Question about LG LFX25960ST Stainless Steel French Door Refrigerator
My freezer door became unhooked on he bottom I don't know if it is broken or i just don't know how to put it back on
    New Friend:
Jimmy the door back and forth, up and down until you get it out. Carefully. Two people helps. There are two metal hooks at the bottom left and corners. The upper one hangs up on a "catch" inside the slot, and you just need to navigate that. Carefully. We had one side come unlatched so needed to be careful not to pull that side out too far to cause too much torque. You'll get it.
Once the door is out, grab a phillips screwdriver. Look for a thin rectangular white piece of plastic (one in each corner, about 4" x 5") that covers the hinges on each side. Unscrew the upper and lower outside screws on that. Take it off. May need to pour warm water on it if it is iced on. It may be taped on but it comes off.
Now you can access the "hooks" better. Have someone hold the door steady (in upright position). Pull the upper hook down (takes a little strength) and then pivot the weird little piece of metal on the lower hook until it fits into the upper hook (temporarily latching them together). Repeat for other side.
Then carefully lift the door into place and slide both "latched" hooks into the interior slots. Helps to have two here. The drawer needs to be out so you can access the hooks and slots. Once the hooks are in the slots, grab that phillips again. Have someone hold a little pressure on the door to keep it in place, and gently pry the weird little pivoting metal piece away from the upper hook with the phillips. Repeat for the other side.
Now push the door into place carefully. Hopefully it will latch up the way it is supposed to on both sides and you will have your freezer (and happy wife) back. Happy wife, happy life! Good luck!
Posted on Jul 16, 2013
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: I have a broken gear
find service centers at http://us.lgservice.com/index_b2c.jsp
Posted on Oct 24, 2008
Amana freezer door doesn't fully shut
There is a drain inside the freezer part of the arb2257csr. The drain can get clogged and the water from the defrost process will pool up on the bottom of the freezer. You can gain access to the back of the unit and remove the pan drain to clean it out. Then make sure water flows and ice is not blocking the drain. It takes a long time to melt so I used a turkey baster and put hot water into the drain from the lower inside middle of the freezer. This drain pan can get pretty smelly when rancid oils and such don't evaporate the way it was designed to evaporate the water. The symptoms were ice on the inside bottom and water pooling in the front of the drawer. It also became very hard to close the door due to the frozen door slide. I have not seen anyone report this on any site so far. Everyone talks about the thermostat but no one seems to have arteriosclerosis of the drain tube.
Apr 15, 2013 | Amana Refrigerators
The water supply hose where it enters the door at the bottom has cracked and broken how do we replace the hose in the door
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 06, 2012 | Refrigerators
Have replaced broken hinge but am stuck getting both fridge and freezer door back on. can do one or the other but not both. westinghouse freestyle fridge/freezer
srack from bottom up- bottom hinge - bottom door- tape door with duck tape- middle hinge- top door- tape top door- top hinge- remove tape- done
May 25, 2011 | Refrigerators
Water tube to the dispenser has came unhooked in the door. how do i get inside door to hook it back up.
around the edge of the door there should be screws holding on the SKIN as they call it
Nov 07, 2009 | Frigidaire FRS26R4A Side by Side...
Replace front side window volvo 850 1996
IT HAPPENED TO ME ON MY 850 YOU HAVE TO TAKE THE DOOR PANEL APART NOT THAT HARD YOU MUSTHAVE TORX FOR THE SCREWS THEN UNPLUG THE WIRING NEXT GET A SHOP VACUMN TO **** UP THE GLASS IN BOTTOM OF THE DOOR AND UNHOOK THE PLASTIC ROLLERS FROM TRACK ALWAYS GET A FEW EXTRAS AND PUT A USED WINDOW USUALLY AROUND $50.00 AND INSTALL AND CLIP THE WINDOW INTO TRACK AND PUT EVERYTHING BACK TOGETHER
Mar 28, 2009 | 1996 Volvo 850
Gss25jfmc side by side
it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Aug 11, 2008 | GE GSS20IEM Side by Side Refrigerator
FRONT DOOR OF DISHWASHER
take off the bottom kick plate and look in there to see if the springs to the door hinges on either side are broken or come unhooked and let me know
Jan 10, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
63 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
