Question about Microsoft Xbox Console
Xbox won't read disks!!!!
My xbox keep sayong it cant read disks !!!! i even put a new CD in there!! i'm going crazy .....( i think the **** is up to this) what should i do!!!!!!!!!!
  • 12 more comments
  • mdbarnes80 Jul 27, 2008
    Ihave and xbox elite halo edition and had it bout a year and just last week it started were it would say reading andthen go to the open tray what do I do?
  • agionis Aug 06, 2008
    my stupid friggin xbox says that EVERY disk even brand new xbox disks needs a dvd playback kit. you dont need a stupid playback kit to play games!!!!!!!!!!!!!!!!1111111
  • Anonymous Oct 03, 2008
    I took mine in and had it cleaned for the 2nd time, plus I already bought a NEW CDrom unit for $60 last year. I'm not paying any more when I can buy a new refurbished one for $49.
    How do I fix the one I have? It can't be any harder than a PC!
  • Anonymous Feb 26, 2009
    i can insert the disk but after that it just stays at the option menu what the hell is wrong with my xbox!!!!!!!!!!!!!!!
  • Anonymous Mar 14, 2009
    my xbox 360 suddenly stopped reading all discs
    dvd and game
    i never put a cd in it though
    where exactly is laser thing... do have to take the top off?
  • Anonymous Mar 21, 2009
    my xbox says the discs are dirty or damaged!!!!!!!!!!!!!!!!!
    my xbox just stopped reading cd's games and movies any kind of disk and it wont read it
  • Anonymous Apr 13, 2009
    i have a prob with my xbob also...the laser will not read any disks/game cds...a yr has past since i got this xbox so i cant return it so what should i do?
  • Anonymous Apr 25, 2009
    xbox wont read discs
  • Anonymous May 05, 2009
    when i put a cd in my xbox it wont do anything it just stays at the option screen.
  • hossein Sep 12, 2012
    I have a xbox 360 Elite and I bought "transfomers fall of syberian" three times and it says "unsupported disk...clean it....what shall I do?
  • mark dixon Mar 19, 2013
    dose it realy work
    how old is the xbox
If your xbox wont read the disc, it just says open tray, there is a very simple solution i discovered. You dont need to do anything complicated or fancy, simply make sure everytime you turn your xbox off the disc is out. Turn your xbox on without a disc in, let it get to your profile screen, then put the disc in. Works every time.
Posted on Apr 14, 2010
  • 4 more comments
  • crookid Sep 14, 2010
    This is the perfect solution. I would like to cast a vote to put this at the top of the page. Thanks for the input!
  • maw_4 Oct 03, 2010
    I wouldn't say it works every time. I have never left a disc in my xbox before turning it off, so obviously I've turned it on without a disc in it. I've let it go to my profile screen and put in a disc - still doesn't read it. All it says is open tray and makes a slight humming noise. I think I might try lubricating the two bars that laser runs along. Praying this will work especially with Halo Reach out now.
  • jprotege Dec 13, 2010
    Works.
  • ryan_mulloy Apr 11, 2011
    This just saved my xbox and I didn't have to take it apart, thanks so much
    dose it realy work
    thank u i found this very helpful :)
    Genius:
  • 1,175 Answers
The unit needs to have the laser reader lens cleaned but DONT use regular rubbing alcohol.
Get pure stuff....the rubbing type leaves a glare on glass and plastic lenses.
Also ,the chrome rails that the laser moves along need to be cleaned and lubed with liquid silicone.
This method clears read problems most of the time.
Posted on Mar 13, 2009
    wrong.
  • siblore878
    siblore878 Nov 11, 2012
    it worked for me but i used wipes for hdtvs
I would just like to say that these other solutions are an obvious money making scheme and unnecessary. Not only are they telling people it's okay to pull apart their Xbox 360 (It's clearly not), but they're advertising products people would have to go buy in order to fix their problem.
Well there is a better solution that was posted here 5 months ago. So I will post it again to let more people know.
BEST SOLUTION:
Simply make sure when you turn your console on or off that there is no disc inside.
Turn it on without a disc.
Load your profile.
Put a disc in and get ready to play.
When you're done take your disc out and then turn off the console.
It's just that simple.
Give it a try.
See for yourself.
Sincerely,
Crookid Fingaz
Posted on Sep 14, 2010
  • 5 more comments
    RIGHT.
    Worked for me.
  • magnify1 Dec 16, 2010
    worked perfectly thanks a ton!
  • Millicans924 Dec 18, 2010
    Worked like a charm. I was close to taking it apart. Glad this was the solution.
