Question about Panasonic DMR-ES20EG DVD Recorder
Dac42724; I have a Panasonic DMR-ES20 DVD
Dac42724; I have a Panasonic DMR-ES20 DVD player/recorder. It quit working, I unplugged it and plugged it back up to reset everything. Now it will run through the updating process (000000) scanning across the front of the unit for ever. I held the on/off button to manualy reset to standby. The clock appears I turn it on by remote HELLO appears, and that is all it will do. Cannot open tray ,turn it off, use any functions on remote, or unit. Got any solutions to fix this.
    Top Expert:
  • Panasonic Master
  • 22,687 Answers
There is a DC - C convertor under the deck that fails. There is a kit available for Panasonic Authorised Service Centres.
Posted on Jun 08, 2017
SOURCE: Panasonic DMR-ES20
For the remote to work, make sure "video" is selected (instead of "tv"). It's the little button on the remote under the red button at the top that turns on the TV ("TV/Video")
As for the split screen, I've had that happen numerous times (when I lose power or revert to default settings). YOu have to go to Setup, Display, and select 4:3.
I hope I have helped you. I'm having other problems - with the audio. Some channels have no audio (maybe 3 or 4) and 2 channels are in SPANISH!!! (??) Weird that it's not uniform. I even tried reverting to default settings (and got that split screen!), but didn't help. It "jumped" a few times to the input type screen. I'm thinking some chip got fried or something. I've had it almost 2 years, and guess that's the "built-in" obsolescence!! :-)
Posted on Nov 22, 2007
  • 47 Answers
SOURCE: Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Posted on Mar 09, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
SOURCE: Panasonic DMR ES15 remote stopped working with dvd/recorder...
Try holding enter button and 1 together on the r/c for at least 3 secs
Posted on Sep 30, 2009
Demonic-2011
  • 467 Answers
SOURCE: Hi. Please help, I have
Sounds like a typical communication error between power supply and main microprocessor, resulting in the unit continuously reverting to standby with no other functions accessible. In this case, the power supply has several faulty/leaky components (no shorts or there would be no clock display at all). Always a good idea to target the PSU in these units first, to eliminate any suspects before diving into the microprocessor (which, I might add, is a high-density surface-mounted IC with pins on all 4 sides and it is glued as well as soldered to the main board).
In the PSU, it is possible many electrolytic capacitors have gone funny, bulged, or leaked. Check and replace ALL caps as required; not just a couple, and check the IC regulator (IC1 is usually a problematic device in many DVD recorders). This IC is usually prefixed with STRxxxx (where x represents its type number) and is a 5-pin standard device. This is obtainable as a part. The cost will depend where you get it from.
If you are not tech. savvy, I suggest you submit the unit to an authorised service centre, for a quote, and a second opinion (on the likely causes and/or how many components are involved in the fault as well as economics of the overall repair), then make a decision afterwards, whether it's worth fixing or not. Up to you, but be warned, it could be an expensive exercise either way.
Posted on Apr 19, 2011
Panasonic dmr es20 frozen
Hello
Unplug the DMR from AC mains socket, and replug it after 5 minutes. If this does not help you, make a factory reset to this set. Get into the user manual, and there is proceedings how to do the factory reset.
Mar 05, 2012 | Panasonic Televison & Video
I need a operator,s manual for the panasonic dmr-es20
Copy of the user manual for this unit can be downloaded from this link , just click HERE and proceed to download the user manual for it.
Jun 13, 2011 | Panasonic DMR-ES20EG DVD Recorder
Panasonic DMR-ES20 no longer plays back picture on any DVD. Sound works fine, but no picture. Have tried with component, S-Video and RYG cables, but no picture.
I just had the same problem, Tried a bunch of things, ended up just unplugging it, letting it sit for a min and plugged it back in...fixed.
Jan 10, 2010 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmr-es35v dvd/vcr recorder reads hello, then u61, then
Plug AC power cord to wall electric socket if it is plugged into a surge protector or extension, if not try a different socket, if issue still exist have unit service.
Sep 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
The display keeps saying please wait. I unplugged the unit and plugged it back in and it still displays please wait.
The display keeps saying please wait. I unplugged it a million times. Please help me resolve this problem.
Aug 01, 2009 | Panasonic DMR-E85H DVD Recorder
PANASONIC DMR-ES46VS Front Panel buttons quite working
I have a Panasonic DMR-EZ47V. All of the panel buttons plus the remote will no longer work. I get a display showing F60. Unit is not very old.
Nov 06, 2007 | Panasonic DMR-ES46VS DVD Recorder/VCR
Error code RC3
I absolutely can't believe this worked for me, I'm so excited!! My error was RC3; my remote had an OK button (not Enter) for a Panasonic DVD/VHS recorder. I held down OK and the number 3 and the remote started working!! Thank you so much, I was getting very frustrated!
Sep 12, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-ES20EG DVD Recorder Logo
380 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
