Question about Magellan RoadMate 800 GPS Receiver
I have a legacy item (Roadmate 800). The battery was dead so I ordered a new one. The new battery powers on the unit but when I plug in ac charger I don't get a solid orange light, but a flashing green (the connection is loose)... anything I can do as Magellan doesn't repair legacy items.
    President:
  • 1,111 Answers
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Posted on Feb 07, 2010
I was having problems with the car charger CA-051, then, I used a T-Mobile charger, at first time worked, after that, the GPS Maagellan was dead. Is it possible that I have to order a new battery? or I...
Using non standard chargers is probably the problem. If the battery has suddenly become sogged since using this charger then it may have done more damage than you want to know about.
Was it the correct polarity +ve Tip? was it the right amperage?
Magellan are specific in recommending you only use their charger and with reason, its correctly made for it.
You can try the new battery angle, but get advice on the charger.
As a small note.. Car chargers do NOT fully recharge batteries in GPS. Use an AC or USB charger. The car charger is a maintenance power supply. Always fully charge the unit prior to use and do not plug to car power until engine has been started.
These are standard rules with all non hard wired GPS and phones, ( but not always in the manual, have to have service and new sales someway!)
Please rate my help++++Thanks for using FIXYA
Aug 11, 2010 | Magellan RoadMate™ 1212 Car GPS Receiver
Broken RoadMate 700
Here are a few tests you can do. Bear in mind if the unit has not been charged for some time and the internal battery is completely flat, you will need to leave the unit on charge for some time even to get a charge light from the LED. Leave it on charge for at least 2 hours. First, check the LED is lit when the cable is plugged in to the cigarette lighter socket and/or mains charger? If it is not, the fuse in the cigarette lighter adapter may be faulty or the charger may not be working. If the fthe LED is lit, then is power available at the end of the cable that connects to your unit? Use your DC voltmeter to check this. If no power is available here, then your cable/charger is faulty - obtain a new one. If there is power at the connector, then the unit may be faulty.
Jun 10, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 2200T won't turn on
ost times not turning on is because the battery is flat or dead. Connect it to a USB charger or and AC charger and leave it for an hour to see if there is any recovery.
If it does not have it taken to a service centre to have the charge circuit checked and a new battery.
May 14, 2010 | Magellan RoadMate 2200T GPS Receiver
Can I charge my Magellan roadmate with USB cable connected to the computer?
It depends on the Roadmate that you have. :
- If your Roadmate has a separate plug-in port for charging your unit IN ADDITION TO a USB port, then no, your Roadmate cannot be charged using your computer via the USB cable.
- If your Roadmate only has a USB port available for charging your unit, then yes, you can charge it via your computer via USB.
However, please note, according to Magellan, charging your unit using your PC via USB can take up to 12 hours to charge vs. 4-6 hours when using the vehicle power adapter.
FYI: This is mainly due to USB constraints on pretty much all electronic devices. USB cannot carry the same amount of power to a device. It uses what is commonly known as a 'trickle' charge to recharge a device. It carries much less current than a full-blown charger (like an AC power adapter).
Apr 18, 2010 | Magellan RoadMate 1340 GPS Receiver
Roadmate 2000 will not turn on. charger light is lit. No response from unit. I turned it off and stored it for a few days, but now it is dead.
its possible it needs a new power port (very common problem on this and many other magellan gps) if your sure the charger is working..you said the light was on, then its working..
plug it in again to the charger, then press and hold the power button for up to 10 seconds.
if that fails, let me know and ill give you something else to try
bill
Mar 08, 2010 | Magellan RoadMate 2000 GPS Receiver
Magellan RoadMate won't compute if connected to power
unplug the charger, then turn the 1200 on, once its fully booted, hold the power button for 15 seconds..the screen will go blank after a few seconds, but continue to hold it for 15 seconds.
now, with the charger plugged in and unit off, press and hold the power button for upto 7 seconds or till it starts.
if that fails, let me know and i can tell you something else to do.
bill
Jan 23, 2010 | Magellan Roadmate 1200 Car GPS Receiver
I lost my ac charger and need to know where to order a new one
I think the DVD Player was made for Target, you might be able to go there and find one and get the info off the power supply (charger) and take the unit and the info to Radio Shack for a replacement. If they can not help try calling MCM Electronics at 1-800-543-4330
Feb 16, 2009 | Curtis DVD8017 Portable DVD Player
Magellan roadmate 2000 no power
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Nov 16, 2008 | Magellan RoadMate 2000 GPS Receiver
Output voltage
Hello rcgibson, output of charger for (if this is correct 'Roadmate 800 GPS unit) AC wall power supply or 12/24 volt DC is 5 volt at 455 milliamp.
Oct 24, 2008 | Magellan Universal Ac Wall Power Supply...
Roadmate 2000 power supply over-voltage
The roadmate operates on five volts dc. Look at the back of the unit and it says so there. Inside the cig lighter plug that comes with the roadmate 2000 is a transformer that converts 12 v dc to five v dc. You used the wrong charger and put twelve volts across a unit that only handles and requires five volts.
Check to be sure that you used the correct charger. it sounds like you did not. It may be possible that the charger was still wet or was damaged when wet and that it shorted out.
Radio shack sells a charger for the car that is made for magellin roadmate 2ooo. It includes several different tips including the one that fits this gps unit and the output is five v dc. It is possible that what you smelled was the charger cord and not the gps unit itself.
I used the wrong charger on mine and had a similar problem. I bought this charger and all is well. radio shack cat no is 20-151. Get it soon because it is on sale for about thirteen dollars and is discontinued. As of today, sat jan 12, 2008 they still have them in stock at most stores. You can call ahead or look online and it will even tell you which stores have them, or you can order online as well.
No, if it is the gps unit titself, do not try to mess w the circuit board. Its cheaper to buy a new one. good luck to all w similar problems and ALLWAYS check to see that voltage and ac or dc symbols, as well as polarity, match up. If not bring your electronics to radio shack Before powering up and they can check all of this ffor free if you are unsure.
Oct 22, 2007 | Magellan RoadMate 2000 GPS Receiver
Magellan RoadMate 800 GPS Receiver Logo
431 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