  • chalkstorm Jan 23, 2011
    Perfect!! We tried all sorts of things but this was THE SOLUTION!
  • maverill Jan 25, 2011
    I did the same with a air mattress pump and it worked too
  • Mike
    Mike May 16, 2014
    what account
I had the same problem wouldn't read game disc but would read dvds. the error message i got was insert an xbox game to play when there was an xbox game in, also i when i closed the tray it would say reading then say open tray. I managed to fix mine.
Please be aware you will have to open up your xbox and in doing so will viod your xbox so please check if you still have it under garuntee first!!
HOW I FIXED THE PROBLEM
first i opened up the xbox and took the dvd drive out.
Then i opened up the dvd drive and replaced the laser for a new 1, but still didnt work, so the next thing i tried was putting the old laser back in and lubricating the 2 bars that the laser runs along ( i used vasleen) any lubrication will work. Time to test it, bingo worked striaght away everytime, no problems since, I think the fualt it that the lubrication on the bars wear off and the laser gets stuck. Give it a tried and let me know how you get on
Posted on Feb 19, 2009
    wrong.
  • 38 Answers
Hi
i have seen on youtube how to clean your lazer with a cotton bud.
you have to open your xbox and find the lense the VERY carfuly wipe the lense with the cotton but.
when u have finnished put a dis in and put the little weight on the disk and try to boot it up it should work.
if it dont then u will need to get a new drive (laser) i got a psare and repair xbox and changed them over
Posted on Aug 20, 2008
    wrong.
I had a can of keyboard cleaner laying around. I opened the Disk Tray and sprayed the Hel* out of the whole inside. It works fine now :)
Posted on Dec 13, 2009
    wrong.
I spoke with Microsoft about this issue and they offered me the solution.
You will need to access the storage device or devices from the Console Settings. When you have the device (eg: Flash Memory, Hard Drive, etc) You will need to access the device system files by pressing Y.
Once in the drives system files, you will need to clear the cache for this/these device/devices 3 times. Once the cache has been cleared, power down the unit and unplug the following:
- Power
- Video
Wait 5 minutes and plug these back again. The device should be able to read disks on boot-up. You will also notice a slight improvement in performance as well. =)
Cheers!
- Clutch
Posted on Oct 07, 2012
  • 152 Answers
Three options.
1. Replace the laser inside the CD Drive.
2. Replace the CD Drive.
3. Get some rubbing alcohol and some q-tips. Wet the q-tip with rubbing alcohol and start cleaning the laser eye with the q-tip. Put a tincy-wincey bit of pressure on the lens but not too much when cleaning it. Then clean up the excess rubbing alcohol with a dry q-tip. Then put the CD Drive and the Xbox back together.
Posted on Feb 22, 2008
    wrong.
  • 45 Answers
Get a laser lens cleaner at the store. Use it as directed.
Posted on Aug 18, 2008
    wrong.
    I agree didn't work for me try a can of air or air mattress pump on the inside of the player with the drawer open worked for me after buying a laser cleaner that didn't work
    New Friend:
Can someone help...my original Xbox wasn't reading games so well so I put a laser lens cleaning disc with the small thristles inside it after acting kinda funnny it read the disc and was cleaned...but after that it only reads CD's and DVD's when I insert games it has no reaction it reads it but nothing happens...so I cleaned the lens myself, again I inserted a game and nothing happened maybe since I inserted the lens cleaner it's like it's stuck on CD's and DVD's please someone tell me how to recalibrate it to read my games again
Posted on Jan 09, 2013
I have same problem and i tried the alchohol thing how do i replace laser or CD rom
Posted on Feb 24, 2008
    wrong.
Pull it apart mate! (don't be shy) use the same stuff that to clean LCD or plasma TV's, clean lens use cotton bud OR swab. clean the rails spotless use Vaseline to lube em up again. my DVD just bombed out i am afraid my previous pott tweak might have eventually killed it.
Posted on Dec 06, 2009
  • cool_MC_Dork Dec 06, 2009
    PULL IT APART! you wont hurt it unless you do something stupid.
    Here is a Quick Guide to help you.
    you will need torx screw drivers can't remember the size though.
    turn your xbox upside down remove all the rubber feet to expose the torx screws there is one hidden under a sticker there somewhere. undo them all and set aside where you will not lose any! next separate the two half's of the shell to expose the guts now there are two tray's on the left is your DVD drive and on the right is your HDD remove the screws holding the two trays together there are a few. now you should be able to remove the drive just unplug everthing from the back of it (just remember where everything goes) now dismantle your DVD drive take the top plate off by removing the screw around the sides this may or may not require a bit of force but it will come loose from there you should be able to perform alot of general maintenance not just to your DVD drive but tou your whole xbox. clean it right up. and while your at it install a chip then get a bigger HDD etc.. etc.
    wrong.
    and wrong again.
