I have an IBM e series x346 (M8840-11M) with dual xeon 3.0gb cpu's, 6gb ram and 2 x 36gb scsi drives running off the onboard controler, not the Serveraid which has been removed. My problem is that it will start up fine, all post and diags say no problem, then after anything from 1 hour to 12 hours, it will shutdown. It then shows VRM and NMI errors. I have checked all fans and am not getting any overheating. It can happen in the middle of a task, or when it is sitting idle, any ideas folks? regards,
  • 1 more comment
  • Greg Cooper Feb 12, 2010
    My problem is that it does all diags without an error. The only feedback from my logs is that it shutdown after running for 21 hours!. No breakdown details in the logs, it just turns off. The diag panel can show any or all of the following:
    CPU, VRM or NMI. I hae completely stripped this unit cleaned and checked all contacts, including the removable VRM, removed the cpu's and replaced them with new thermal compound. It then ran for 21 hours. Prior to that it had been cutting out intermittently after anything from 1 1/2 hours to 4 hours. I am wondering if I am getting a progressive breakdown of the motherboard itself, any further ideas are most welcome.
    regards,
  • joecoolvette
    joecoolvette May 11, 2010
    I don't have any documentation supporting the VRM on the motherboard, that is to say, whether you have dual VRM's, or just a single VRM. Your original post lead me to believe that your logs stated an NMI. Which is used to signal attention to non-recoverable hardware error/s. (Hardware component is bad) VRM was also listed. Therefore I concluded that one, or more VRM's are bad. (Based on if the unit has dual VRM's) To me a CPU error would be a logical error shown, as the Voltage Regulator circuit, or removable module in this case, is what regulates voltage for the Processor. Seems to keep coming back to a bad VRM. Haven't posted anything resembling a solution yet, so I am posting in the Clarification category. Would like you to take a look at the capacitors on the motherboard, and if the VRM's are not an Integrated Circuit, see if you can view capacitors on it/them. This would be in reference to Electrolytic Capacitors, of course, and not Solid capacitors. This link takes you to Visual Signs of Capacitor Failure, (Electrolytic) See if upon close inspection, you have any visual signs of capacitor failure on the motherboard. Plus if the VRM, or VRM's, are not of an Integrated Circuit design, (Plus not enclosed in a case that you cannot open), see if there are any visual signs of capacitor failure.http://www.capacitorlab.com/visible-fail...
  • joecoolvette
    VRM = Voltage Regulator Module. Regulates the voltage for the Processor. You have dual VRM's as you have dual Processors. NMI = Non Maskable Interrupt.http://en.wikipedia.org/wiki/Non-maskabl... Would appear one, or both VRM's are weak. Just my thoughts.
  • 53 Answers
Check windows logs!
Posted on Feb 11, 2010
Can run windows 8 on IBM intellistation z pro ?
IBM IntelliStation zPro came with different CPU chips through 1997 to 2006. Depending on which year or type your machine is will determine if you can upgrade to Windows8.
The chips used were
IntelliStation Z Pro
Type 6899 (March 1997 to ??)
Type 6865 (October 1998 to April 2000)
Type 6866 (January 2000 to March 2002)
Type 6894 (May 2001 to June 2002)
Type 6221 (November 2002 to February 2005)
  • Dual Intel Xeon at 2.4, 2.67, 2.8 or 3.2 GHz
Type 6223 (August 2004 to March 2007)
  • Dual Intel Xeon with Intel 64 (formerly EM64T) at 3.0, 3.2, 3.4, 3.6 or 3.8 GHz
Type 9228 (June 2006)
  • Dual Intel Xeon Model 5130, 5140, 5150 or 5160
Windows 8 If you want to run Windows 8 on your PC, here's what it takes:
  • Processor: 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2 (more info)
  • RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card: Microsoft DirectX 9 graphics device with WDDM driver
As you have Type 6223 which a Xeon faster than 1GHz it should work with Windows 8 but not all Xeon processors are compatible depending on which one you have. See this Microsoft site after you check your Xeon chip family on the motherboard or through the Windows system command. Search for xeon.
Processors What processors support Windows 8
Aug 15, 2014 | IBM IntelliStation Z Pro 6223-42U PC...
