Question about ZT Group CISNET A7050 PC Desktop
High speed I am trying to set my computer up with high speed. It keeps telling me that I have to turn on the highspeed. Is ther a switch somewhere to change it over? I have a cisnet
You should contact your service provider . THey should fix the problem. ok
Posted on Feb 22, 2008
Wash down
That would depend on what you want to do with it. Although something that big cannot adequately spin out at high speed because it cannot balance itself. So if you select a setting with a highspeed spin it wont make it to the high speed.
Apr 28, 2014 | LG WM2240CW - Front Load Washer with LED...
High speed internet
Pay for it. Your speed is limited by your ISP. Unless it's limited by your distance from the CO; in which case you are limited by physics.
Oct 28, 2012 | Westell Wirespeed Westell 7500 Dsl Modem...
How to enable highspeed usb on neclcd1770nx monitor
On most monitors that have usb ports you have to run a usb cable from the computer to the monitor to get the usb ports to work.
If your computer is not equipped with high speed usb ports you can purchase a pci usb adapter card that can make it usb 2.0 which is considered high speed.
Try purchasing one from Tiger Direct at:
Below is a link to one that I use which costs $9.99
Jun 09, 2012 | Computers & Internet
Code po551 after 2.7 to 3.2 conversion
I have no experience doing this conversion myself but that code should have nothing to do with the engine itself. The code indicates that you're having a problem with the power steering pressure switch (psps). I suspect that the connector to it got left of or damaged during the engine swap. The psps senses when the steering system is loaded, such as tight parking turns and then tells the computer to increase idle speed so that the engine does not stall. If the wire to the switch is left off or damaged, the code will set. You'll need to inspect the high pressure line coming from the power steering pump. Somewhere between the pump and the steering rack you will see a small oil pressure switch with a couple of wires going to it...or at least it should, the connector might be hanging somewhere near it.
Aug 13, 2010 | 1999 Dodge Intrepid
Unit cools but has only low speed. is fan bad or control board
It's either the high speed winding on the motor or the button or switch. You need to check to see if you have voltage to the high speed when you push the high speed button. If you have volts it's the motor if not it's the button or switch.
Jul 04, 2010 | Heating & Cooling
Carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
Dec 24, 2009 | Garden
Inside fan switch has 4 speeds only high works,
I have great news!It is not that bad!Look near the blower motor in the blower case housing ther is a blower resistor.It will have a multi-wire plug in.Unplug this ,and remove the two screws that retain the resistor in the box.Pull the resistor out ward,it will be out.The part store will have it or can get it for you.This is your speeds for your blower motor.If the blower is making any kind of racket,or seems to be slow when it is on high selection,replace it also,cause this is the cause if the resistor going out.
Aug 21, 2009 | Dodge Dakota Cars & Trucks
Mower not running at set speed, choking
you should have an air/fuel mixture screw on the carb somewhere. Start the engine and turn it one way then the other a small amount at a time. One way it will get worse and one way it will get better. Keep turning till it smooths out
May 09, 2009 | Garden
I'd buy a USB 2.0 hub, connect it to one of the ports, then set the hub on top of the computer. That would make it convenient to connect devices to the hub and give you high speed to run your new devices. Good luck
Nov 12, 2008 | ASUS Ai Lifestyle M2N-E (ASKU49311)...
Vornado heater doesn't work on high setting but only at low setting
Dust on the inside of the unit can cause the overload switch to shut many vornados down. Blowing the dust out of the unit with compressed air or a blower may help.
Another problem that causes vornados to stop working (light on - no heat no fan) is when one of the bearings starts to go bad in the unit. This causes the fan to be slower and less effective and the unit’s inability to move the heat away from the thermal overload switch again causes it to shut down.
Though you could remove the front and rear bearings and try to get replacements if it's even replaceable ... Once the bearing starts to go bad there is little that can be done ... HOWEVER, here is one solution to get more life out of the unit.
First, use a blower to blow all the dust out of the unit.
Then, because it is typically the front bearing that goes bad first, lay the vornado on it’s back (so the unit would be blowing air up toward the ceiling), this will relieve the front bearing somewhat and rely more on the rear bearing which tends to last longer.
The vornados I’ve had are all thermistor units ... that is, they don’t just turn on and off when the set temp is reached but in fact slow themselves down (both heat and fan) to keep some level of air circulation in the room. This is a good thing by the way.
There are usually two toggle switches .... one is a heat switch - usually Low & High .... the other is the thermistor switch (this sometimes is labeled “fan”) - usually Auto & High.
Once the unit is on its back ... Now, change the settings as follows:
Turn the Heat switch to LOW
Turn the Fan switch to HIGH
Turn the dial (with the temperature in degrees on it) to the lowest setting - which is somewhere around 60’ish.
Now turn the unit on and it should stay working.
Three things that could cause it to turn back off ...
You turn the Fan switch back to Auto.
You turn the Heat switch back to High
You turn the temperature selection dial too high ... though, you can cautiously turn the dial up a few degrees at a time ... the unit will start shutting down again when you set the temp too high ... then just dial it back down ... unplug for a couple minutes, then turn back on.
Oct 22, 2008 | Vornado EH1-0014-01 Compact Heater
ZT Group CISNET A7050 PC Desktop Logo
Top ZT Group Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