    Problem Solver:
  • 10 Answers
3 options
1. Get a lens cleaner CD.
2. Get a new drive.
3. Replace the lasers there are inside the CD Drive or replace the CD Drive.
I hope that will help you.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Posted on Apr 19, 2009
    wrong.
    I opened the DVD drawer and used a air matress pump ro blow air toward the laser lens and that seemed to get things going again. The nice thing was I didn't have to tear it apart
Regular xbox wont read discs
Posted on Nov 15, 2009
  • 3 more comments
    You're pathetic.
  • anthonyteles Oct 25, 2010
    Crookid, it is people like you that make people not want to participate in forums. I am a 6 year Microsoft tech. Just so that EVERYONE is aware, every option given in this forum to date is a viable option EXCEPT for the one that Crookid promotes. If you start your console without a disc, and it works, it is not a magical fix. It simply means your driver is on its way out, and it is a hit or miss that it will read. Aside from letting a professional fix it(we have to eat too...) Cleaning, and lubing is your best option. Also you can get a new dvd drive for between 20 and 40 dollars, with many tutorials online to show the simplicity of replacement. I suggest calling Microsoft first, your warranty may still be active.
    Well, just so you know Anthony, his solution works ever time I get this issue. Never had to bring my xbox to a store, buy any cleaners or other garbage, nothing.
    Like you said, you techs need to eat, so I can understand you promoting the method that will make you the most money.
  • jakeold Jan 02, 2011
    dont use stake knife to take apart xbox, stabbing yourself hurts a little
  • sugrns3824 Apr 16, 2011
    It is great that crookids method works. However my son tried it and it didn't work for him. We lubed up the bars and cleaned the lens and it worked. I understand you are proud that your method works crookid but you don't have to be rude to let people know. And by the way your behavior reflects on ***********. Just sayn.....
My CD drive won't read anything?
you need a new laser by the sounds of it
Aug 01, 2012 | HP Computers & Internet
Well.. i can close my disk drive all i want, however, it will just keeep on opening and closing and wont read the disks at all and i cant afford a new one... my xbox is under 1 year of age. i got...
When the xbox is blinking it means 2 things. the cable that connects to your drive needs to be replaced or your DVD no longer works. The connector cost around $3 or a New Drive cost around $30 on ebay
Thanks
www.1RepairStop.com
Aug 30, 2011 | Microsoft Xbox 360 Console
What do you do when your xbox won't read disks?
The main problem might be a big problem with the disk tray. There might be an faulty wire that has lost connection and if your disk wont event turn on, there might be a problem with the power supply that supplies the cd tray. If the disk opens and closes but doesnt read and wont say tray is in and keeps saying open tray, there might be a small fracture on some of the wires or there is something wrong with the motherboard of the xbox 360. The best way is to buy the warrenty now and send it to the xbox 360.
Jul 27, 2011 | Microsoft Xbox 360 Console
Xbox cant read any disks
The laser in your xbox probably isn't reading it correctly, you should send it in for help.
May 16, 2009 | Microsoft Xbox 360 Console
Xbox 360 Pro : To Play This Disk Error
Unfortunately , a new xbox360 game cant be played in a normal xbox (not xbox 360)
The problem is that the new xbox is way different on the inside than the original xbox is. Because it is way more powerful, you can put an old xbox game into a 360, and it will work fine (most of the time), but if you try the reverse there is no way to make it work.
May 13, 2009 | Microsoft Xbox 360 Pro System Console
Xbox cant read disk then scratches the disk
rub some brasso onto the cd and rinse off with hot water and soap.then dry with a cotton t-shirt.
this repairs the scratches on the cd and the unit should read the cd ok now.
Jun 11, 2008 | Microsoft Xbox 360 Console
XBOX 360 Core system
there is something in your xbox 360 called a lens and that what makes the xbox read cds so try this go to a store like walmart or maby even a local store and find something called a laser lens cleaner this can clean a lot of stuff game consloles cd players dvd players and probaly more so over the years haveing a xbox 360 it collects dust on the lens and does not read good
May 13, 2008 | Microsoft Xbox® 360 Core System Console
Microsoft Xbox Console Logo
49,576 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
