Question about Nokia 6680 Handheld
6680 dropped into water how to fix it
My nokia 6680 got washed in a laundry machine what would i need to replace and how to fix it
  • 78 Answers
If u have immediately switched it off. ther is a chance of saving ur mobile.open the panel and dry it for a day or two in dry sun shade. its ur luck after all
Posted on Feb 08, 2010
Hello i have a problem to remove water from this machine & i can't open the door
if the water out pipe cant reach outside the laundry to the ground
for gravity to drain the machine
drop off the water pipe outlet connection or let it fall on the floor
and have a lot of towels and mops handy
if the door will not open after iit is drained
machine will need repair
Jun 17, 2016 | Washing Machines
My frigidare laundry center, FFLE2022MW will not fill with water at all.
I have a Frigidaire Landry center model # FEX831FS4 I washed a small but heavey rug in it and it quit during the spin cycle and now wont do nothing but the dryer still works...can you help me out?
Aug 21, 2014 | Frigidaire FFLE2022MW Electric Laundry...
My washing machine leaks alot of water from the drain trap while it is working or when it has just done a wash.
Thanks for the model number. The leakage is very likely from the drain hoses that are connected to the drain pump. For your model the drain pump is located at the bottom front behind the bottom plate. You will have to remove the screws holding the bottom front plate. Once you get this out you can access the drain pump and hoses. Either one of the two hoses (inlet from drum or outlet to laundry drain hose) could have burst or lost hose clamp. Need to fix this. Also check the laundry tub drains are clear and there is no back water into washing machine.
May 01, 2014 | Washing Machines
It does not drain water. Also smelt burning from the machine while washing.
Your drain valve solenoid burned up - the solenoid windings are shorted/burnt.
Fix: replace drain valve.
Aug 16, 2011 | GE Spacemaker Washer and Dryer Electric...
Water sensor not working. Started a load of Laundry and the water did not shut off therefore flooding my whole Laundry room. How can I fix this myself?
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug or turn off circuit breaker ,if the water continues to fill, that valve is sticking,it is what to replaced
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps
Gene
Jul 31, 2011 | GE Spacemaker Washer and Dryer Electric...
Tried to do a load of laundry and the water doesn't seem to come. The machine beeps and flashes F and then H or vice versa
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 03, 2011 | Kenmore Elite 45986 Front Load Washer
We have a Samsung WF8802 RPZ washing machine with a 5ud fault code. What is the problem?
We have a Samsung WF8604NGW front loading dimond 6kg washing machine. We had the 5ud error message. It turned out the filter was clogged with fluff from a new set of bathroom mats my wife washed. To fix: Put the machine on to drain (if poss) - should be 1 minute on our machine however as the machine was so clogged it took around 15 to finish. Also use the draning tube located next to the filter (on our machine) to get rid of as much water as poss. Now remove filter and clear (warning some water will remain in the system) Before spinning any laundry run the rinse cycle (with an empty drum) a couple of times and clear the filter each time. If the filter is still clogged the laundry will spin heavy as the water will still be in the drum leaving you with no very dry laundry and a horrible noise during the spin. Regards Rik.
Nov 14, 2010 | Samsung Washing Machines
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
Nokia 6680 charging problem
this is a common problem with mobile phones if the battery voltage drops to low the phone canot control the initial cherge remove the battery and charge out of the phone if you can or by a new battery which will have a small charge in and should allow you to cherge the phone normaly
Dec 14, 2008 | Nokia 6680 Handheld
Nokia 6680 cannot save pictures and music to gallery
Due to water drops inside my mobile 6680 Gallery wont open.I have formatted my mobile also still it is not solve.Do u have any software to maintain the gallery.plz i will be waiting for ur reply.
Aug 10, 2008 | Nokia 6680 Cellular Phone
Nokia 6680 Handheld Logo
65 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
