Question about Samsung Rugby SGH-a837 Cell Phone
The battery runs down at the end of the day when i dont even use it
Code p1610 & p1611
Dont know where you found these fault codes but their not in my nissan list or the universal codes ,no my main suspect is the alternator diodes now charge the battery and then disconnect the alternator wires and see what happens when car is left for a few days
Jan 29, 2014 | Nissan Micra Cars & Trucks
I have 2001 acura 3.2tl with 200,000 miles on it. it runs fine i did a tune up used original spark plugs, new air filter and i even changed 4 ignition coils. Only problem i had with this car is when...
Plug the block heater in , End get a good battery for it, get awinter battery, Not a california battery, Then it might start, If the engine has seen it,s better days, End don,t use snake oil in it, Use real oil.
Nov 10, 2012 | 2001 Acura 3.2TL
Do you charge the gator's battery at the end of the day every day it is used or only when the battery goes completely down?
its a good idea to charge each time its used, but thats not realistic for most so definitely dont leave it for long periods totally dead or outside in freezing temps and it will last easily 3-4 summers!
Dec 25, 2010 | Peg Perego John Deere Gator HPX Ride on...
My 2006 Volkswagen Toureg keeps running down batteries. Even after you've replaced with a brand new battery, it runs down after a few days. Have done a full system scan, and nothing was found
this is where an electrical tester is needed,to check the fusebox etc for any current drain when ignition is off.
good hunting,last time i did one of these it took two whole days...
Aug 19, 2010 | 2006 Volkswagen Touareg
New battery but car dies
See if you can find someone with a multimeter and hook it up to battery, to see what voltage it reads before you try to start it, then write it down.Now boost it or whatever you have to do to get it running, and check voltage & record it with engine running. Voltage should be higher when engine running, approx 13.5 or 14 volts as compared to 12-12.5 when not running. If no increase, you have an alternator problem most likely. Let me know what you find.
Aug 08, 2009 | 2001 Chevrolet Cavalier
Flat battery on s type 2001
Hi
Sounds like the battery to me.
Have they done a heavy discharge test on your battery at the garage, and can assure you it is 1OO% ?
The alternator is supposed to keep the battery topped up on charge nicely, even if it is only a few mile run every day, with your head lamps and heater going full blast, and then your fan runs on after switch off.
By the way it should only run for short time, how long have you heard yours run ?
Possibly the thermal switch is staying on too long ?
Did they test your charging rate on your alternator too, at your garage ?
How old is the battery ?
Is it of recommended type ? and not a cheepie from Halfords ?
Hope I have been of some help.
Good Luck
John.
Jan 05, 2009 | 2002 Jaguar X-Type
1983 chevy c10 firing problems
Problem sounds like it's in the power feed from the battery. Try a different battery (may be an intermittent plate or post connection problem in the battery). Also check the fusible link in the cable connected to the positive battery terminal, and check both battery cables from end to end as well as their connectors.
Mar 29, 2017 | 1995 Chevrolet S-10 CA Edition
Samsung Rugby SGH-a837 Cell Phone Logo
26 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
