I have a old furnace i light the piolt it stays on but when i turn the the dial on the gas look like its breathing i n an out hard then dies ive taken everything apart and cleaned it the neck the sensor the piolt orphis
  • 1,476 Answers
Have you checked the gas regulator? Sounds like it is fine until there is a bigger demand for gas and the regulator can't keep up. I've seen this on my propane grills. Give it a try and get back to me.
hardrocko
Posted on Feb 07, 2010
Replaced thermocouple pilot stays on but burner wont light
Make sure the gas valve dial is turn to the "on" position. Otherwise, I would need more info to answer this question fully.
Nov 17, 2015 | Empire Comfort Systems DV-215-SG...
How do I light the pilot light on an old moffatt oven
iT SHOULD TELL YOU ON THE BOX WHERE THE RED BOTTON IS LOCATED. MOST WORK LLIKE THIS. YOU TURN THE DIAL TO PIOLT AND HOLD DOWN THE RED BOTTON AS YOU LIGHT THE POILT CONTENUE TO HOLD BOTTON DOWN FOR ABOUT A MINUTE AND LET GO IF THE POILT STAYS LIT THEN TURN DIAL TO ON. IF POILT DOES NOT STAY LET WAIT FIVE MINUTES AND TRY IT OVER AGAIN FROM BEGINNING
May 06, 2014 | Ovens
When I turn gas to furnace pilot light goes out
Now getting enough oxygen. To much fuel but it can not breathe try adjusting pilot nozzle.
Oct 21, 2013 | Omega Trane Furnace Draft Inducer Blower...
Have an empire wall furnace. Natural gas. Vent through the wall. My problem is that sometimes when it ignites, it makes a loud boom and I can see a flame flash at the top of the heat exchanger. I was...
Not sure what the problem is, but mine does the same thing.It also blows the pilot light out when it does it..Had several service calls, no luck...POS, don't buy another Empire heater....
Nov 09, 2010 | Empire Hight Efficient Direct Vent Wall...
Pilot light wont stay lit.want to clean the orifice
You shut off the gas.
Shut off the power.
Remove the gas valve and burner assembly.
After cleaning and reassembly you must purge the system and use a gas leak detecting soap to verify no leaks before turning on the power.
Apr 15, 2009 | Heating & Cooling
Can't find instructions on lennox gf 8 series furnace
Does it have a standing pilot light? On new units, there is an igniter and not a pilot. But if you have a standing pilot, you will move the gas valve to "pilot" and push down the red button while holding a flame under the pilot located by one of the jets. Once it lights continue to hold the button down for a minute or so and then release the button. The pilot should stay lit. Then turn the dial to the on position. That's it.......... If the pilot won't stay lit then the thermocouple is bad and needs to be replaced.
Apr 05, 2009 | Heating & Cooling
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
Changed the filter and I'm not getting hot air. how do you light the piolt
If you have a standing pilot then on your gas valve turn it to pilot. Push the button in on the gas valve in the pilot position. Hold for 60 to 120 seconds than release the button a turn to on and the furnace should fire up.
Oct 21, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
