Question about HP Xb3000 Notebook Expansion Base And 400gb Kit 400 GB Hard Drive
My hp pavilion will not charge with connected wire that is plugged into outlet; it seems stripped?
  • 478 Answers
Outlet plug on laptop damaged you will have to send it to someone who can replace the outlet for you unless still under warrenty then you can send it to HP for repair
Posted on Feb 10, 2010
My hp pavilion desktop pc power cable is plugged in but when I push the power button it does nothing
most of those hps have a light on the back on the power supply that lights when its plugged in but not all. I would try plugging it in on a different outlet to be sure its not a power strip or bad house socket. Make sure if it does try to come on that the power supply fan is turning. I would also take the side cover off and make sure that the wires that plug in the switch have not come loose
Dec 13, 2013 | Computers & Internet
Laptop battery is not charging
Hi, this information represents a basic troubleshooting guideline. Refer to your user guide for specific charging and connection instructions. Manuals may be available online in the Support Web site of HP.
Remove the battery from the computer.
Confirm the battery contacts are free of any foreign material that may prevent charging.
Reinsert the battery into the computer.
Verify that the AC adapter cord is properly connected and plugged directly into a known working AC power outlet.
NOTE: If the battery charges correctly when the AC adapter is plugged directly into an AC power outlet, but not when plugged into a power strip or surge protector, the problem is with the power strip or surge protector and not the computer battery or AC adapter.
Verify the correct AC adapter is being used.
Ensure the AC adapter box power light is on. This will be an illuminated green light.
If the AC adapter power light is not on, the AC adapter and power cord will need to be replaced.
Verify the charging indicator is illuminated on the computer.
If the issue still exists, install a different compatible HP battery, if available.
NOTE: If a replacement battery charges and operates correctly, the problem is with the first battery.
If neither the original nor a replacement battery charges, service may be required for the computer.
Dec 21, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Should a person plug the laptop in when using it where there is a wall outlet?
I would say: yes. The battery has a specific number of charge/discharge cycles. Once this number is reached, the battery's charge retention starts degrading, & eventually, the battery fails. I recommend using the battery only when no wall outlet is available.
Sep 15, 2010 | HP Pavilion dv6000z Notebook
My HP PAillion ze2000 PC Notebook will not charge
I had this problem with my laptop and the way to solve it is.... guess!!
Get a new power cord!!
Dec 31, 2009 | HP Pavilion ze2000 Notebook
The battery will not charge unless the computer is off. it runs on the battery even if its plugged in why? if i unplug the the adapter then plug it in it charges for a few seconds and then stops and then...
1. First remove the Battery, clean the Battery contacts with the pencil eraser and insert the Battery in the Computer.
2. Connect the AC Adapter (Battery charger) securely to the Computer and the Power outlet.
3. If the issue persists, try connecting the AC Adapter to different Power outlet.
4. Make sure that both the connecting points (DC IN port on the Computer and the Power outlet plug) are securely connected and not loose.
5. If the issue persists, try with different AC Adapter.
Good Luck!!!!!!!!!!!!!
Nov 18, 2009 | HP Pavilion zd8000 Notebook
HP zd8000 will not charge battery or run on power cord
check the dc jack probably is loose that cause the batterie dont get charge
Aug 13, 2009 | HP Pavilion zd8000 Notebook
HP Pavilion 700 Wont Turn On
verify if at rear is a button with 1 and 0 position
that must be on 1
Jul 24, 2009 | Computers & Internet
Green power supply light blinking? HP Pavilion a820n
These wires vary based on the type of the board each wire lead is labeled to coorespond with the pins on the board. You need to reference the manual for your specific motherboard. If you don't have the original get it from the vendor support site or just google it. Unless your motherboard is an odd brand it should be easy to find.
Mar 28, 2009 | HP Pavilion A820n (PP165AA) PC Desktop
I can't start my hp zd 8000
If no power check;
  1. If on battery take out battery and plug in ac adapter to a known good outlet.
  2. Make sure power connections are snug
  3. Make sure ac adapter connections are good.
  4. If ac adapter on power strip, turn off and on power strip
  5. Try again.
If theres no display try the following;
  1. Reboot and keep tapping on F8 to go to Safe Mode.
  2. In Safe Mode select "last known good configuration" and then press Enter
Still no display;
  1. Connect an external monitor, toogle to external monitor
Let me know if any these solutions work if not we can try something else
Jan 18, 2009 | HP Pavilion zd8000 Notebook
HP Xb3000 Notebook Expansion Base And 400gb Kit 400 GB Hard Drive Logo
105 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
