Question about Lands Phones
How do I erase entries - Lands Phones
  • Cliff May 11, 2010
    What make and model of phone?
    President:
  • 1,561 Answers
From your phone, click the menu button, different folders will open, click on your contacts, all entries will come up, click the option button, different options will come up, select mark all and click the option button, you will see delete option there, select it and all your entries will be deleted.
But if it is just few you want to delete, mark the ones you want to remove and do same as above, just the few you selected will be deleted.
Best regards.
Posted on Feb 07, 2010
HOw do I unblock a number from my Uniden DECT 6.0 home phone?
Call block entry options:
With the phone in standby, open the call block list and find the entry you want.
Press Menu/select to open the individual entry menu. Choose one of these options:
  1. Edit (Handset only) Edit this entry. The phone will prompt you to edit the name & phone number.
  2. Delete Erase this entry from the list & allow calls from this number.
Dec 20, 2017 | Uniden Lands Phones
How do I unblock a phone number on my uniden dect 6.0 phone
May 22, 2015 | Uniden Lands Phones
Purchased a 2007 MKZ and there was no owner's card to get the keyless lock code. How can I get it so I can set my doors?
The keyless entry code should be printed on a label by the fuse box. I have attached a picture of where you should find the label SECTION 501-14: Handles, Locks, Latches and Entry Systems 2007 Fusion/Milan/MKZ Workshop Manual GENERAL PROCEDURES Procedure revision date: 07/31/2006 Keyless Entry Keypad Code Programming adobe.gif Printable View (109 KB) NOTE: To associate a memory configuration to a personal entry code, refer to the Owner's Literature.
  1. Enter the permanent factory keyless entry keypad code.
  1. NOTE: Holding the 1/2 button for more than 2 seconds after activation erases all the customer codes. The existing code does not need to be erased to program a new code.
    Press the 1/2 button within 5 seconds to activate the programming mode.
  1. Within 5 seconds, enter the new 5-digit keyless entry keypad code. The doors lock and unlock to confirm the new code is programmed.
2010&c18=modelyear&c20=n996353&c35=wsm%2ckeyless%20entry%20keypad%20code%20programming%2cs7s%2c501-14%2cgeneral%20procedures&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=428&ct=lan&hp=n&[aqe] ddll111_2.jpg
Mar 10, 2011 | Lincoln MKZ Cars & Trucks
How do i delete my contacts
Use the Security Menu to quickly erase all the contents of your contacts lis.
1. Pess MENU>Settings/Tools>Settings>More...>Security and enter your lock code.
2. Select Erase/Reset>Erase contacts.
3. If you are certain you would like to erase all you contacts entries, select Yes.
Mar 08, 2011 | LG RUMOR Cellular Phone
How to reset anti theft system
KEYLESS ENTRY SYSTEM You can use the keyless entry keypad to:• lock or unlock the doors without using a key.• open the trunk.• recall memory seat/mirrors/steering column/adjustable pedals positions1 or 2. The keypad can be operated with the factory set 5-digit entry code; this code is located on the owner's wallet card in the glove box, is marked on the computer module, and is available from your authorized dealer. You can also create your own 5-digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation. Programming a personal entry code. To create your own personal entry code: 1. Enter the factory set code. 2. Within five seconds press the 1 • 2 on the keypad. Note: The lock motors will cycle, locked then unlocked 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other. 4. Enter a sixth digit to indicate which personality feature should be recalled by the personal code. Note: The lock motors will cycle, locked then unlocked. • 1 • 2 recalls driver personality 1. • 3 • 4 recalls driver personality 2. • 9 • 0 does not recall a driver personality. Wait 5 seconds without pressing a keypad button in order to store a personal entry code. Tips: • Do not set a code that uses five of the same number. • Do not use five numbers in sequential order. • The factory set code will work even if you have set your own personal code. • If you set a personal code and store it over an existing personal code it will erase that personal code only. Erasing personal code 1. Enter the factory set 5-digit code. 2. Press and hold the 1 • 2 for two seconds and release; this must be done within five seconds of completing step 1. 3. Press and hold the 1 • 2 for two seconds to erase the customer programmed code; this must be done within five seconds of completing step 2. Your personal code is now erased and only the factory set 5-digit code will work.
Feb 09, 2011 | 2002 Lincoln LS
How to change the keypad code on a 2001 mercury grand marquis
look for the permanent code on the plastic card in the owner manual packet. Or, pay dealer to extract code from computer.
Keyless Entry Keypad Code Programming NOTE: The system only allows one code to be programmed.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds after activation will erase the stored customer code . The door locks will lock, then unlock, confirming the code is erased. The existing code will not need to be erased to program new a code.
  1. Within five seconds, enter the new five-digit keyless entry keypad code. The door locks will lock and unlock to confirm the new code is programmed.
Feb 08, 2010 | 2001 Mercury Grand Marquis
How can I erase a single entry from my locations list
To do this;
From the Menu page touch - 'Where To' then 'My Locations'
Touch 'Favorites' then select the entry you want to delete.
Touch the 'Edit' button then on the Edit window select 'Delete' then select 'Yes'.
The entry is now deleted from the locations list.
Hope this helps. If so please do take a moment to rate the solution. Thanks for using FixYa.
Jan 19, 2010 | Garmin StreetPilot C330 GPS Receiver
Grapics, songs ,videos and voicemails deleted whats up?
The following is from the Razr V3 manual: Master Clear - Clear all user settings and entries except SIM card information, erase all downloaded pictures and sound files, reset all options except unlock code, security code, and lifetime timer. Caution: Master clear erases all user-entered information (including phonebook and datebook entries) and user-downloaded content (including photos and sounds) stored in your phone's memory. After you erase the information you cannot recover it.
Hope this answers your question.
Apr 11, 2009 | Motorola Mobility RAZR V3
How can i restore factory setting in motorola v3i without sim card
Master Reset
Reset all options except unlock code, security code, and lifetime timer:
Go into Settings > Initial Setup > Master Reset
Master Clear
Caution:
Master clear erases all information you have entered (including phonebook and datebook entries) and content you have downloaded (including photos and sounds) stored in your phone’s memory. After you erase the information, you can’t recover it. Clear all settings and entries you made except SIM card information, erase downloaded pictures and sound files, and
reset all options except unlock code, security code, and lifetime timer:
Go into Settings > Initial Setup > Master Clear
Jan 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Cell phone
try this. The menu names may vary depending on the model or even service provider. look for a simmilarly meaning menu name
For missed calls, made calls or received calls
Go to
menu, call history, erase History, then click on whichever option you want to clear it. you can also clear all.
if you only want to erase just one entry go to call history, go to the category you want(missed, outgoing,incoming) then scroll to your particular one and click options, erase
Assuming you want to erase the recipients of txt messages, go as if you want to send a text(menu, messaging, send message, text message.) then on recent list, scroll and select your desired entry and press options, erase
Good luck
Feb 08, 2008 | Samsung SGH-E720 Cellular Phone
Lands Phones Logo
77 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
