the printer's name doesn't show in the Printers folder of Control Panel, the driver for it has not been installed. Do so and try again.
Jun 18, 2011 | Lexmark X2670 All-In-One Printer
No content prints on document when word document is sent to the printer
Is the problem only with Microsoft Word? If so you might have selected something else in the "Print What" box in the "Print" dialog box instead of "Document". See the below screenshot and make sure that the "Document" is selected. The Print dialog box will come up when you click the "Print" sub-menu from the "File" menu, i.e. click "File" and select "Print".
If this doesn't help, reinstall the printers drivers/softwares. That should fix your problem.
If the problem isn't only with Microsoft Word Documents, then there might be other problems with your printer, it could be cartridge/s, ink, drivers, etc..
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 14, 2011 | HP Officejet 6500 AllInOne InkJet Printer
I can't print an alignment page from my computer. How do I align my computer?
Alignng your Lexmark:
1. Load paper in the paper tray.
  1. On the control panel, press Mode repeatedly until Copy is selected.
  2. Press Options until MAINTENANCE appears.
  3. Press + until Align appears, and then press Select.
An alignment page prints. Once this page prints, your automatic alignment is complete.
This works on Lexmark Printers, if it doesn't let us know what model you have.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 20, 2011 | Lexmark All-in-One Printer with PictBridge
How can i clean a printer
Apr 30, 2010 | HP LaserJet P2015dn Printer
How do I clean my printer heads
Apr 08, 2010 | Epson Stylus C86 InkJet Printer
Not printing on last copy
My guess is it?s probably the print head. These things are designed to print on single sheets so even though it?s probably well within specs it still doesn?t have enough force to push an image to the last page. Less likely but never the less a possibility this could also be caused by inconsistent paper in the two boxes. Continuous feed, multi-part forms in a box are made by several manufacturers and have different characteristics. -You might try flipping the box of forms from the printer that works to the one that doesn?t just to make sure it?s not the forms. When I used to use multipart forms we would place orders for several boxes of the same form and occasionally some would be from a different manufacturer. The paper looked the same but the characteristics were way different. By the way we tried to do four-part but could never print beyond three part forms. Our fix was that we decided we only needed one in-house copy. -If the problem doesn?t follow the paper then I would suspect the print head. Panasonic print heads are fairly easy to replace and fairly inexpensive so I would try changing it out. With a lot of use the print heads do wear out so even if this doesn?t solve this problem you?ll have a spare when your vertical characters start looking wavy?. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 14, 2007 | Panasonic KX-P2023 Matrix Printer
Brother HL 2140 Laser Printer Logo
136 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