Nmi error
Chip-set or memory error that relates to parity or ECC (error correcting) Try singling out your system memory and see if you still get this error.
Feb 05, 2014 | IBM Xseries x346, 1 x xeon 3.6 ghz/1 mb,...
Single core 2.8ghz xeon to quad core cpu
http://en.wikipedia.org/wiki/Xeon#Prestonia
"In 2002 Intel released a 130nm version of Xeon branded CPU, codenamed "Prestonia". It supported Intel's new Hyper-Threading technology, and had 512KB L2 cache. This was based on the "Northwood" Pentium 4 core."
Meaning it is a Single-Core processor.
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#.22Prestonia.22_.28130_nm.29
Scroll down.
400MegaHertz Front Side Bus. (400MHz FSB)
http://en.wikipedia.org/wiki/Xeon#7300-series_.22Tigerton.22
"The 7300 series, codenamed Tigerton (product code 80565) is a four socket (packaged on Socket 604) and more capable ->
QUAD-CORE processor.................."
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#.22Tigerton.22_.2865_nm.29
1066MegaHertz Front Side Bus. (1066MHz FSB)
The motherboard uses the Intel E7505 motherboard chipset,
http://en.wikipedia.org/wiki/Intel_Xeon_chipsets#NetBurst-based_Xeon_chipsets
Note the - Processor FSB supported -
533MegaHertz
ONLY supports Single-Core processors, too.
The answer is No
Regards,
joecoolvette
Dec 17, 2012 | Computers & Internet
Ooh, ooh, I know this one. Is it an x346?
Did you also get "error 2807-01 Controller Onboard detected an internal error error 2200
CPPRHTS1&1 FAIL DATA: 035-253-001-20100309-58-RAID"?
Get a 71P8644. I've had two servers fail identically as above. Solid fixes.
Or use a Search Engine if your server/symptom differ.
Jul 14, 2011 | IBM ServeRAID-7k Controller (71p8642) SCSI...
PLIIS DRIVER ANTENNA GPS HI-204III USB.WINDOUS 7 !!!
I have installed Garmin mobile PC 5.00.70. on my Toshiba Satellite L450, OSWindows 7 Ultimate, Dual-Core CPU T4400, 2,2GHz, 3,0GB RAM, but can't findHI-204III USB.
I was regularly install driver for HI-204III USB also and W7Ultimate was informthat new device is successfully installed.
Sep 04, 2010 | Haicom HI-204E GPS Receiver
Dell PowerEdge 1600sc server won't boot.
> black screen & flashing cursor ...
Damaged boot-record on the disk-drive???
Was it configured to try to boot from 'A:' ?
Disconnect the hard-drive & CD/DVD drives.
Put a diskette into the drive, and see if it tries to find a boot-record on the diskette.
If it tries, then it has P.O.S.T.'d correctly.
> no beep codes
When it worked, did it beep _once_ when P.O.S.T. completed?
Taking out the RAM _should_ cause some beep codes, i.e., "no RAM".
> anyone?
Replace the monitor?
Replace a dead video-card?
Or, add-in a video-card, and connect a monitor to it, leaving the original monitor connected to the original video-card. One of the two displays should show the P.O.S.T.
Jun 12, 2010 | Dell PowerEdge 1600...
IBM server x346 has problem
The x346 server should have 2 SMPS in the server , Try connecting one power and test and then try the other , incase the smps has some problem such issues ivolve.
Dec 25, 2008 | IBM eServer xSeries 346
Windows 2008 server installation in IBM X346 server
http://www.soft32.com/Download/Free/Adaptec_AIC7902_HostRAID_driver/4-173525-1.html
Try this one
Dec 11, 2008 | Microsoft Windows Server Standard 2003 for...
Windows 2008 on IBM x346
I used this one with good result:
http://www.adaptec.com/en-US/speed/scsi/windows/a320raid_win2k8_x86_b212_exe.htm
Nov 11, 2008 | Microsoft Windows Server Standard 2003 for...
Dazed and confused - unknown system restart
First off, take the message at its word: restart the machine, go into the BIOS and disable all power saving. Also, turn off ACPI if it's on.
Jan 28, 2008 | Computers & Internet
Computers & Internet Logo
852 people viewed this question
David Payne
David Payne
